Question about Garmin ETREXVISTA GPS Receiver
ETrex Vista shows incorrect date
About 5 weeks ago, I purchased a Garmin eTrex Vista. Within a couple of days, I had to return it because it started showing the wrong date – out by many years. In all other respects, the unit seemed to be working fine (acquired a satellite fix quickly, compass and barometer work OK, etc).
The unit was replaced with a new Vista unit, which was working fine – until today! Now my new replacement unit is showing exactly the same symptoms. Today (17 November 2007) it is showing the date on the Main menu screen as 02-Oct-66. (There is nothing I can see which shows whether this is 1966 or 2066, but either way, the date is wrong.) It shows the correct time of day, however, and manages to get a satellite fix quickly, even though it appears to believe that it is living 59 years in the future (or possibly 41 years in the past.) I have checked that I am running the latest system firmware (version 3.70), and have tried a full hard reset, changed the batteries, etc, but nothing I have tried will correct the date problem.
This makes the unit all but useless for me, as the downloaded track-logs show corrupt time and date stamps. One major consequence of this is that I can’t use the track-logs to geo-reference my digital photographs from my remote site trips, which is one of the main reasons I bought this unit. The downloaded track-log files show the dates for the latest track-log points as being 24-Aug-30 to 27-Aug-30, whereas the Vista Main screen is currently showing the date as 02-Oct-66!
Another critical issue is that I can’t download track-logs into MapSouce – the MapSource software attempts to download the current track from the unit, but then at the end of the download seems to recognise that the data is corrupt, and rejects the whole track-log.
I have contacted Garmin Tech Support and the local reseller for advice, so far without success. Is there a known PERMANENT fix for this problem?
Re: eTrex Vista shows incorrect date
Thanks for the great advice. My problem is fixed!! Yay!
Posted on May 07, 2008
0 characters
3 Points
My eTrex Legend cx beeps constantly when turning off. The only solution I have found is to remove a battery. Any ideas?
I have the same problem. The unit is only 1 week old and I have used it maybe 5 times. The problem started a couple of days ago when I removed the USB connection from my Mac without ejecting it first. I think this might have screwed up the microSD card. I noticed that if I remove the microSD card the unit turns on and off normally. but is I have the microSD inserted, it turns on oK, works (apparnetly) Ok, but freezes with a constant beep when I turn it off.
Will try to reformat the card (any idea how to do that on the unit itself?)
Aug 18, 2009 | Garmin eTrex Legend Cx GPS Receiver
My GPS won't stay on
I can solve this by not solving it. First I tried reset the unit to default settings: hold down the power, page, and enter buttons at the same time, a message, "do you really wan to reset..." will appear. Select "yes." If the unit reboots, hurrah. If not, call tech support (1.800.800.1020). Get an RMA, send it back to them for repair. I had purchased mine over 30 days ago but less than 60: Amazon wouldn't replace it, Garmin will either replace or repair. If you want them to send a new unit while the old is in transit, just ask; they will charge and then credit a card once they have the old unit is in hand. Good luck.
Apr 25, 2009 | Garmin eTrex Venture HC GPS Receiver
No change time
You will need to backup all of your tracks, waypoints and routes to your PC. With the unit off, hold down the page, enter (joystick), and find buttons for 5 to 7 seconds while power up at the same time. Then go outside and let the unit get a fix on the satellites. This will fix the date problem. Once done go to the main menu and select setup and the system. Make sure WAAS is disabled. If you enable this option the date will get messed up again and you will have to do this all over. There was supposed to be a firmware upgrade that fixed this problem, however I found after flashing the firmware update, the date problem still occurs if WAAS is enabled.span.jajahWrapper { font-size:1em; color:#B11196; text-decoration:underline; } a.jajahLink { color:#000000; text-decoration:none; } span.jajahInLink:hover { background-color:#B11196; }
Apr 22, 2009 | Garmin eTrex Vista GPS Receiver
Garmin eTrex Vista Cx won't turn on
Call Garmin customer service, they are wonderful. My rubber thing around the outside became loose,and they sent me a new unit, even though it was almost 2 years old.
Apr 11, 2009 | Garmin eTrex Vista Cx GPS Receiver
BlueChart MicroSD map will not display
Get program MapUpload from after that go to Piratebay find Bluechart Atlantic 9.5 torrent.Mout it to Mapsource and with help of MapUpload send it to sd card
Apr 01, 2008 | Garmin eTrex Vista GPS Receiver
Garmin Etrex display problem
Have you updated your Garmin unit software recently?
