Question about LG L196WTQ Monitor
LG Monitor L196WTQ-BF ..weird image stuck on desktop??
Hello: hope you can advise on what the problem might. i have this L196WTQ-BF monitor that worked great...until I moved. i suspect that someone may have dropped in during the move; reasong being..there is an image stuck on the desktop that i can't get rid of. it looks like it might be an image of a broken window or something, at first i thought it was some kind of weird spider, lol. but now i think it is supposed to represent a broken monitor, like a rock through a window : ( i know i probably sound as though i'm stoned, lol. but no, i'm not ; ) any advice would be greatfully appreciated. thanks!
  • 2,229 Answers
The "image" you are talking about: Is it there when the monitor is off? If so, you are correct--it's broken and must be replaced.
Is it on the desktop when you start the computer and does it stay there no matter what program you are running. If the answer is "yes" then I'm afraid the answer is the same.
Posted on Jul 16, 2009
Lg 1752s goes into power saving mode when pc is turned on
Hello Alan,
That is actually not power saving mode, the flashing power light indicates the power supply is not starting up correctly and keeps shutting down and trying again. This is a very common symptom of a failure of the capacitors on the power supply board. The L1752s uses the AIP0157 power supply board which is the same board the is used in several LG monitors such as the L196WTQ and L194WT. Here is a link to a repair guide for the L196WTQ that shows what capacitors to look for and replace on the power supply board to bring the unit back to life.
http://www.ccl-la.com/blog/index.php/lg-l196wtq-bf-lcd-monitor-repair/
I hope this helps, if so please rate my solution.
BuddyMc
May 15, 2012 | LG L1915S 19" LCD Monitor
How to open a lg monitor 196wtq
Here is a link to a dis-assembly and repair guide that should get you going.
BuddyMc
Feb 14, 2012 | LG Computers & Internet
My L194WT -SF WONT WORK NO POWER USED SAME POWER LEAD ON DIFFERENT MONITOR NO PROBLEM
Hello Steve,
The most common problem with the L194WT monitors is a failure of the power supply board. There are parts called capacitors that fail and can cause the issue you have. Sometimes the power light will just flash, sometimes it takes several minutes to display a picture or even a wavy picture, all of these issues indicate a failing power supply board. These boards can be repaired if you can do a little soldering. The L194WT uses the same power board as the L196WTQ and we have a step by step repair guide with dis-assembly instructions available at http://www.ccl-la.com/blog/index.php/lg-l196wtq-bf-lcd-monitor-repair/ Look over the guide and check your board to see if your capacitors have bulged and need to be replaced.
I hope this helps, if so please rate our solution.
BuddyMc
Aug 07, 2011 | LG L194WT 19" LCD Monitor
How do i dismantle L192WS LG monitor ? please help
We have a full disassembly and repair guide for this model monitor posted on our site at:
BuddyMc
Jan 01, 2011 | LG L196WTQ-BF 19" Monitor
My monitor, Flatron L196WTQ-BF, just quit working one day. I have tried to get it to work, checking power, moving to different computers, etc, but it won't light up at all. The on/off switch remains dark...
It sounds like you have a failure in the power supply board. We have a free repair guide posted on our site at: http://www.ccl-la.com/blog/index.php/lg-l196wtq-bf-lcd-monitor-repair/ that should get you back going again. The guide shows you how to remove the case and what to look for to identify the problem. Look it over and see.
CCL_Tech
Corporate Computer
www.ccl-la.com
Sep 04, 2010 | LG L196WTQ Monitor
MY LG L194WT Was working turned it off and will not come back on. Should I have it repaired or toss it?
For a 3 years old monitor, first place to check will be bad caps in the power supply, open it up and post back so we can guide you further, see example of failed monitors due to bad caps: http://s807.photobucket.com/home/budm/allalbums
Feb 15, 2010 | Computers & Internet
LG L196WTQ monitor just quit working. won't turn
Look in the power supply section first for bad caps, post back what you find inside, pictures will help a lot to guide you through, see example of failed monitors due to bad caps: http://s807.photobucket.com/home/budm/allalbums
Jan 24, 2010 | LG L196WTQ Monitor
LG Flatron L196WTQ-BF Monitor will not power on
Here is a link to a How To on this monitor (and similar) they offer cheap parts as well.
http://www.ccl-la.com/blog/index.php/lg-l196wtq-bf-lcd-monitor-repair/comment-page-1/#comment-136
Nov 12, 2009 | Computers & Internet
My 194wt worked great for 3 years, now it wont turn on at all. is this the normal life of this monitor ? how can i fix this ?? ive confirmed 120v at power inlet and some dc voltage on various mini pins on...
Same problem as above. Had mine for 2.5 years and worked fine until I tried to turn it on this morning - won't come on at all. I have tried another power cable and verified that another monitor works on the old one.
Oct 03, 2009 | LG L1915S 19" LCD Monitor
My LG L196wtq-BF went black this morning. No light on the power switch. How do I get the back off the monitor?
We have some dis-assembly guides on our web site at: www.ccl-la.com/badcaps.htm There are not for your exact model but they should help.
Buddy
Corporate Computer
www.ccl-la.com
Aug 31, 2009 | LG L196WTQ-BF 19" Monitor
LG L196WTQ Monitor Logo
203 people viewed this question
Top LG Computers & Internet Experts
Michael Vincent Cruz
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
