Question about Scosche Industries Scosche Slc4 Speaker High Level Converter
Schoche converter trouble
I have a schoche high to low level converter and i hooked it up before all fine, then bout ten minutes of running time it cut out and the subs will not kick on. The amp is on and it works fine. So its gotta be the converter right? Is it possible to fry the converter
  • 53 Answers
Yes , if you do not make your connections right you could probably damage the high to low, verify that all the wires you tapped into where speaker wires
Posted on Jul 16, 2009
Rainbow e2 won't run on low speed runs poorly on high
Your model has a modulator that may be defective. Take it to a repair facility
Jan 03, 2014 | Vacuums
Engine light on in 2001 tribute Runs rough Book says don't fill gas while running - too late Says it's emission Little help?
try dissconecting battery bout ten minutes.make sure fuel cap tight also.if lite still on will need to hook up to scanner(repair shop) to clear code and reset.it senced fuel vapour leak
Feb 12, 2011 | 2001 Mazda Tribute
What all do i need to hook up three ten speakers with a 1100 watt amp to my factory radio?
you will need to get whats called a line level converter. This device takes a channel from your factory stereo, pads the level down to a reasonable level your amp can take without causing clipping. You can then use your external amp and subwoofers. One major problem with low quality line level converters is alternator hum. Just a warning. Good luck
Mar 20, 2010 | Stingpro ST444 1850 Watts Complete...
Check Oil On 1993 Suzuki Katana 750
Just make the bike level and check it. It's actually better to check it after the engine has been off for ten minutes or so. This ensures that the oil has had time to drain back into the pan and is not circulating elsewhere in the system. That will help with obtaining an accurate reading
Sep 15, 2009 | 1993 Suzuki GSX 750 F (Katana)
Can the Pyle PLCD-42
Yes there is a couple possible ways.
1. Get 2 RCA Y adapters and split your Preamp Output you will not have any type of fader control this way because you are using a single output.
2. Run one amp from the radio with a set of RCA Cables.
Hook up amp #2 using a Line converter connected to the output of your stereo which will convert you to RCA the just run a cable to the amp..
3. If one of the amps has a High Level Input Run a set of speaker wires from the stereo outputs to the High level Input.
I personally prefer the above 2 methods I find Low Level input sounds better.
Hope this gives you some Ideas and helps
Aug 31, 2008 | Pyle PLCD-42 CD Player
Factory stero to amp
If the amplifier has inputs for a high level signal, you unhook the wires going into the speaker and plug them into the amp, then hook the outputs up to the speakers. If the amp only has rca inputs, you need to also buy a line level converter. Then you unhook the speakers, hook the wires up the the converter, then hook the converter up to the amp, then hook the amp up to the speakers.
Please leave good feedback!
Dec 08, 2007 | Blaupunkt PCA250 Car Audio Amplifier
Help! New Grill not flaming properly!
good day,
hope this link below will solve your problem.
grilling
Aug 21, 2007 | Char-Broil Commercial Stainless Steel...
Scosche Industries Scosche Slc4 Speaker High Level Converter Logo
606 people viewed this question
Top Scosche Industries Car Audio & Video Experts
xxxxxx xxx
ravie__s
Level 1 Expert
Jose Velazquez
Jose Velazquez
Are you a Scosche Industries Car Audio and Video Expert? Answer questions, earn points and help others
