Canon XL1S Mini DV Digital Camcorder Logo
p
peter james cail Posted on Feb 18, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Have pixellations accompanied by crackling. sounds electronic fault. Picks up good footage via firewire. Good tapes still offer crackling etc.
Using a known good tape still results in poor replay, also new tapes also give poor recordings. Recording digitally via the firewire connection gives good results.
David Payne
Level 3:
Top Expert:
  • Canon Master 14,162 Answers
  • Posted on Feb 18, 2016
David Payne
Canon Master
Level 3:
Top Expert:
Answers
14162
Questions
0
Helped
2998361
Points
455836
1helpful
Hi, I am trying to import from my Canon MV 600 ( Tape not digital ) into a mac pro. I got the DV to firewire lead but the computer doesnt seem to recognise the camera. Many thanks Billy
Hi in order to get footage off your camera through Firewire i.e DV you will have to use a software to capture the footage. You can use iMovie to capture the footage off the camera.
Open Apple System Profiler (it's in the Utilities folder) and check to see if your camera appears in the FireWire section.
If your camera is connected via FireWire and is turned on, follow one or more of these tips to re-establish the connection to the camera.
  • Turn the camera off and back on again.
  • Disconnect the FireWire cable from your computer and reconnect it. Do the same at the camera as well. If the camera is connected through a FireWire hub, try connecting the camera directly to the computer.
  • Some cameras need to be set to "VTR", "VCR", or "DV" mode in order to communicate with a computer. Check your camera's documentation for information on how to set your camera to this mode if needed
Hope this helps.
How do you record without sound
There does not appear to be any provision on the camcorder menu, to mute the audio.
As an alternative, I would recommend you connect the camcorder to your computer or laptop (via firewire if possible) and transfer the footage onto your computer's hard drive.
You can then use your computer's Movie Maker application to edit the footage - here you can either remove the audio track, or overlay your new audio soundtrack.
Good luck !
"if this has helped you, please rate this solution"
HVX200 shot footage - viewing footage on consumer grade camera
You can only view hd footage on hd devices. so if you recorded hd footage onto a tape, you will not be able to view it on a standard def camera, ie the dvx100b. The footage should not be harmed. Now if you are trying to view via p2 card over the firewire, whole new scenario.
Can't Import Footage Via Firewire with Sony DCR-TRV900E and Vista
Hi nash
I ma having the same problem... Did you get a solution in the end?
How do i edit footage from dcr-dvd105e on my laptop
If you are running Windows "XP" or "Vista" on your lap top you have Windows Movie Maker on your machine. If you run that program with your camcorder connected via Firewire it should be detected automatically. WMM allows you to edit your video and output to EMail, CD and DVD. Use the WMM "Help" facility to get you started. Good Luck.
Pixels instea of clear picture
The problem is with the tape...Never rewind tape in the play mode for some reason it will screw it up.
And only use good tape such as...
Panasonic - MiniDV Digital Video Cassettes Model: AY-DVM80XJ
3answers
Sony DCR-HC 36E Bands of old video & pixellation
well, first a few things I want to point out to you.
-fixya is no a job for experts.
-I can't be on guard 24/7
The video heads may be dirty use a cleaning Casette to see if things improve
http://www.sonystyle.com/webapp/wcs/stores/servlet/ProductDisplay?catalogId=1551&storeId=10151&langId=-1&productId=11027631
Aug 25, 2008 • Cameras
1helpful
2answers
SHARP Viewcam z vl-Z500H-S Camcorder
To transfer video you need to use firewire, not usb. If you use firewire to connect, set the camera to the 'play' icon and then open up a capture program (ie, movie maker) you should be able to just record/capture from there. Good luck!
3answers
Get Final Cut Pro 5.04 to communicate with my XH A1
Many HDV cameras and decks are able to play and record DV as well as the higher-resolution HDV format. Additionally, many of these HDV devices will attempt to automatically change their settings to match the format of the tape that it's playing. Here are some tips for using these types of devices with Final Cut Pro / Final Cut Express.
