Question about RTO Automatic Transmission And Engine Oil Pressure Tester
I bought a 95 e320 benz with no radiator
And the trani fluid dipstick was bone try i put 3 quatrs of fluid in it now it doesnt reverse should I add more or is the transmission bad
    Sergeant:
  • 384 Answers
Transmission is bad.
Posted on Jul 16, 2009
Add transmission fluid to 06 buick
use the dipstick tube for trany to fill trany
Aug 06, 2014 | 2006 Buick Rendezvous
How do I check the transmission fluid on my 2009 F-150? Where is the dip stick?
This depends on what trany is in that truck, one has a dip stick tube with a normal dip stick to check the level and then the other trany has no dipstick theres a plug on the side of the trany where the tube would go , the plug need to be removed and to add fluid you would need a pump and small hose to pump it in, also these tranys take a certain type of fluid so check with your local dealer , the wrong fluid will damage the trany, the plug you remove will have a small stick on it to measure the level, when checking the level you dont put plug all the way in only the stick part goes in. here are a few diagram to show you the plug location and the stick to check level. hope this helps, be careful the plug is near exhaust and truck must be at operating temp and truck on level ground to check the level. good luck, hope this helps.johnjohn2_2.pngjohnjohn2_3.pngjohnjohn2_4.png
Mar 13, 2011 | 2009 Ford F-150
Where do you put transmission fluid in 1988 honda accord
If this is a manual trany you need to fill from under the car on the side of the case, if your car has an automatic trany then open the hood and look at the left side of trany it will be behind the radiator fan on the trany way down you will see a dip stick this is where you check the level and fill or add fluid, you add into the same hole as the dip stick goes into, when checking the level of the trany oil make sure the car is on level ground and engine is warm, the dip stick unscrews to remove and when checking the level just put back in hole dont screw down to check level, then remove and it just read near full, if between add and full thats okay, if at add then add a pint go through gear and recheck.
Nov 25, 2010 | 1988 Honda Accord 4 Door
Automatic Transmission 97 metro
Hi:
Specifically, you remove the transmission dipstick and use a narrow funnel to pour transmission fluid in the transmission till it is full. Remember to check your fluid level after the transmission is warmed up, and the car is running, gearshift in Park.
May 06, 2010 | 1997 Geo Metro
99 Saturn SL1 when stopped and then put in reverse
That I'm not sure about yet. Do me a favor and pull the trany dipstick and put your nose really close to the fluid on the stick and see if it smells burnt.and is the fluid red or brown.
Mar 08, 2010 | 1999 Saturn SL
I have a 1998 jetta, do I need to put transmission fluid in?.
they are sealed trani and yes if your trani slip you need to add trani oil that u get from the dealer only and ask for breakable seal with oil
Jan 12, 2010 | 1998 Volkswagen Jetta
Where is the transmission reservoir on the 1999 E320?
The Mercedes Benz E class W210.065 chassis, along with others, have a Factory Sealed Transmission....MB claims "lifetime fluid"..do not believe this...i strongly recommend you service the transmission every 30,000 miles to prevent premature failure. These transmissions are expensive to repair, and AAMCO does not have qualified techs do do it properly.
If you want to service the transmission...
You will need a dipstick (MB special tool) to check the fluid level, not to remain in transmission while driving.
Also make sure to add 220-271-0098 magnet to the trans pan.
The transmission does have a filter & is fully servicable.
You must use the "special" MB fluid, 8 liters are required
Good luck...i hope this helps, please rate me a fixya.
Jul 28, 2009 | 1999 Mercedes-Benz E-Class
Mercedes after shifting to reverse to drive the 1st gear slips
mercedes did nothing wrong your transmission is probably blown up. no way they could put in the wrong parts they wouldn't fit. how many miles are on your trans now? did you ever do a transmission service on the transmission that mercedes says is lifetime fluid? dont do back to the dealer find an independant shop that specializes in mercedes, like the one i work for. the dealer doesnt care about its clients. Us independants honestly do care
Dec 04, 2008 | 2005 Mercedes-Benz Mercedes Benz E320 Cdi
RTO Automatic Transmission And Engine Oil Pressure Tester Logo
55 people viewed this question
Top RTO Measuring Tools & Sensors Experts
jdthefixer
Steve
Vuk B
Are you a RTO Measuring Tool and Sensor Expert? Answer questions, earn points and help others
