Question about Kenmore Washing Machines
Kenmore 90 series washer w broken belt
I have a Kenmore 90 series washer with broken belt(found it under the washer). How do I replace it?
    President:
  • 744 Answers
Hello I'm afraid you didnt find a belt but maybe a piece of the coupling. Here are detailed instructions on replacing a coupling: from the limited information this sounds like it's going to be a broken coupling. Kenmores are usually direct drive machines made by whirlpool, this means they don't have a belt. Instead the transmission is connected directly to the motor via a coupling. This is what a coupling looks like: Kenmore 90 series washer w broken belt - 0c6b869.jpg To confirm this pull the machine forward enough that you can lean it back and it will stand back under it's own weight. Wedge something underneath the chasis so it does not fall on you while your accessing the bottom. Go under the Machine and locate the motor, You will see the pump connected to the motor connected to the transmission. 1. Unplug the wire harness from the motor then. 2. Use a screw driver remove the 2 clips holding the pump in place and remove or push the pump out of the way. 3. You will need to remove the 2 screws from the brackets holding the Motor in place with a nut driver. 4. With a screwdriver remove the 2 clips holding the motor in place (be carefull to support the motor as the clips comes off) 5. remove the motor and drop it onto the floor. Now you will see the coupling..one side on the motor the other side on the transmission the rubber connector in between. Replace the coupling if broken or worn and reassemble the washer in reverse order. Now you should be all set. Be aware you may smell rubber on the first couple loads this is normal after replacing a coupling. Good Luck!! if you have any other questions or concerns please feel free to comment again. Mike p.s Please remember to rate my solution since this helps me to help other people :) Thanks!
Posted on Jul 15, 2009
  • 1 more comment
  • Ron Beare Dec 21, 2013
    can you not read---Broken belt under wasdher
    Add a Comment reported initially
  • Ron Beare Dec 23, 2013
    How does one replace the broken belt???
My kenmore 90 series model 110 will not spin, makes a buzzing sound
HI,
This problem is caused by either a broken washer tub drive belt or a broken washer tub drive coupler, look under the machine for evidence of this.If it is found to be true you have to go for a replacement of that particular unit.
Mar 29, 2010 | Kenmore 24032\24036 Top Load Washer
Kenmore 90 series washer does not drain
Check the following to address this issue.
1. Clogged drain line or water pump
Check to see if there's something stuck inside the pump or the drain hose connected to the pump (pump is usually located at the bottom and towards the back of the washing machine).
2. Water Pump
If the drain line isn't clogged, you may have a problem with the water pump such as a frozen pulley or a broken impeller. If that's the case replace the water pump. Note: if you have a belt driven washer, check the belt(s) for cracks, as this would be a perfect time to replace the belt(s) if needed.
Jun 21, 2009 | Kenmore Elite 45986 Front Load Washer
Kenmore 70 series washer will not spin, clothes are too wet
Not a belt, this is only a sound deadening devise on the brake housing. Not really needed. Replace the coupler
Jan 03, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore 90 Series Washer
You have a broken lid switch. Its # ll in the diagram. Part # is 3949238. Let me know if you need info on how to replace it, Dave www.washermd.com
Dec 17, 2008 | Kenmore 23822 Top Load Washer
Kenmore 70 series top load washer - no spin
the older belt drive washer has a cylanoid under it on the top trans missin called a wig wag eather broken wire to it are bad wig wag can still be found ck lid switch also
Mar 19, 2008 | Washing Machines
Washing Machines Logo
2,283 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