Mar 21, 2008 | Garmin eTrex GPS Receiver
Wrong elevation showing garmin etrex vista
Found a fix, by resetting all user data my problem was fixed.
Garmin Edge 305 Power off device and hold 'mode + power'
eTrex Vista Power off device and then hold 'page + enter + power'
Hope this helps!
Dec 16, 2007 | GPS Devices
Garmin Etrex Vista Date problem
Thanks to a hint from a user on another web forum, I have found a fix, at least for now.
Specifically, a normal "master rest" on the eTrex Vista is accomplished by holding down the "Page" button and "Enter" (i.e. the click stick) while powering up. You are prompted that a full reset will occur, and after confirming, the machine is reset. However, in my case, this achieved a full reset, but did not fix the date problem.
However, the undocumented "super master reset" on the eTrex Vista is achieved by simultaneously holding down the "Page, "Enter" and "Find" buttons while powering up. You have to hold all buttons in for about 5 to 7 seconds, and you DON'T get the warning message, but when the machine finally restarts, it is fully reset. After acquiring a satellite fix (took several minutes) - lo and behold - my time AND date both seem to be correct!
Oddly, neither Garmin tech support nor the local reseller seemed to know about this method of REALLY resetting the machine - I will pass on the information to them, for future reference.
The link which documents the "super master reset" procedure is here:
Hope this might also help other eTrex Vista owners who are experiencing the same date problem.
Nov 17, 2007 | Garmin eTrex Vista GPS Receiver
Garmin eTrex Legend
Do the following: 1 - Make sure you have fresh batteries in the unit and turn the unit on. 2 - Check the GPS date and Time. On the Main Menu at the bottom of the screen, you can see a date and time. If the date and time are not current, then the clock is your problem. You will have to wait for the almanac information to be updated. Details are below in a later section. 3 - Make sure your GPS is in the Normal Mode and not a demo mode. Verify other systems settings. Go to the main menu and click on Setup icon. From the Setup screen, access the System screen icon. Verify the following settings: GPS: normal WAAS: Enabled Language: English or your choice. Battery: Set according to your battery types. 4 - Check your GPSs Version Software. Go to the main menu and click on Setup icon. From the Setup screen, access the System screen icon. From the System screen, access the sub-menu icon in the upper right bar. Select "Software Version" from the list. Verify the actual software version for me. The latest version available for the eTrex Legend is version 3.90 dated March 2008. Update the unit using this latest software and using Garmin's Webupdater. If that won't work, use the following download page to access the latest software updates per units. 5 - Resetting your GPS clock and almanac information Next you may need to acclimate your unit to a new date and time (almanac information). If you had your unit off and without batteries for over a month since you last accessed satellites, then your clock and almanac information may be incorrect. Even Garmin acknowledges this problem after software updates and the problem with accessing satellites. They state: "unit data including alamanac information may be incorrect or cleared. Back up all user data before upgrading. After installation is complete, place unit with a clear view of the sky for 15-30 minutes to re-acquire almanac data. " I know of no way to reset the clock using the GPS menus. All I can suggest is that you do the following: A - turn the unit on and wait 5 minutes or so for the "Poor Satellite Reception" screen to appear. See page 7 of the owner's manual. B - Set the "new location" to your area using the map when the "poor satellite reception screen" appears. Be sure to use the "map" option and not the "automatic". C - Set the GPS outside with a clear view of the sky. Check on it every 10 minutes. When the "Poor Satellite Reception" screen appears again, then click on "Restart Search". The "Restart Search" option is used when the date provided in the GPS is not today's date. (See page 7 of the Owner's manual for an example) Legend Owners Manual: D - Once the GPS can track 4 satellites, then the clock should reset and you should be fine. This process could take up to an hour. I have had this problem with my eTrex Vista and eTrex Legend (both backup GPSs) and resolved it by having the clock reset. In fact, I just tried my eTrex Legend today after not using it for many months and storing it without batteries and it had this same problem. I followed the steps above to fix the problem. This took about 35 minutes.
Mar 28, 2007 | Garmin eTrex Legend GPS Receiver
GPS Devices Logo
1,681 people viewed this question
Top Garmin GPS Devices Experts
Tom Chichester
Jonathon summesfield
Bill Gilhooly
Bill Gilhooly
Are you a Garmin GPS Device Expert? Answer questions, earn points and help others
