Question about Samsung HP-S4273 42 in. Plasma HDTV
Scrolling line My samsung also has the same problem. But we had the same issue with another flat screen. I thought if I purchased an HD cable box that it would fix the problem but no luck. I am not currently using a HDMI cable though.
  • anesbitt79 Jul 16, 2009
    the lines run vertical and are kinda purple. sometimes they are black
  • 304 Answers
Question. Are the scrolling lines horizontal?
If so that is called 60 cycle Hum Bar and is a result of the following:
1. Bad grounding of the cable system.
2.Bad cable box. This a common problem with cable boxes.
3.If you are using Component cables from the cable box to the tv then the Component cables might be bad. Try using another set of Component cables. If that does not work then you need to call the Cable co. to come out and check their system and make sure that the cable tech brings out another cable box to try out. There is no problem with the set.
Posted on Jul 16, 2009
  • Peter Skipper Oct 15, 2012
    I checked and replaced cable and new cable box and I still have a problem. Any suggestions?
Samsung flat screen T.V with sound problems.
Sounds like the issue is with the set top box of your cable or direct tv provider. Please swap that receiver for the equivalent or a more updated version.If the problem persists. Verify that all inputs on television is correct. It should match. Output of source( digital receiver,dvd player) to Input( television ). Make sure all is secure. Good luck
Jan 31, 2010 | Samsung LE32R41BD 32 in. HD-Ready LCD...
Some HD channels won't work on new Samsung tv.
Some hd channels can only be viewed by watching thru a cable box. If you are using a cable box check with your cable provider to see what the issue is.
Dec 23, 2009 | Samsung LN52B550 52 in. LCD TV
Hi! i just purchased a Samsung SyncMaster P2370HD P2570HD flat screen tv and I was wondering if you are able to tell me the correct settings to put on the TV to get the best picture? The picture does not...
Hi Suzette my name is Roety,
I can help you with your issue ,
First of all make sure you have an HD signal connected.
These days using a non HD box will produce a bad picture on an HD TV.
If using a cable/Dish box set the output resolution to 1081i only,
for picture controls set them all center and max out the picture/contrast control
If I have helped you with your issue please click accept.
If you have more questions you can still respond until this post expires,
I will reply asap
Thanks
Nov 28, 2009 | Samsung Televison & Video
Cannot optimize picture width on new flat screen HD
On your cable box remote press the hd zoom button. I have comcast cable box and it worked for me.
Dec 25, 2008 | Toshiba REGZA 42 in. Flat-Panel LCD HDTV
Cannot set screen width
Both the TV and the Cable box have Aspect(height/width) settings. You must confirme the setting on the cable box and then do the TV.
1. Set TV to Native, this should show image exactly as the cable box sends it.
2. change Aspect settings on the cable box until you get one that works
3. if you get a good one, then your OK. You will just need to find a setting between the 2 devices that work for you. Also, these settings may change automatically for the TV or cable box based on the channel
Horizontal Lines scrolling on screen
I had a similar issue with my Mitsubishi HD 1080. My power supply went out, I had it replaced and it works like new. However, just today I had AT&T U-Verse installed. When the cable guy was showing me the new HD channels all seemed good. This evening (about 5 hours after being installed) I started seeing these horizontal lines across my screen. The picture was still HD quality, but those annoying lines just wouldn't go away. Anyway, after reading a few blogs on-line suggesting interference or bad grounding, it hit me!!! The AT&T guy who installed my U-Verse (cable, internet and phone) had set the modem on top of my TV!!! It was just starring at me this whole time. So I removed the modem off the top of my TV and put it on a side table just to see what would happen and sure enough the lines were gone!!! You may not have the exact same problem, but it may be some type of interference (cell phone, modem, etc, either on top or around your TV that is causing the issue... Hope this helps. Thanks.
Oct 31, 2008 | Televison & Video
HDMI INPUT FOR NON HIGH DEF CHANNELS WILL NOT DISPLAY FULL SCREEN
if you have a cable box then it is probably the resolution settings in the cable box, what type of cable box do you have
Jun 30, 2008 | Samsung LN-S4692D 46 in. LCD HDTV
Picture issues
Greetings caesar975,
Unfortunately if you chose to view the non HD channels in wide screen format, you are going to have the top and bottom of the screen cut off. Eventually this will not be a problem when everything goes to digital. However presently non HD channels are presented in 3:2 ratio where as HD is 16:9, So your choice really is to view them with the lines on either side for now.
I do not have an answer for the white flickering lines.
To get the BEST picture out of your 1080p unit I highly recommend using HDMI cables to hook it up.
I hope some of this helps.
Sincerely,
Dorothy
Go Ahead. Use Us.
Jun 11, 2008 | Samsung LN-T4061F 40 in. LCD HDTV
Vertival Color Lines
We had the same thing happen to us on the right-hand side. A technician told us yesterday that the Motorola Cable Box (supplied by Shaw Cable) places a border on Non-True HD Channels. Because we didn't place our picture setting to 'full-screen' each time we viewed these channels and burn line was created. He gestimated a replacement screen runs about $800.00 Canadian, but we have a 3 year extended warranty and will receive a new TV. He also said it happens on all big screen tv's that use a cable box creating borders on Non-True HD Channels.
May 04, 2008 | Toshiba REGZA 42 in. Flat-Panel LCD HDTV
Samsung HP-S4273 42 in. Plasma HDTV Logo
287 people viewed this question
Jerry Greenberg
Jerry Greenberg
