Question about Dometic Rooftop RV Air Conditioner
Compresser tries to kick on but wont - Dometic Rooftop RV Air Conditioner
  • 3,600 Answers
You have a bad start capacitor and the three prong device san be replaced by buying on line or going to a RV dealer and buying the three prong compressor start switch, it pulls out has three holes in it the shape of a triangle if it has a bad start capacitor you can buy one that will replace it without taking out the old capacitor. If you want a web site where they sell these post on this answer and I will send you the address of the parts store that sells them.
Posted on Jul 16, 2009
    Scholar:
  • 91 Answers
Have you tried another electrical hookup for your RV? You may not be getting quite enough electricity to start compressor(it takes quite a draw) It may need a kickstart, which supplements the capacitor in starting the compressor. This usually is needed when the unit gets a little older. It piggy backs onto your capacitor inside the unit, up top. If you turn off the energy, take off the plastic shroud you can access the electrical box. If you can fit a kickstart into the box be sure to secure it with some metal plumbers tape and sheetmetal screws. It might be a challenge to find a supplier willing to sell A\C parts to the public. But good luck anyways.
    Champion:
  • 233 Answers
It could be the start components or the compressor, the start relay or capacitor may be bad, (if equipped) this can be verified with an ammeter, if there are no start components you can try adding a start assist to the compressor circuit, (if it has a run capacitor)
My 2001 zr2 s10 cracks hit an kicks back an wont start
Timing Issue
Belt,Chain,Ignition
Compression problem preventing
it from turning over
Does it turn over by hand
See if you still have the correct cam timing
with #1 cylinder at top dead center
Mar 07, 2013 | Chevrolet Astro Cars & Trucks
Kawazaki kdx 125 wont start
KICK HARDER TRY PULL STARTING IT..IN SECOND GEAR..DOES IT HAVE ENOUGH COMPRESSION TO START?IT SHOULD START PULLING IT...START OFF WITH NO THROTTLE THAN IF NOT STARTING CRACK THE THROTTLE SO LIGHTLY AND SHE SHOULD FIRE OFF WHILE IN GEAR BEING PULLED OF COURSE BE CARE FUL NOT TO RUN INTO. WHO EVERS PULLING YOU..USE A LONG TOW ROPE..IF YOUR NOT A SEASONDED RIDER AND KNOW YOUR BIKE VERY WELL I WOULD NOT ATTEMPT THE PULL START...IF NOT CHECK YOUR COMPRESSION AND TIMING..MAJOR VACUUM LEAK MAYBE AT BASE GASKET..IS ENGINE SUCKING TO MUCH AIR? GOOD LUCK..
Mar 02, 2013 | kawasaki KDX 125 Motorcycles
My 125 4 stroke wont start when i was just riding it
This is a lawn mower, not a two way radio...
Peter
Nov 20, 2012 | Radio Communications
Hi have a Husqvarna 410 2000 got spark fuel back fires but wont start checked flywheel is on right valves rock at top dead centre ... ?? but wont start ? kick start only tho ?
If the valves "rock" at TDC, the piston is at TDC EXHAUST, not TDC COMPRESSION. Chances are the engine is flooded. Install a fresh spark plug and go easy on twisting the throttle when starting the bike. Be sure the battery is in good condition. Push the kick lever to just past TDC compression then give a strong kick. Don't try to kick start with the piston going upward on the compression stroke. Be sure the air cleaner is not dirty and you have good gas. Please rate my answer. Thanks!
Mar 27, 2011 | 2000 Husqvarna TE 410
Rm 125 wont crank
wont start, or you can't move the kick starter?
If it kicks easily, do a compression test.
Feb 04, 2010 | Suzuki RM 125 Motorcycles
Husaberg 600 wont start on the kick
How much do you weigh? If you have strong compression, that's what you want.
Aug 06, 2009 | 2000 Husaberg Fe 600 E SM
I have a 1994 buick lesabre and the a/c wont work.the air compresser is good, i put freon in it,no leaks,what else is preventing my compresser from kicking in?
Try a test light on the wire on the compressor if it does not kick on. It should kick on in the a/c positions, as well as the defrost positions. See if someone can help, turning on and off the a/c inside the car ;)
Jul 02, 2009 | 1994 Buick LeSabre
My 1993 Olds 88 wont start cranks but wont kick over. Fuel prob
3.8 are known for ignition trouble but first use the fuel release valve located on top of engine under a screw cap to see if your getting fuel. It takes 4 things to make engine run fuel spark air and compression. But most likely the Ign control module or crank sensor. So try this
1) check the fuel pressure
2) check for spark
3) compression test
Apr 26, 2009 | 1988 Oldsmobile Delta 88
Yz 250 wont kickstart
Hi!
You obviously look after your machine and very sensible when laying up, however as you are probably aware 2 strokes rely heavily on compression, A. to produce excellent combustion and B. to draw fuel into the chamber. So when you try kick starting you can't get enough revolutions to draw the correct amount of fuel into the cylinder, where as you push start you constantly turn over the engine increasing compression slightly and bingo it fires.
Can you remember how when kick starting it before this problem the feel on resistance when kicking over? has it now become a lot easier? if so you possibly have worn or broken compression piston rings.
A compression test will reveal this, I hope this sorts your query?
Press the Blue button please for my FREE effort,
Thank You!
Paul 'W' U.K.
Feb 06, 2009 | 2000 Yamaha DT 125 R
Yz 250 1992 wont kick start
check your compression I had a 94 yz that done that when i checked the compression it was really low so I put new rings on the piston and that's all it took to bring her back to life
Feb 03, 2009 | 2000 Yamaha DT 125 R
Dometic Rooftop RV Air Conditioner Logo
225 people viewed this question
Top Dometic Heating & Cooling Experts
Bill Long
Donni Steen
mike cooper
Are you a Dometic Heating and Cooling Expert? Answer questions, earn points and help others
