Inhave a problem with a separation corona charger for
  • 1 more comment
  • Andy Bell
    Andy Bell May 11, 2010
    whst kind of copier and exactly what is the problem..
  • Adorjani Laszlo May 11, 2010
    Please specify your machine type,model.
  • sam gerban
    sam gerban May 11, 2010
    name and model needed.
  • Office Equip... Master
  • 6,161 Answers
Replace the wire(s), check the ends of the corona section, maybe arcing to ground thru the housing where the wire mounts are.
Posted on Aug 08, 2009
Photocopieur
C - 0100 Charge corona wire winding failure.
C - 0200 PC drum charge,Image transfer/paper separator coronas failure.
Clean the coronas wire and the coronas house using isoprophil alcohol and clean or change the contact combs(a little Cu pieces)
If you enter in service mode and select Counter mode you can reas the trouble code list description.
Apr 26, 2013 | Konica Minolta Minolta Ep4000/ep5000...
How can fix this code C-2105 in konica minolta bizhup 600
C - 2105 Transfer/separation corona cleaning motor home sensor error code.
Remove the transfer/separator corona located in ADU assy,use the vacuum cleaner and clean the corona support and the 2 sensors(located under corona assy rear and front area).After cleaning urn ON the copier and is working.
Mar 16, 2013 | Konica Minolta Developer 02xk Dv710 for...
Fuser problems
Fuser not cause light copy.If fuser problem the fuser unit not fixing the toner to paper (not fixing image).Light copies :dirty optical parts,Organic Photo Conductor drum,charge roller or charge corona wires or charge corona grid dirty,transfer/separator corona wires dirty.
Aug 13, 2012 | Office Equipment & Supplies
I see this message on the screen. A malfunction was detected. please call technical Rep code: C0200 what should i do if i don't want to call?
Code C0200
Description
PC Drum Charge, Image Transfer, Paper Separator Corona malfunction
Detection Timing
The leak signal (SCD) turns ON after the PC
Drum Charge and Image Transfer/Paper Separator
Corona output has been turned ON.
Try this:
C0200: Corona Malfunctions
Relevant Electrical Parts
  • High Voltage Unit HV1
  • Master Board PWB-A
Jul 06, 2011 | Minolta EP4000/5000 CS/PRO Copier
Copy quality from my sharp AR 275 copier keeps fading away. I have replaced the drum. I cannot locate the corona wire. where is it located.
No corona wire is there on this model, you can find one saw teeth like portion inside the main charger it serves the purpose of corona wire you can find the charger assembly on the drum unit, you try to clean the charger assembly by washing it and drying it buy the sun light, better to replace the maincharger, drum, cleaning blade, and developer together. Rate this and vote for this .
May 18, 2011 | Sharp AR-275 Copier
How do we fix c970 error for estudio350 -tosiba
open the side door & look for the transfer - separation charger wire if broken
or if any foreign matter is on
May 12, 2011 | Toshiba e-Studio 350 Copier
Black lines through printed pages have cleaned unit and replaced black drum unit.....still have black lines
Clean the charge corona wire/charge corona roller and the charge corona wire gride,and the transfer/separation corona wire/roller.After clean the units and clean the optical section perform the auto image adjust mode.
Sep 28, 2009 | Sharp AR-BC260 Color Copier
My di520 error code 210 every time
The problem in the transfer/separator corona unit. Clean the corona wire,change or clean and cut the holes of corona holder.100%is the good solution.
Aug 21, 2009 | Konica Minolta Office Equipment & Supplies
Minolta EP 2050 copier
C0200: PC Drum Charge, Image Transfer/Paper Separator Coronas Malfunction.
Most probably a broken corona wire. It can also be caused by dirty coronas wich can be washed with water and soap and dry them well. If the problem persistes must look for the conections and HV1, wich suplies the coronas. GOOD LUCK.
Oct 31, 2008 | Minolta EP4000/5000 CS/PRO Copier
Panasonic FP7117 Photocopier Fault code E3 11
that is for corona assembly first of all confirm that it is charger assembly or lower assembly .first of all put out lower assembly from machine and on copier if coderemoves then clean this assembly and change corona wires .if code still clean charger assembly and change corona wire.cod will bi removed.mian jee
Jul 14, 2008 | Panasonic Office Equipment & Supplies
k24674
