Question about Minn Kota Boating
1995 minn kota turbo 865 will not turn new foot control/wil turn if power is hook direct past cotrol board
tbirdfan1
  • 3051 Answers
SOURCE: Where can I get installation manuel for Minn Kota bow mount maxx?
Hi there
if you go to the web site of the manufacture they havre a printable version of the manual there is even a phone number to call for help please try this ok and let me know how this works for you
best regards mike
Posted on Mar 06, 2009
  • 10 Answers
SOURCE: Where can i get a circuit board for my minn kota
http://www.northlandmarine.com/MinnKotaQuickRef.htm
You need your serial number of the trolling motor, length of shaft, and thrust poundage.
or you could call Minn Kota direct and give them the same information at 800-227-6433.
Posted on May 02, 2009
SOURCE: I need Minn Kota Power Drive operators Manual
I'm installing a Minn Kota Power Drive 70# on my Crestliner Fishhawk. I understand the 24 volt system. however the boat has 2 black, an orange and a red wire running to the batteries. I know black to neg. but where do the orange and red wires go.
Posted on Jun 28, 2009
SOURCE: i have a minn kota deckhand 35 that wont wind up.
Solution- Take the cover off the Deckhand 35 by Minn Kota. Inside is a motor drive. Remove the cover plate held in place with 4 screws. inside are nylon gears, most likely broken. The gears can be replaced with a Minn-Kota Deckhand Gear Repair Kit.
I found mine on the web at Northland Marine.com it's about $24.00 for the kit, plus shipping.
Good Luck!
Posted on Jul 13, 2009
SOURCE: can you wire a minn kota foot control
Lost power to trolling motor. Fuses are good, and am getting power to the plug. I replaced the control board about 3 years ago, and the attenuator never worked right. How can I tell if power is making it to the control board?
Posted on Apr 06, 2010
Only have a model number and need to order a Minn Kota electric motor propellor
Minn Kota go by the thrust which is mentioned on the top plate. I got mine off Craigs List as well.
  • Minn Kota Prop Compatibility Chart - TrollingMotors.net https://www.trollingmotors.net/blogs/selection/86967623-minn-kota... Minn Kota Prop Compatibility Chart Minn Kota Prop Charts. ... Minn Kota with a serial number and they can recommend a compatible prop for your older Minn Kota motor. ...
  • Minn Kota Motors www.minnkotamotors.com Prop Selection & Part ... Electric Anchor Winches; Shop All; APPAREL. ... A combination of a Minn Kota motor and foot controlled rudder steering allow you truly ...
  • Trolling Motor Replacement Props - Minn Kota www.minnkotamotors.com/Accessories/Trolling-Motor-Accessories/... Minn Kota builds the world's toughest ... Electric Anchor Winches; Shop All; APPAREL. Mens; Ladies; Youth; Shop All; WHAT MOTOR DO I NEED? LET US HELP YOU ...
  • Minn Kota Replacement Propellers - www.fishntech https://www.fishntech.com/minn_kota_propellers.html ... Minn Kota Electric Trolling Motor Replacement Propellers & Nut Kits, ... Minn Kota Replacement Propellers . ... Minn Kota Electric Trolling Motor Replacement ...
  • Minn Kota props replacement props for Minn Kota www.minn-kota.com/minn-kota/minn-kota-propellor/page/2 Minn Kota Replacement Props for propellor Weedless Wedge 2 Props ... Minn Kota MKP 3 Prop 2061151 ... MinnKota Trolling Motor Power Center $57.58; DeckHand Electric ...
  • MINNKOTA MKP 37 2091170 TROLLING MOTOR PROPELLER ' ... www.ebay.ca/sch/...nkw=MINNKOTA+MKP+37+2091170+TROLLING+MOTOR+P... Find best value and selection for your MINNKOTA MKP 37 2091170 TROLLING MOTOR PROPELLER ... MINNKOTA MKP 37 2091170 TROLLING ... MINN KOTA ...
  • Jun 08, 2016 | Minn Kota Endura 30 Freshwater Transom...
    The motor has two speeds. Very fast forward and very fast reverse. The speed control is not functioning
    A lot of these units have 2 year warranty. Minn Kota web site list authorized warranty repair centers. The foot control unit most likely got water in the digital switch. If not under warranty any longer, open it up and see if any water bubbles in the sealed board where speed switch makes contact. If so you will need new foot control.
    Sep 30, 2010 | Minn Kota Powerdrive 68PD V2 Pontoon Motor...
    My Johnson Escape boat w/ Minn Kota engine stopped running
    I've had the same problem. It steams from the control panel. I took and ran a seprate ground wire directly to the motor. This is simple to do and takes 15 minutes. Starting in the battery compartment feed cable into the split-loom and continue feeding until reaching the control panel. Pull an extra 5 foot of cable and open dry hatch in rear by motor feed cable around and out to motor connections., Good time to replace rotary switch and circuit breaker. These also are trouble-some parts.
    Aug 01, 2010 | Minn Kota Boating
    On a Minn Kota All Terrain trolling motor, what should the MOM/OFF/CON switch be set to when using the foot pedal manually?
    You should only use the MOM (or momentary) setting when using the push button the foot pedal. Con will just keep the motor running and your foot control will only allow for direction and speed!
    Jul 06, 2009 | Minn Kota Maxxum 70 Freshwater Bow Mount...
    Can you wire a minn kota foot control
    .....I think so ;)
    Here's a schematic, complete with wiring diagram:
    Maxxum 70 Bowmount
    Best of luck!
    Mike
    Jun 04, 2009 | Minn Kota Maxxum 70 Freshwater Bow Mount...
    Prop spins slow on any speed on the foot pedal
    There is a good chance that the control board is bad. This is a common problem with these units. I have replaced my control board twice. When the control board goes out, some function of the unit will not work correctly while other functions work fine. The first time mine went out, the prop motor would not work. The last time the board went out, the unit would only steer right.
    May 27, 2009 | Minn Kota Maxxum 55 Freshwater Bow Mount...
    Minn Kota power drive trolling motor will not steer to the right **** huard
    It is the circuit board in the foot pedal. You will have to replace the whole foot pedal. This is a very poor design. The thin plastic which protects the contacts gets a little hole which allows water to enter and consequently the contacts corrode. Has happened to me two times in past four years. It might be OK for operation in a dirt-free water-free environment; but not under actual fishing conditions.
    Apr 29, 2009 | Minn Kota Maxxum 55 Freshwater Bow Mount...
    Where can i get a circuit board for my minn kota foot pedal Part # is 9901-200c
    Apr 22, 2009 | Minn Kota Maxxum 55 Freshwater Bow Mount...
    Minn-kota 865 autopilot
    Hello dtspins2. Your footswitch is stuck. Disconnect the DC. Remove the bottom of the foot control, check the wiring for insulation broken off and wires shorting out, and disconnect a wire(note color of wires) from switch, reconnect power to confirm motor don't run. Remove the switch and contact your local electrical supply store(may cost less) or marine store for replacement. Good Luck.
    Sep 07, 2008 | Boating
    Used minn kota problem
    on the older ones all i had to do was turn the arrow by hand to match direction. The arrow would click and turn with a little pressure.
    Jul 19, 2008 | Minn Kota Boating
    Boating Logo
    127 people viewed this question
    Top Minn Kota Boating Experts
    Mike Marcotte
    Mike Marcotte
    Andrew Taylor
    Andrew Taylor
    Colin Stickland
    Colin Stickland
    Are you a Minn Kota Boating Expert? Answer questions, earn points and help others
