Question about Bosch Axxis WTA 3510 Electric Dryer
Bosch Dryer misfunction
My Bosch Axxis WTA 3510 is not working. The "start" button does not depress sufficiently for the machine to start, although the "on/off" button will light. The "open" button seems to work. I have cleaned out the lint catcher. Any advice?
  • 130 Answers
Check the fuse. This is a German unit, so every part including the light bulb is 208/240 volts. If the fuse for the dryer on the back is open the unit will not start.
Posted on Jan 06, 2008
All the lights come on but the dryer does not start
There is a resetable fuse inside the dryer but your going to have to remove the back of the machine to get to it if I remember correctly
May 27, 2012 | Bosch Axxis WTA 3510 Electric Dryer
Hello, I have a Bosch Axxis electric dryer that when i turn it on and hit the start button the light comes on telling me that the unit has started but it is not spinning. Also there is not any heat being...
Hi, Welcome to FixYa. If you turn the drum by hand do you feel any airflow out the back ? (you need to undo the vent hose too) This will tell you if the belt is broke. Let me know and we can go forward from there. Regards, Macmarkus :)
Mar 21, 2011 | Bosch Axxis WTA 3510 Electric Dryer
Bosch AXXIS dryer # WTA 3510 uc slipping / grinding sound when drum reverses direction. Difficult to turn drum by hand. Belt or motor?
drum baring or rollers if you can get belt off try to turn drum if it still hard to turn you will know its not the motor may be something in blower give it a try
Sep 30, 2010 | Bosch Axxis WTA 3510 Electric Dryer
Everything on the dryer indicates that it is working but nothing happens when I push start
The push start button may be gone. U have to get to the wires to bypass the botton to know for sure if this is your problem......Hope this helps.
Aug 12, 2010 | Bosch Axxis WTA 3510 Electric Dryer
Bosch Axxis WTA 3510 Electric Dryer. I changed the fuse but it won't turn. Could it be the motor because I don't hear any sound?
there is a switch next to the belt tension arm behind the motor that needs to be reset push the switch needs to be pushed to the right andthis should get your unit running as long as you have power
Sep 16, 2009 | Bosch Axxis WTA 3510 Electric Dryer
Bosch wta3510us tumbling NOT heating. Reset button?
Remove your back cover ,and then you see the heating element.On one side or on top there is a termostat(Small Black)there is a red button which you should press down until you hear a click.Start machine and element should work.You can start it for a little while but be careful.Put cover back after cleaning loose lint etc. Jan
Jan 09, 2009 | Bosch Axxis WTA 3510 Electric Dryer
Asko stackable dryer/Bosch stackable washer compatability
If you arer going to replace the washer with a Bosch Axxis model, it will simply plug into the back of the dryer (if it is electric) because normally the dryers are 220 VAC. Works A-OK.
Nov 23, 2008 | Bosch Axxis WTA 3510 Electric Dryer
Service Manual
Based likewise on your Premium Problem/Post here, I tried looking for a service manual but only found a possible source of the wiring diagram, have you tried here. Unfortunately, you need to be a paid member to access the files to my understanding.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Jun 25, 2008 | Bosch Axxis WTA 3510 Electric Dryer
Bosch Axxis WTA 3510 Electric Dryer Logo
574 people viewed this question
Top Bosch Dryers Experts
Lawrence Oravetz
Are you a Bosch Dryer Expert? Answer questions, earn points and help others
