Question about Fedders Appliance Air Conditioner Wall
I have a fedders ac unit that has temp settings. I was wondering if there is some way to override the 66 degree setting to make it run cooler to make the room colder. (like the older styles...down to 50 degrees!!) (I AM mechanically inclined if need to access, solder, etc.) Thank you in advance Bill billmaucher@yahoo.com
    Champion:
  • 233 Answers
You can get a manual analog dial thermostat, atan appliance store and substitute it for the current stat, some boards also have installer settings that you can reset the limits, (I would try that first) there also are some that have dip switches that can be set to override, the issue with the last two would be finding an installers set-up manual, as I said I would search for that before I tried any non factory components
Posted on Jul 16, 2009
CWC-1600 cools constantly
More than likely, the thermostat on the unit is going bad. If the coils haven't been cleaned recently, then I suggest that you unplug the unit, clean it well and then cycle it back on. If it continues, then the thermostat that's located within the unit is going bad. Please refer to the owners manual for proper service and maintenance for your unit. https://www.appliancefactoryparts.com/content/pdfs/140265-1.pdf
Feb 04, 2017 | Heating & Cooling
Maytag m6x06f2a like new but doest blow cold air
Make sure the Thermostat is set correctly! The problem with mine was the temp in the house was colder than my A/C lowest thermostat setting.I had my AC temp setting on 66 degrees.The temp in the house was a little lower so the AC didnt kick on just the fan blowing cool air and no compressor working. The next day it was warmer out and the house temp was 79. So when I powered up the AC set at 66 i heard the compressor kick in and the AC worked fine.
Aug 27, 2013 | Maytag M6X06F2A Air Conditioner
My frigidaire a/c is set 73fhrenheit after running for a time the temp. on the unite drops to 60 degrees by it self what is the problem ?
AC units, no matter if they are big/small, window or big central units. They will only cool the air in the room, or home, to about 15 degrees cooler than the outside air temperature. If you live in Georgia and it is 100?F+ outside, you will be lucky if the unit will reach 80?F even running all day.
Jul 22, 2012 | Frigidaire FRA186MT2 Window Air...
I have a 5 ton ac with two 10 kw heat strips. The problem is that the unit runs constantly on one stage with the temp. set at 66 degrees in the winter. The second stage heat will kick on if I manually...
Between two stages, the difference temp has been set up to call for second stage.. If you need immediate heat what you did is right. But again you have to reduce to your required temp. Hence, wait the second stage get started.
Jan 13, 2011 | Heating & Cooling
I just got a new heating unit installed. However it runs constantly. If the target temp is 68 degrees it will hit 68 degrees and just keep running. It does the same at 63 degrees. Is this normal?
Dear friend! Any thermostat, it's calibrating to cut off at the end of 2nd beginning and cut in 2nd ending of temp.
Ex: In heat mode, If you set @ 68 degree, it will cut off 70 degree beginning and cut in at the end of 66 degree.
Hope it's helpful to you?
Jan 10, 2011 | Intertherm Heating & Cooling
What degree should I keep it on? 66 or 79? I can't find the manual
79 will mean that your house will be 79 degrees inside, I would think you would rather 75 or lower number. The lower the number the colder you want the room to get and the harder the AC will have to work for you.
Jul 07, 2010 | Fedders A6D24E7D Wall/Window Air...
10000 BTU Fedders. Thermostat set to 66. Only cools to 73.
Just move the Tsat. But you have a chance of icing the unit if you are not careful. Good luck. Russ
Jul 21, 2009 | Kenmore 72059 Air Conditioner
Thermostat window ac turns unit on and off 8 degrees above se
the unit may be drawing the cool air it just released back into itself,plus the air close to the unit may be a little cooler than the air in the rest of the room.
Mar 19, 2009 | Kenmore 72059 Air Conditioner
Hot air blows unless the temp is turned down to 66 degress
well ? Does It get cold @ 66 Degrees? And If so.. Aint 66 degrees cold?
Mar 15, 2009 | 2004 Honda Odyssey
VP500 Cooling unit issues
http://www.rosehillwinecellars.com/3rsV2/54_RHWC_plans/tuscany_plus_250_500.pdf
above is a link to the Vintage Keeper manual PDF format manual and problems and trouble shooting guide
Oct 23, 2007 | Vintage Keeper VP500 Wine Cooler
Fedders Appliance Air Conditioner Wall Logo
195 people viewed this question
Top Fedders Heating & Cooling Experts
Dan Webster
Dan Webster
Ronny Bennett Sr.
Ronny Bennett Sr.
Bill Long
Are you a Fedders Heating and Cooling Expert? Answer questions, earn points and help others
