Question about Dishwashers
Kenmore Ultra Wash dishwasher model number 665.1374 or 665.1384 I am a technician. This unit does nothing. It has power and ground. I have tested the door switches. They test good. If I unplug the unit and plug it back in then it will run a drain cycle, at least that is what I think it is doing. The motor runs for about 4 minutes. Once it shuts off, there is no further response. No control indicators illuminate. No response from pushing any of the touch buttons.
Falling Down
  • 67 Answers
SOURCE: bosch shu8806
the pump may be clogged, or the motor start capacitor may be bad or some units have a fill switch wired inline with the motor so it won't start unless the unit is full
Posted on Nov 30, 2007
  • 1214 Answers
SOURCE: Kenmore Ultra Wash Dishwasher LIghts are blinking....
I suspect for either of these units that the timer control boards are bad.
Posted on Jan 24, 2009
  • 132 Answers
SOURCE: control panel is locked. no buttons work when pushed
Try unplugging the machine and wait 5 minutes. Plug it back in, the problem should clear.
Posted on Mar 26, 2009
  • 7 Answers
SOURCE: Error code 2H
The control panel needs to be replaced (indicated by the "2H" error code displayed at the start of the cycle).
BTW - The number 1 displayed at the end of the cycle indicates the cycle has timed out (i.e., it doesn't mean 1 minute remaining). Hence the continued running of the unit. Until you replace the control panel, you'll have to manually cancel the cycle at this point.
Posted on Jul 29, 2009
  • 127 Answers
SOURCE: kenmore dishwasher has stopped draining.
remove the kick panel below the door, place a pan, etc under where the drain hose connects to the drain extension tube, and slide the clamp back some so you can slide the hose off of the extension tube (white plastic tube) and drain any excess fluid into the aforementioned pan, etc., then unscrew the extension tube and check for plugs, or restrictions.
the sump may also be pluged beneath the strainer assembly, and that requires removing the lower spray arm, the water tube that runs up the inside back of the unit, and the upper parts of the assembly below them to access the drain/pump sump area.
last but not least the impeller is jamed and might be able to be freed by removing whatever has lodged within there..
ya never know...
best of luck,
Posted on Oct 25, 2009
Do you have access to the reset code for my Kenmore Ultra Wash dishwasher model 655.16812990?
Check your model number again. Missing or transposed numbers. You should be able to see or download rhe manual here. Also parts and diagrams.
Parts for Brands Craftsman GE Kenmore Whirlpool and more
Sep 04, 2014 | Kenmore Dishwashers
Kenmore ultra wash diswasher top rack not cleaning
see please the next video for your fix it: God bless you
Jul 21, 2012 | Kenmore 24" Built-In Dishwasher with Ultra...
Power went out and now dishwasher will not restart
Try unplugging your dishwasher and waiting 30 seconds, and then plug it back in. See if that helps.
Nov 23, 2011 | Kenmore Dishwashers
Normal wash light blinking, d/w wont start
Wish I could solve this, as I'm having the same problem too. Normal light blinks not matter which wash button is pressed. Cancel light will light, but still NOTHING happens. Same model as yours.
Jul 23, 2010 | Kenmore PRO 24 in BuiltIn Dishwasher with...
Kenmore Ultra Wash Dishwasher - no lights, won't reset
check wire nuts that were used to install power cord/it is on the right hand side of toe kick if ok there is a fuse on the control that you can replace located top of door
Sep 26, 2009 | LG LDF6920ST Stainless Steel 24 in....
check and see if you are getting ac 110 volts to your water vave when trying to start the unit. if no power check your breakers and /or the incoming power to your dishwasher if they are ok and show 110 voltage coming to the unit then you probably have a control board or touchpad problem which would need a little more detailed check out.
If you do have ac 110 to your water valve then you may just have a bad water valve. Because the washer has to fill first. Hope that helps!!
Jun 29, 2009 | Kenmore 24 in. 15689 Built-in Dishwasher
Dishwasher will not turn on
Bruce, It would be great to know the model number of your your Kenmore Ultra wash dishwasher, please look on the right hand side of the door for a model/serial number if possible.
First steps: With no power, please check how the dishwasher gets power. If it is plugged in to an outlet under the sink, please confirm that it is plugged in fully. If that does not fix the problem and if it is plugged in, remove the dishwasher plug and plug in any lamp or small appliance and make sure it turns on.
If no power at the outlet, check the house circuit box for a tripped breaker/blown fuse. Also, check if any of the outlets have GFI (Ground Fault Interupt) circuit protection. Reset that outlet (even if it is not not the same outlet as the dishwasher is plugged in to.
Next steps: If the dishwasher is connected to a live circuit but still does not work, a component in the dishwasher has probably failed and a service call is in order. Or replacement of the dishwasher, depending on its age.
Please accept this solution soon after walking through the steps - or add a comment with an update and I will try to help more.
Mar 28, 2009 | Dishwashers
Jan 24, 2009 | Dishwashers
Kenmore Dishwasher displays the number "98"
I have a very similar problem. When I push a wash selection, every light on the panel shows up...and when I push Start, nothing happens. When I push cancel, it trys to drain, even tho no water is in there any more. Have you ever had an answer to your problem?
Feb 06, 2008 | Kenmore 16872 Built-in Dishwasher
Dishwashers Logo
105 people viewed this question
Top Dishwashers Experts
