Question about Kenmore 94802 Front Load Stacked Washer / Dryer
Kenmore Washer/dryer combo not going into spin/drain mode in the washer. fill, and wash work fine.
  • 15,935 Answers
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question@#@#$%
Posted on Oct 01, 2010
My kenmore 29822800 won't fill with water, it works on spin and drain
The last time I moved, my washer/dryer combo (Frigidaire) had the same issue for approximately 7 months before finding out all I needed to do was level the washer, and of course, make sure the faucet connected to the washer is turned to on position. Hope this is helpful.
Praysemema.
Mar 13, 2013 | Kenmore Washing Machines
My washer filled up with water, - the filling part works. however, it won't agitate or drain.
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
Aug 23, 2010 | Kenmore Dryers
Water under stackable washer dryer
The front panel comes off and you will be able to trace the water source. These combo units spin immediatly and if the drain is slow the water will spin up over the edge of the tub during drain.
Eric
Dec 24, 2009 | Kenmore 98702 Stacked Washer/Dryer
Kenmore front-load washer stops at rinse cycle
When the washer initially fills for the wash, is it only hot water entering the drum? Try switching the water temperature between hot and cold as it fills. If any of them show little or no water getting through, it sounds too easy but check to make sure water supply taps are on, and that the cold/hot fill hoses aren't reversed. Remove the fill hoses and check any of the screen filters for blockage (in the hoses and in the inlet water valve). When the machine stops and waits to fill but all you hear is a hum, it sounds like there is power going to the valve but water is not able to get through it.
Mar 03, 2009 | Kenmore 43142 Front Load Washer
Kenmore stack washer and dryer
gabehart....sounds like belt is slipping. Replace it. The water pump is on a separate smaller motor so is not affected by the agitator/spin motor.
Jun 04, 2008 | Kenmore 98702 Stacked Washer/Dryer
98702 Washer Drain/Spin Dead.
My Kenmore 98702 washer Fills and agitates as expected but stops at the end of cycle failing to drain or spin
Dec 05, 2007 | Kenmore 98702 Stacked Washer/Dryer
Frigidaire Washer/dryer combo
Dtronics,
A part called a (wig-wag) its a part that consists of two selonoids, one is bad. It switches the transmission from the wash cycle to the spin cycle,at the same time it opens the pump for draining.
hope this is helpful
handiman518
Nov 13, 2007 | Frigidaire FEX831CS Top Load Stacked...
Kenmore 4314220
It sounds like you could have a couple of issues going on here. First of all, to answer the question about stacking the units; there is a mounting kit that you are supposed to use to place the dryer on top of the washer. The top is supposed to come off the washer to accomplish this. There are a couple of brackets to install and the dryer is supposed to mount to the washer with a couple of screws. Your local appliance store should be able to provide this for you. All you need is the model number of the washer and dryer. If the timer is only working on one cycle then you may have a bad timer. But...before we go jumping on that bandwagon...you mentioned that the washer is not filling and the water just keeps running out. This sounds like a problem known as "siphoning". If you have placed your drain hose in the standpipe in a manner that does not provide an air gap for drainage, the washer will not fill and will continue to "siphon" water from the machine as it tries to fill. If the washer cannot fill, the pressure switch will not shut off, and the timer will not advance any further. Double check your drain line to make sure you do not have it shoved too far down in the standpipe (3" to 4" should be sufficient). If the drain hose is sitting in the drain trap where the water sits, there's no air gap. Also, make sure you do not have the top of the standpipe sealed for any reason. Once again, you need an air gap in order for the water to drain properly. Let me know if this helps you.
Sep 08, 2007 | Kenmore 43142 Front Load Washer
Loud spin, doesn't fill, dial doesn't move.
yes you do have to remove the top off the washer and the washer should come with a mounting kit that must be used when stacking this unit. as far as your filling and draining problem i have had this problem several times before you have to replace your speed control board or sometimes called the speed control unit in the lower right hand corner of your washer
Kenmore 94802 Front Load Stacked Washer / Dryer Logo
122 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
