Question about Whirlpool Calypso GVW9959K Top Load Washer
Error code C1 what is the problem - Whirlpool Calypso GVW9959K Top Load Washer
  • 15,935 Answers
The C1 error is displayed when the motor tries to pull more than 26 amps to run.
This indicates a problem with the motor or motor controller.
Overloading or excessive suds can also cause this error.
If you like to make a few more checks then the image below contains the instructions for entering the diagnostic test mode.
Its a short cycle that runs all of the components so the operation of each can be checked.
I hope this helps but an intermittent C1 error can be hard to pin down.
http://media.fotki.com/1_p,wbrrkqqwkwbqsdgxgtqsskgwtqkq,vi/kdkftbfkwxkfsqdgqsg/1/1303472/5961857/image5668img-or.jpg
From the service manual....
"C1 = Average current limit Or Instantaneous current limit.
If a status signal comes back from the motor controller that a current
limit has been breached, the unit will return to standby mode and
display either CA for average current limit trip or Cl for
instantaneous current limit trip.
Average current trip occurs if there is a 2 second average of current
draw greater than 5.55 amps
at the motor windings.
Instantaneous current trip occurs if there is a spike of 26 amps
instantly at the motor windings.
This may signify problems with the drive motor, thermal protector, or
motor controller. Over-loading the unit may cause this problem."
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 23, 2010
What is error code C1-14
C1 14 MAIN CHARGER TROUBLE (COLOR)
You might be able to clean the charge wire.
https://www.sosnfl.com/sharp-mx-c312-error-codes/
May 07, 2016 | Sharp MX-C312 Multifunction Printer
Sharp MX-2600n has an E4-11 code. How do I fix that?
Search Results
    SHARP MX 2600N ERROR CODES Trouble Codes
    https://www.sosnfl.com/sharp-mx-2600n-error-codes/
    SHARP MX 2600N ERROR CODES trouble codes C1 10 C1 14 C4 00 E7 03 E7 10 E711 E7 ... Wait until the panel has gone dark and any flashing buttons have stopped flashing. ... A0 11 FIRMWARE VERSION INCONSISTENCY (MFP-PCU).
    [PDF]Sharp MX-M350N Trouble Error Codes - OlsonBros
    olsonbros.com/sharp/.../pdf.../trbl-mxm350n_m350u_m450n_m450u.pd...
    MX-M350/M450 N/U TROUBLE CODES 11 - 1. [11] TROUBLE CODES. 1. General. When a trouble occurs in the machine or when the life of a con- sumable part ...
    [PDF]Sharp MX-3500N Trouble Error Codes - OlsonBros
    olsonbros.com/sharp/support/.../trbl-mx3500n_3501n_4500n_4501n.pd...
    MX3500N SELF DIAG AND TROUBLE CODE 8 - 1 ... part has reached .... 11: When detected during other than a job, the operation is enabled in other than the ...
    Error Codes > Sharp > MX2600N - Printcopy.info
Feb 03, 2016 | Sharp Mx-2600n MFP Copier
I keep getting an error message and it stops, Error message C1 and there is nothing with the bobbitn
Try hitting the F8 key after the Laptop starts booting, and when the list of options comes up, select boot in safe mode. If you are unable to get to the options screen, then search on the C1 error code on Google, and look at the tips on resolving the problem.
You will need to make note of the full error code, ie C1xxxxxxx.
Sep 04, 2015 | Computers & Internet
Carrier Comfort Zone II Thermostat is blank and the 3 companion thermostats are all showing Error Code C1. What does that mean?
Hi Anonymous,
For all wall mounted and Artcool split system codes
Error code = C1 or CH1
Flashing Light = 1
Fault = Indoor temperature sensor open or closedcircuit.
Display = Indoor.
Indoor Operation = ON
Error code = C2 or CH2
Flashing Light = 2
Fault = Outdoor temperature sensor open orclosed circuit.
Display = Indoor Outdoor.
Feb 14, 2015 | Carrier Heating & Cooling
What is a code c1 on a samsung mini split?
Fault = Indoor temperature sensor open or closed circuit.
Jul 26, 2014 | Samsung AQV12VBCN Vivace Mirror Finish...
Xerox workcentre 5020/Dn c1 error
i have one xerox 5020 machine, there is display showing C1 error code in first tray and C3 error code in bypass tray .if open and close the machine will be idle and ready to cpoy. there is no paper pick up in both trays. please help to resolve the problem.
Dec 17, 2012 | Office Equipment & Supplies
I have error code E000732-0001 on Canon imagepress C1
Error :
E732 code
Workaround :
E732 code is a Reader communication error.
If the Reader is disconnected from the Printer a E732 code will result. Once the Reader is disconnected the logic on the MAIN-Controller is changed to a "0". The copier is now set up to be a Printer only, and will not recognize the Reader.
To correct this, you must enter service mode, COPIER>OPTION>BODY>W/SCNR and set that to "1". Then you must turn the copier off, then on.
To enter service mode: press "Additional Functions" then "2" and "8" together, then "Additional Functions".
Which User Guide? Reference, Easy Operation Guide, Printing Guide, Mailbox Guide, Sending Guide etc....
Sep 09, 2009 | Canon imageRUNNER C3200 Copier
Error code c1
Error code C1 indicates a problem with drive motor-thermal protector or the motor controller
may be due to overloading
Press( stop/cancel) to clear the display.
Hope this helps
Dec 23, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
Getting error code c1
Hi
Error code C1 indicates problem with drive motor-thermal protector-or motor controller
Overloading may also cause the problem.
Hope this helps
Nov 24, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
C1 error code
CL code stands for overloaded motor. Motor is drawing to many amps and cuts out. I suspect a failing motor or something binding that causes the motor to draw to many amps. Don't know how to fix it.
Aug 20, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
Whirlpool Calypso GVW9959K Top Load Washer Logo
124 people viewed this question
Dan Webster
Dan Webster
Sal De
