Question about Sony XM-475GSX Car Audio Amplifier
Power acoustiks amp wont get off protection mode? how do i reset it? please help me i tried everything.
  • 655 Answers
Hello nfox1987,
First you need to determine if the amp is defective or if something else is causing it to go into protection, most often a short in the sub or amp wiring.
Disconnect the sub(s) from the speaker output terminals and the RCA inputs from the head unit, and test if the amp powers up OK. If it does, the problem is in the sub(s) wiring or voice coils, or in the RCA inputs to the amp. Reconnect each one-at-a-time to determine exactly where the short is and repair or replace the defective wiring or unit. If it doesn't power up with the inputs and sub(s) disconnected, the amp itself is most likely defective.
Hope this helps.
Posted on Jul 16, 2009
How do i fix my Power Acoustik LT-980/2 car amp, it keeps on going into protect mode.
Disconnect all speaker connections and rca cables. Leave power, ground and remote wires intact. Try turning on again. If you still have a protection light your amp is faulty. Hopefully you have warranty . .A thumbs up would be greatly appreciated if this answer is helpful to you
Aug 10, 2011 | Power Acoustik LT-980/2 Car Audio...
I have a power acoustik ibm12000d amp had it installed to weeks ago wired at one ohm to a 15inch acoustik p3 sub worked good for to weeks hit good and everything but now its cutting off when turned up I...
Sounds like an over current condition. Your sub may be the problem. Does it go into protect mode when it cuts out? remove the sub and turn up the volume and see if it cuts out when you keep increasing the volume. If not, then it may be that the sub shorts out when turned up too much, kicking the amp into protect mode. If it still cuts out, then it may be the amp. Try another sub if you have one or borrow one from a friend.
Aug 06, 2011 | Power Acoustik OVN1-2000D 1-Channel Car...
Amp pulses from power to protect
check it without the speakers if they go to protection,and if not check the speakers
May 27, 2010 | Power Acoustik PS4-800 Car Audio Amplifier
Its in protection mode and i have no idea why....i checked the fuses...the terminals and everything....need help please
yes you have a internal fault of the amp. the circuit that puts it into safe mode is bad and that is a very small chip on the board know as a op amp. needs to be repaired.
Feb 02, 2010 | Power Acoustik OVN1-4000D Car Amp
My amp goes in protect mode
Maybe the audio amplifier IC´s are damaged
Feb 06, 2009 | Power Acoustik GOTHIC OV2-1200 Car Audio...
POWER ACOUSTIK - A1800DB how to fix protection mode
If I don't ask the stupid questions first, I always get burned! Have you tried removing both the +12V and remote connections from the amp and letting it sit for a few minutes? If the amp doesn't automatically reset (and you have removed the condition that caused it in the first place), your amp may need repair, as it might have shorted something internally.
Mar 11, 2008 | Power Acoustik A1800DB Car Audio Amplifier
Protection Mode? amp wont start
With your multimeter set to DC volts and the black meter lead on the ground terminal of the amp, touch the red lead alternately to the B+ and remote terminals as the amp shuts down. If the voltage drops below ~11 volts, you need to check the wiring feeding whichever line is dropping too low.
If the voltage remains near or above 12v, disconnect all speaker wires and signal cables from the amp. If it powers up, the wiring needs to be checked. If it still shuts down, the amp likely has blown output transistors.
Nov 29, 2007 | Power Acoustik LT960 Car Audio Amplifier
Protection light on
i had one of these amps, if you don't have a good ground, the protection light will come on.
May 09, 2007 | Power Acoustik TS1440-2 Car Audio...
Power Acoustik TS620-2 Amplifier
Check the wiring at the speakers themselves. It's possible that while you were moving the box one of the speaker wires came loose and shorted against the other terminal. A shorted speaker wire or damaged speaker will cause the amplifier to go into protect mode. If you have a digital multimeter with a resistance feature, you can test the resistance between the positive and negative terminals for each speaker.
Feb 26, 2007 | Power Acoustik TS620-2 Car Audio Amplifier
Sony XM-475GSX Car Audio Amplifier Logo
285 people viewed this question
Top Sony Car Audio & Video Experts
xxxxxx xxx
Larry Stiles
Larry Stiles
Philip Rowney
Philip Rowney
Are you a Sony Car Audio and Video Expert? Answer questions, earn points and help others
