Question about Cycling
I want to replace the handlebars on my new schwinn, but there seems to be a small plastic plate in the way of the loosening nut. ideas?
    President:
  • 1,137 Answers
If your replacing the stem also, you can gently pry around the edges of the plastic to remove it. It is a plug that fits down into the stem.
Posted on Jul 17, 2009
Adjust handlebar height on Schwinn Varsity
I'm answering 7 years later. I have a Schwinn Varsity 2500 Bike made probably in 2015. The Schwinn Varsity Bike is not set up the same way as a traditional bike. I loosened the center compression bolt and the two side stem clamp bolts and it came loose where I can adjust it up or down but, there's nothing to tighten the slack up below. I did some research. My original post here was to add or remove a spacer. I think you can remove a spacer to lower but, I don't think the stem is long enough to add another one. I've seen they sell an extension that you can add-on to make the handle bars higher.
Jun 25, 2012 | Schwinn Cycling
Tip
How to replace a chain with master link on a Schwinn Airdyne
Airdyne Chain Replacement with Master link
This video will demonstrate how to replace the chain with master link on a Schwinn Airdyne.
  • First remove the cotter pin and clevis pin from the user's right handlebar. Then lower the connecting arm and handlebar.
Caution: be sure to hold the handlebar as it will come loose after removal of the above parts.
  • Remove the connecting arm and pedal and crank arm by removing the wedge pin. To simplify this process loosen the nut and tap on it with a small hammer until the pin is loosened.
  • Remove the nut, wedge pin, crank arm and connecting arm.
  • Next remove the chain guard; there are three screws attaching it as shown in the video.
  • Remove the chain by locating the master link. Remove the lock pin and the cover, and then disconnect the chain.
  • Place the new chain on the sprockets as shown in the video.
  • Install the master link, cover and lock.
  • Re-install the chain guard and attaching screws.
  • Re-assemble the connecting arm to the handlebar and eccentric.
  • Be sure the brass bushing is installed in the front inner side of the connecting arm before installing the clevis pin and cotter pin.
  • Install the crank arm with pedal.
Be sure when completing this step that the crank arm is installed in the opposite position as the users left side crank arm.
  • Install the nut onto the wedge pin and tighten.
  • This completes the procedure.
Replacing Schwinn Airdyne Chain with Master Link
on May 23, 2016 | Schwinn Airdyne Exercise Bike
Adjusting the angle of the handlebars on a schwinn avenue
I have a mens schwinn fifth avenue, and it has threadless handlebars. I wanted to adjust the angle and found a nut that adjusts it that is on the front of the neck that is angled so its pointed towards the tire, hooray ,,because those two that are at the angle position on the bars dont work foe that purpose or any really, just there to frustrate you.
Mar 12, 2012 | Schwinn Cycling
I need help with raiseing and tighting the handlebars on a schwinn skyliner!!
there is either a bolt or a hex key nut there that you turn counterclockwise to loosen the bolt holding the post to the body, adjust to the height you wish, the return the bolt/nut to the point it stops not over-tightening the bolt.
Any other questions, please ask, happy to help
Rate on assistance please
Joe
Aug 31, 2011 | Cycling
How do I raise the front handle bars on my Schwinn Jaguar?
On most bikes (Jaguar is a broad category, with varying details) there are two bolts in the middle of the handlebars. One bolt squeezes a clamp around the middle of the handlebars. If you loosen that one, you can tip your handlebars up or down. You can usually see this entire short bolt and it's nut (actually you would loosen the nut.) The other bolt is the one you want. On this other bolt, only the head of the bolt is visible. This is actually a long bolt that extends down into the the handlebar stem. The nut is down inside the stem, and it wedge-shaped so that it jams the stem tight inside the tube that houses it. Loosen this bolt about two turns, but do not remove it. Just give it a tap with a hammer, to free the wedging of the nut. You will now be able to pull the handle-bar stem up. It will probably still be snug, so you will have to twist it back and forth to pull it up. Pull the stem all of the way out and take a look at it. There will be a line on the stem that tells you the maximum safe height to which you can raise it. Re-insert the stem at least far enough to hide that line. If this is not high enough, you can buy a longer stem to replace it. Good luck, Al K
Feb 03, 2011 | Schwinn Men's 26" Jaguar Cruiser Bike
In putting together my 26"
Loosen both nuts on front wheel.
Stand bike straight up, or set bike upside down on seat and handlebars.
With fingers on fork and thumb on wheel, pull wheel so it is centered on fork.
Now tighten one nut part way. Keep holding wheel.
You may need somebody to help.
Then tighten other nut.
Go back to fist nut and tighten a bit more.
Repeat back and forth tightening until nuts are tight and wheel is in center of fork.
Dec 25, 2010 | Schwinn Men's 26" Jaguar Cruiser Bike
Schwinn Impact MOS.....can the handle bars be raised? If so, do you loosen the small star nut on top, or the large nut at the base of the handle bars?
In order to raise the handle bars, you will need a hex key. Put it into the hex indentation at the top. Turn it left to loosen it. Then raise the handle bars to the desired height.
May 22, 2010 | Cycling
Trying to raise handle bars on roadmaster xtreme hype.trying losing 2 big nuts on top section of the fork. doesn't seem to do anything. tried losing the allen type bolt at the top the fork but it only...
You loosen the nut that you see where the handlebars enter the front tube on the frame. Pull up a bit after loosening and then be sure to tighten the nut back when you get it where you want it.
Jul 05, 2009 | Schwinn Mesa Gs Mountain Bike
How do i adjust the handle bars to go higher?
there is a nut on the lower part of the hadel bars you loosen that up then rais handel bars.
Jul 02, 2009 | Schwinn Meridian Adult 26-Inch 3-Wheel...
Cycling Logo
Top Cycling Experts
John Egan
John Egan
Are you a Cycling Expert? Answer questions, earn points and help others