Tip: Make explicit settings on your HDV device. Instead of using an "Auto" setting, make your own settings on your HDV device to keep the communication going between it and Final Cut Pro / Final Cut Express. This also helps Final Cut Pro / Final Cut Express keep things running smoothly with HDV devices that handle both DV-NTSC and DV-PAL.
For example, say you're using an HDV deck to capture footage from a tape that was recorded as DV-NTSC. Before capturing in Final Cut Pro / Final Cut Express, make sure that you set the deck to DV mode specifically—don't rely on Auto mode. With some devices, you may need to disconnect it from FireWire to change the mode.
For a common capture workflow, this sequence of steps can provide the best results:
  1. Quit Final Cut Pro / Final Cut Express if it's open.
  2. Insert your tape into your HDV deck or camcorder.
  3. Use the device's menus to set it to match the format that's recorded on the tape.
  4. Connect your HDV device to your computer with a FireWire cable.
  5. Open Final Cut Pro / Final Cut Express.
  6. Choose an Easy Setup for DV or HDV (whichever matches the format recorded on your tape).
  7. Proceed to Log and Capture.
Tip: Quit Final Cut Pro / Final Cut Express before changing modes. It's generally a good idea to quit Final Cut Pro / Final Cut Express before you change the mode on your device from DV to HDV, or from HDV to DV, and then re-open the application again.
Tip: Use an Easy Setup to play back non-default HDV format footage on your HDV device. You can use Final Cut Pro / Final Cut Express to make your HDV device play back footage in its non-default HDV format. For example, maybe you have a 1080i60 HDV device and want to play back footage that was recorded as 1080i50. Or perhaps you have a 1808i50 HDV device and you want to play back footage that was recorded as 1080i60. To do this, follow these steps:
  1. Connect your camera to your computer.
  2. In Final Cut Pro / Final Cut Express, choose an HDV preset Easy Setup that matches the format of the tape's footage (you don't need to restart Final Cut Pro / Final Cut Express).
  3. Your device's LCD display should automatically display a switch to 60 or 50, indicating the type of media that's being played.
Playing back non-default DV format footage on your HDV device You can also use your HDV device to play back footage in its non-default DV format too. For example, maybe you have a 1080i60 HDV device and want to play back footage that was recorded as DV-PAL. Or maybe you have a 1080i50 HDV device and want to play back footage that was recorded as DV-NTSC. If so, follow these steps:
  1. Make sure that your device is in DV/DVCAM mode.
  2. Put your device into Play/Pause mode, then open the Log and Capture window in Final Cut Pro / Final Cut Express.
  3. Make sure that your device's LCD (or other readout screen) displays the same format as your tape or Final Cut Pro / Final Cut Express will misinterpret what type of device you have.
Tip: Avoid recording both HDV and DV formats on the same tape. Use separate tapes whenever you want to record in a different format. If you need to record over existing footage in a different format (for example, you have a tape with DV-PAL on it, but you want to record over it with HDV 1080i50), it's a good idea to black and code the tape, or completely record over the old footage with contiguous recording in the new format. If the tape contains even a second of, say, DV in the middle of an HDV tape (or vice versa), it could cause unexpected results later when you try to capture video from that tape.
For more information, see HD and Broadcast Formats and the Final Cut Pro / Final Cut Express User Manual, available under the Final Cut Pro / Final Cut Express Help menu
HELP!!!! Panasonic GS180
firewire is an apple gift to the video etc . world ( also called standard : ieee 1394 ); it solves some problems better than usb because it is a peer to peer connection ( all devices communicate with each other ) and your editing will be easier with it ;
Top Canon Video Cameras Experts
NOEL
NOEL
john h
Are you a Canon Video Camera Expert? Answer questions, earn points and help others
