Question about Daewoo Televison & Video
Vcr keeps turning off by itself. can't load tape.
  • 458 Answers
Take the top cover off & have a look at the deck mechanism to see if there is anything obstructing the tape from loading properly. Put a tape in & watch closely to see if it draws the tape in, lowers it down & then threads the tape around the heads. If this is not the case & there is nothing in the mechanism preventing this action then look to see if the head drum is spinning.There may be a fuult with the loading motor if the tape is not being pulled into the machine. If there is a fault with the deck then it is best to take it to a repair centre.
Posted on Jul 18, 2009
I hAVE 24 in DVD triple combo ^&@$DG TV. I put
You're describing what could be a loose or worn loading belt problem, most of the vcr mechanisms used in these combos use one to load the tape and thread it for it to play or record, that is why you have to keep puhing the tape untill the machine accepts the tape and you have to keep pressing play untill it starts the play function.
Sep 19, 2009 | Sylvania Televison & Video
Toshiba VCR
Check this link it has some solutions that you can try in removing the tape inside the VCR http://www.fixer.com/no-eject.html
Hope that helps...........
Sep 12, 2008 | Televison & Video
Panasonic 7350 VCR Keep ejecting tapes just seconds after loading
This happens when he strings are worn out or broken. It will not hurt to replace the strings of the VCR after some while.
Jan 29, 2009 | Panasonic AG-7350 VHS/S-VHS playback VCR
We have an emerson vcr model ewv 401a. It is new only used twice in the past yera or so. Put in tape, tape was stuck we were able to remove the tape but the vcr keeps turning self off after about10 seconds...
there is an acrylic post inside that directs a light beam to several different places so when the light beam is broken then it tells other parts that the tape is loaded this could be broken off or if the tape broke off inside a piece could be wrapped around a capstan or drive post causing the machine to think it is at the end of the tape and to turn itself off.
Dec 15, 2008 | Stanley 100 ft. Tape Measure, FatMax
T.v. ejecting vcr tape and turning self off after being turned on
If VCR mechanism doesn't load or unload properly, TV will shut off. VCR machnisam in your TV requires cleaning/ service. Spacialy belts and pulleys.
Jun 22, 2008 | Philips Magnavox DVD/VCR Dual Player
What do I do when my Emerson TV keeps turning off by itself?
I had the same problem with mine turning off after 3-5 seconds. After much research I found a suggestion that on some combo units the vcr part could have a power supply cutout if it is not working correctly. I tried to insert a tape and found that the tape mechanism would not accept a tape. I used a little bit of force and managed to insert a tape. I then played the tape forwards and backwards and the power stayed on! I ejected the tape and found the TV then worked just fine. The power has now been on for over one hour. I hope this give you another avenue to try and fix your problem.
Nov 30, 2007 | Televison & Video
Help!
My guess is that the prisim broken or led (light emitting diode) below it has failed so the vcr is stuck in an endless load...
It will have to be taken apart and the tape in it manually unloaded by turning the load motor counter clockwise. Then visually inspect the prisim and test the diode.
If any of this sounds too foreign take it to a good shop and they'll have it back and running in no time..
Hope this helps!
Bill
Nov 14, 2007 | Philips CCC132AT 13 in. TV/VCR Combo
Televison & Video Logo
214 people viewed this question
Top Daewoo Televison & Video Experts
 Grubhead
Grubhead
Are you a Daewoo Televison and Video Expert? Answer questions, earn points and help others
