Question about Brother IntelliFAX 2800 Laser Fax
Just replaced toner - now it prints so dark I can't even read the fax
  • 183 Answers
Most common cause is a dirty corona wire and or drum. If after cleaning the corona wire and drum the copies are still mostly black and smeared, the drum may be broken.
Posted on Jul 16, 2009
5 Suggested Answers
blkghost
  • 46 Answers
SOURCE: Toner Cartridge reading has empty but have replaced toner
Try to see in the software if there is any reset option for the toner.
Posted on Nov 08, 2007
ronaldsuboc
  • 449 Answers
SOURCE: Toner prints to dark
hi!!!!!
try to re-install the driver of your printer!!!
or try to figureout the settings of your printer
Posted on Oct 29, 2008
greg_margo
  • 1959 Answers
SOURCE: Sent faxes not printing clear
Per Brother's User manual,
http://www.brother-usa.com/ModelDocuments/Consumer/Users%20Manual/UM_IntelliFax_4100_4750e_5750e_EN_98.PDF
Clean the machine’s interior and the primary
corona wire of the toner cartridge This is a common cause for your printing/copying problem. This should solve your issue. Best of luck.
Greg
Posted on May 20, 2009
FixinFax
  • 3085 Answers
SOURCE: Toner Life has ended
Did you pull the plastic tape on the cartridge?
Posted on Feb 11, 2010
Printed pages look terrible...
I'm more familiar with HP printers, but it sounds like a fuser is bad. The fuser effects print quality as well. If you've replaced the toner, as you have.
Apr 24, 2009 | Sharp FO 5550 Plain Paper Laser Fax
Fax is received is very dark and almost unreadable
You can try using the menu to lighten the fax, but if all received faxes are dark, you may be experiencing a weak scan light. try making a copy instead of fax (which essentially is a fax printed to yourself) if also dark, its certainly your scanning imager that's failing. If that's the case I would recommend replacing the entire machine. Parts are expensive, and its a difficult to service part yourself. Also you may find that toner costs alone may pay for the replacement machine over this unit.
-Good Luck!
-FW
Jan 05, 2009 | Sharp Office Equipment & Supplies
Fax prints to dark
have you replaced the drum??? are you using brother oem toner???? generic toner will give you all kinds of problems
Oct 29, 2008 | Brother IntelliFAX 2800 Laser Fax
hi!!!!!
Print in light
1. Check TONER SAVE setting. If this setting is programmed "ON", all
printed documents will be light.
a. Press MENU/SET, 1 (General Setup), then 6 (Toner Save).
b. Press the top or bottom navigation key (keys located above and below
the MENU/SET key) until the display reads "Toner Save: OFF".
c. Press MENU/SET.
d. Press STOP/EXIT.
2. Check the PRINT DENSITY setting. This setting allows you to adjust
the print density from light to dark.
a. Press MENU/SET, 2 (Fax), 1 (Setup Receive), then 6 (Print Density).
b. Press the up navigation key (key above MENU/SET) to make print
darkeror the down navigation key (key below MENU/SET) to make print
lighter.
c. Press MENU/SET.
d. Press STOP/EXIT.
Oct 15, 2008 | Brother IntelliFAX 2800 Laser Fax
Very poor printing
If the prints are light or have white lines it will be related to the laser unit. There is a strip of glass that sits above the drum inside the machine. Clean it. If there is toner on it will cause this problem. Otherwise the laser unit has failed.
If you have dark marks, blotches or reprinting (part of the image repeating lighter down the page). It will be build up on the fuser rollers. Remove the drum/toner and look at the rollers behind, they will look dirty. The only way to resolve this is to replace the fuser unit as it is worn out.
The only other possibility is that the drum contact on the sides of the machine are deformed or out of position. Its hard to tell and fairly unlikely in this model.
Apr 17, 2008 | Brother IntelliFax-2820 Laser Fax
"Toner Low" message = no faxes :(
Need to do a hard reset. Contact Dell for instructions, but it will involve turning printer off, opening front cover, pushing buttons on front panel in certain sequence, etc. Each model differs, which is why you should call Dell.
Mar 20, 2008 | Dell 1600n All-In-One Laser Printer
Fax confirmations printing dark
change the toner cartridge , if it doesn't solved your probleme then it is probably that you have a defective Laser/scanner ( turning on laser continuously )
Jan 09, 2008 | HP LaserJet 3330MFP All-In-One Printer
Ricoh FAX2900L printing too dark
check the scanner white roller witch is under the front cover where you feed in the paper to be scanned sometimes this gets dirty you can take it out by releasing the levers on each side..this also sets the density for copying.. if you have just put a newe cartridge in also check that it is seated properly as the contacts for the charge might not be connecting properly
Nov 08, 2007 | Ricoh FAX2900L Plain Paper Laser
Brother IntelliFAX 2800 Laser Fax Logo
291 people viewed this question
CheckitRight
CheckitRight
James Cagle
James Cagle
Samyfam
Samyfam
