Need a new gears for a PL-710SH paper shredder. One of the plastic gears between the motor and the shredder drums has broken up. Probably overloaded it with paper at one point. Is there a place to buy gears for items like this?
  • 328 Answers
Call Fellowes direct. 800-553-1155
Posted on Jul 22, 2009
Paper jam
Does it sound like the motor is spinning? or does it sound like the motor is bound up? I ask because if it sounds like the motor is spinning, then chances are good you stripped a plastic gear somewhere in the drive system that feeds the steel shredder. I just pulled apart one of these and saw that the motor has a steel gear on it. that steel motor gear meets with a plastic gear, and then the plastic gear meets with steel gears attached to, and which spin the shredder. So if you ever bind the shredder with too much paper, the steel motor gear will grind the teeth right off the plastic gear and it won't spin anymore. If your motor sounds like it's bound, then the good news is that the gears aren't stripped. You'll have to take the shredder apart so you can remove the paper causing the problem. Of course unplug it first before opening it up. They are not overly complex but just remember where the screws goes so you put them back in the right holes.
Sep 01, 2014 | Office Equipment & Supplies
DX-PS10MC gear broken
Might have to go to eBay or Gumtree.
Mar 05, 2014 | Dynex - 10-Sheet Microcut Paper Shredder
The shredder developed a jam. I removed the bin and the top of the shredder. I removed the shredding mech. and removed the paper material. Reassembled the shredder. Shredder starts up when paper is...
Does the motor run??? even in reverse???
If the motor doeas not run at all it probably PCB. If the motor does run but the cutting mechanism does not turn then you probably have stripped/broken plastic gears... open and check,...contact Royal at 1-800-524-0799 for parts assistance.
Oct 27, 2010 | Royal VF880 Shredder
Runs continuous when turned on, but stops when paper is inserted
I owe this to a Steve-EE.
Mine was the LED where the paper feeds. $1.69 for a 2 pack.
http://www.radioshack.com/product/index.jsp?productId=3107633
May 09, 2010 | Staples SPL1050LBRX (CrossCut) Shredder
Staples spl-710sh paper shredder stopped shredding
This exact thing has happened to my unit as well. Ive disassembled it to discover that 5-7 teeth on the gear that the motor drives have been stripped off. Unless the gear can be replaced (which is probably not worth the expense), then the unit is toast. Sorry. Good luck.
Jun 16, 2009 | Office Equipment & Supplies
Replacement plastic gear for a Royal 150MX shredder
For parts call Royal at 1-800-524-0799; they should be able to help.
Don't forget to lubricate the cutting shafts on x-cut shredders.
Apr 02, 2009 | Royal 150MX Cross-Cut Shredder
Paper stuck in the Fellows Paper Shredder
  1. Remove Shredder from paper catcher bin
  2. Remove shredder cover from shredding mechanism assemble (approx. 6 screws on bottom of cover)
  3. Separate shredding mechanism from bottom cover (may have disconnect circuit board from assembly and other wiring from switches , sensors, etc,)
  4. Remove motor gear cover (approx. 4 screws)
  5. Separate shedder main drive gear from motor step up gear by pulling gear out
  6. Turn shredder mechanism up side down to access the cutting blades
  7. Use an adjustable wrench to turn the main drive gear to see stuck paper
  8. Use a needle noise pliers to remove paper shreds
  9. Repeat step 7 and 8 until all shreds are remove and cutting mechanism move smoothly
  10. Reassembly before testing shredder
  11. If you remove only some of the shreds, the motor may seize up and strip the plastic gears from step up gear.
Feb 09, 2009 | Fellowes DM8C Cross-Cut Shredder
Paper Shredder blades do not turn, even though motor is running
yes, it's the plastic gear that's shredded in this shredder. the drive gear on the motor is metal, as are the gears attached to blades. between is a single plastic gear which is chewed up the instant resistance is great enough. fabulous engineering. not a difficult fix, but where does one find the replacement part?
Jun 08, 2008 | Office Equipment & Supplies
Order main drive gear for geha paper shredder
This is how a got my hard to fine gear!
Contact Michael Business Machines for your local dealer 1-800-223-2508
Good luck, Tom
Feb 18, 2008 | Geha Primo 2600 Shredder
380 people viewed this question
k24674
