Question about Craftsman 20 hp 42 in. Deck Lawn Tractor - CA Model
Blades won't disengage
Changed the v-belt on my craftsman lawn tractor per owners manual. It is on and working. However, the cutting blades will not disengage. When I ran it to make sure it was working, I noticed the motor revs up and slows down on it's own. Did I re-connect something wrong? Can you help me?
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 95 Answers
I would check to make sure you have the correct belt first.There is usually a belt dioagram in the manual and on a sticker on the mower.Then check the idler pivot bracket to make sure it is moving freely to allow the belt to loosen also there is a small spring p/n 169022 that pulls the idler pulley back to disengage the belt when you release the engage lever its is about 1/2 inch by 3 inches long on the center of the deck.Also there are 2 brake cams that lift the brakes off the pulleys make sure they are lubed with wd-40 where the roll across the idle plate,and make sure the idler plat does nat have a worn spot on it where the cam roller rides on it.
Posted on Jul 30, 2009
Craftsman zero turn runs but blades won't engage.
if got elect. pto/ and clutch,could have a wire connector come loose
Oct 21, 2012 | Craftsman Garden
Craftsman 20hp lawn tractor blades won't engage
check to make sure your cable is in tact its called a pto clutch cable about 20 buck on ebay it may be broke inside
Sep 26, 2012 | Craftsman 20 Hp 42" Deck Lawn Tractor
Blade engagement lever won't disengage
If this is a manual engagment system all the lever does is to pull a jockey wheel into the back of the belt to tention it thus starting the blades to turn, so either the cable is jammed that pulls the jockey wheel in, or the jockey wheel arm is seized and needs freeing off to allow the jockey to to move to the relaxed position.
Jun 23, 2012 | Craftsman 20 Hp 42" Deck Lawn Tractor
I have a Craftsman FS5500 48" lawn mower. The PTO makes a noise (squeak) for a second when I pull up on the red blade engage knob. The blades do not engage. PTO does not turn. When I push the red...
The problem is probably in the button that you pull and push to engaged and disengage the PTO... If you wiggle the button or try to pull it slowly, you may find a spot where it will work. But the button has gone bad and will need to be replaced.
If you are comfortable with wiring, you could jumper the wires and getting it working, but it would be a very temporary and possibly dangerous fix...
Jul 30, 2011 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
My riding lawnmower blades will not disengage or engage Now my lawn mower will not start
just replaced some pulleys on my craftsman 42 inch cut and now the blades are ingages all the time, but it will start
Jul 17, 2010 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Blades running while the lever is disengaged
sounds like belt is to tight or the electric clutch isn't disengaging
Jun 25, 2010 | Craftsman YT 3000 42" Kohler 22 hp Gas...
Blades will not disengage
the brakes on the deck belt not working belt to tight or deck not fully disengaging
Jun 22, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
When the mower is off and the clutch is disengaged you should not be able to physically turn the blade(s) if you can then you need to adjust the blade brake (look on the mower deck and you should see what appears to be a brake pad). Your owners manual will show you how to adjust. If you need a copy of the owners manual then I would suggest going to www.managemyhome.com and downloading a free copy of the manual for your mower (Need model number which starts is located under the seat).
Jul 27, 2009 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Craftsman 20 hp 42 in. Deck Lawn Tractor - CA Model Logo
355 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
