Question about Sharp Office Equipment & Supplies
What's your question? My machine (MX-2300) sharp got problem of E7-20
    Top Expert:
  • Sharp Master
  • 14,162 Answers
Posted on Feb 18, 2016
SOURCE:
Sharp Tech
  • 63 Answers
SOURCE: uc-21 code
I will have to take a stab at this at this code is not listed in the service manual. The UC codes deal with Counterfeiting! Either the user wanted to try and copy money or they copied something that had the colors very close to money so the only way to fix this is to have an authorized dealer call Sharp and have the boards ordered.
Posted on Oct 17, 2009
  • 6 Answers
SOURCE: what is Code: H5-01 on the sharp mx 2300 copier
You need a service reset.This is a fuser problem .clr and star and hash and star fusing reset
Posted on Nov 16, 2009
  • 15 Answers
SOURCE: How do you load standard sized envelopes into a
long ways in the cassette, unless you have a bypass tray, make sure to change your cassette setting under systems settings, tray settings.
Posted on Sep 09, 2010
  • 66 Answers
SOURCE: How can I check drum and developer usage level for
You can press #*C* respectively, then press 22 start 1 start respectively then it will show you all the counteres including drum and developer for the 4 colors.Rate this and vote for this
Posted on May 17, 2011
Testimonial: "Thanks a lot, that's exactly what I was looking for. Now, another question: what does that mean that i.e. drum for yellow has "02" life?"
dwylie76
  • 80 Answers
SOURCE: how to download the part guide for sharp mx 2300
Email me at dwylie76@gmail.com
Posted on Oct 25, 2011
How do i fix error code L4-06 on sharp MX-2300
Trouble content
When separating the primary transfer belt unit,
change in the separation position sensor
characteristics is not detected within the specified time.
Section
PCU
Case 1
Cause
Harness connection trouble between the PCU PWB
and the separation position sensor
Check and remedy
Check the harness between the PCU PWB and the separation position sensor.
Case 2
Cause
The belt position sensor is not interrupted or it is always interrupted.
Belt separation clutch operation trouble
Check and remedy
Use SIM6-3 to check the belt separation operation.
Case 3
Cause
The primary transfer belt unit is not installed.
Check and remedy
Install the primary transfer belt.
Hope this help you, good luck!!!
Nov 23, 2015 | Sharp MX-2300N Color Copier
Print 4.374 x 5.75 sharp 2300
Envelopes must be run from the bypass tray at the side of the machine. touch the paper trays on the touch screen. Set the bypass to envelope and com10. when you go to print, make sure the paper type is set to envelope under printer preferances.
Aug 03, 2012 | Sharp MX-2300N Color Copier
Sharp MX 2300 E7-01
That is an ICU image transfer trouble code. Check your MFP PWB connections, or replace your MFP PWB.
Oct 04, 2011 | Sharp MX-2300N Color Copier
How can I check drum and developer usage level for Sharp MX 2300?
May 17, 2011 | Sharp MX-2300N Color Copier
MX-2300 scanner errror message: Selected Servers
You probably have incorrect log in details (Username & password)
Apr 08, 2010 | Sharp MX-2300N Color Copier
What is Code: H5-01 on the sharp mx 2300 copier
Oct 27, 2009 | Sharp MX-2300N Color Copier
UC-21 code and the service manual only goes to UC-20 Model sharp MX-2300
Apr 30, 2009 | Sharp MX-2300N Color Copier
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
Adorjani Laszlo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
