Question about Stanley Bostitch 18 Gauge Brad Nailer 1 - 1/4IN - BT125K - 2
Bostich angle trim nailer sometimes the ram or nailer will not go back up and I have to open it and manually put it back up with screw driver
  • 142 Answers
Sounds dirty to me...open the nose and spray WD40 in and around the nose, as well as the track....also, check if that model needs oil, because that can also cause the problem. All in all, it is a lubrication issue
Posted on Jul 16, 2009
Bostich bt200k brad nailer: how difficult to replace driver?
If it is a real expensive brand of driver I would try and fix it. However, I have learned as a contractor that sometimes you can save money
in the long run by simply buying a replacement. The price has dropped quite a bit.
Jan 05, 2013 | Air Tools & Compressors
Bostich coil framing nailer will not advance the next nail
Bad or dry feed piston o-ring or a loose feed piston as they are held on by a metric allen screw that will sometimes back out. Use blue Locktite when reinstalling the screw. It could also be the feed spring but they rarely fail on the larger framing nailer.
May 14, 2012 | Stanley Air Tools & Compressors
Just had gun rebuild by bostich my m111fs flooring gun drives the staple to far into flooring and the piston sticks in wood as well. nate
Most likely the piston (#15) has partially unthreaded from the piston stem (#17) - this requires a complete teardown to rectify. Sometimes it is simply because use has caused it to loosen - it can also be because the piston has stripped.
Also check your bumper - if it is worn, or in pieces the driver will overdrive.
Sep 11, 2010 | Stanley Bostitch MIIIFN Flooring Nailers
WHEN I DRIVE A CLEAT INTO THE FEMALE GROOVE OF THE T&G IT STOPS SHORT OF DRIVING IT ALL THE WAY SO THE NEXT PIECE FITS SMOOTHLY. CAN U ADJUST THE DEPTH OF THE STAPLE? THIS IS USING THE BOSTICH MANUAL...
I assume you are hitting the driver square and hard. You can't baby a floor nailer. If hitting the driver is not the problem, the driver that contacts the nail could be chipped or broken. It's not unusual, especially if you've used it on hickory or maple. Compare it to a new one to see if that's the problem.
Nov 04, 2009 | Stanley Bostitch MIIIFN Flooring Nailers
Paslode 16 gauge cordless angled finish nailer was dropped and the wire probe on the front was bent. I need to remove the probe for repair. I have removed all visible screws, but something seems to still...
Put all screws back. I had to get mine as sraight as possiable too because i bent mine.Just use pliers if all else fails go to pasilode.com.
jj505 please rate
Apr 08, 2009 | Tools & Hardware - Others
Porter/Cable 15 gauge angle finish nailer
The driver assembly can sometimes get bent or the tip can get a little deformed causing it to hang up in the nose. Other than that, not much else it could be if you rebuilt the whole thing
Dec 31, 2008 | Porter Cable 16 - Gauge Finish Brad Nailer...
Bostich gun problem
If the piston/driver is broken, the gun will fire however nailing will not take place because the piston will jam in the cylinder. Sometimes the cylinder will also crack when the driver goes. If the piston is not broken but stays down, then check the cylinder check valve, worn lower bumper, bent driver or cracked cylinder. 18 guage nailer has a very thin driver which will easily bend or break. Parts however are not expensive.
Nov 18, 2008 | Stanley Bostitch 18 Gauge Brad Nailer 1 -...
Stanley Bostitch 18 Gauge Brad Nailer 1 - 1/4IN - BT125K - 2 Logo
139 people viewed this question
Top Stanley Tools & Hardware - Others Experts
John Trevino
yoopertech
Are you a Stanley Tool and Hardware - Other Expert? Answer questions, earn points and help others
