Question about SanDisk 4GB microSDHC Memory Card
How can i remove write protection to my microsd.even if the switch is in unlock position
    Problem Solver:
  • 5 Answers
Move the switch between unlock and lock
erase the folders u hav on the mem.card or upload ur stuff first then delete
then u can put wut evr u want on it like music or wutevr
hope i helped :)
Posted on Sep 07, 2009
How do you unlock a Locked sandisc
That depends on the type of the SanDisk product.
SD and SDHC cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Memory Sticks have a switch along one side. One position is marked "LOCK", the other position unlocks the card.
MicroSD adapters have a slide switch, just like SD cards.
Mar 23, 2013 | SanDisk 2GB microSD Memory Card
Remove rewrite protection from card
SD and SDHC cards as well as microSD adapters have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Jun 16, 2012 | SanDisk 2GB microSD Memory Card
Removing write-protection from SD card
SD cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
May 02, 2012 | SanDisk Microsd 2gb Memory Card Micro Sd 2...
Memory card unlocker
Micro SD (secure data) cards store information such as Word, image and video files.
Kingston microSD cards are used in many settings, such as schools, businesses and government offices, to protect data.
Some Kingston microSD cards are locked for added protection.
In the locked position, you cannot add or delete data from a microSD card.
You will need to unlock your Kingston microSD card in order to save data on it or delete data from it.
Remove the Kingston microSD card from whatever device it is kept in, whether it's a storage case, a digital camera or a GPS.
Find the small plastic switch on your Kingston microSD card.
If you are looking at the microSD card with the arrow pointing away from you, the switch will be on the right side of the card.
Flip the switch on the card to the unlocked position.
This will enable you to store and remove files on your Kingston microSD card.
http://www.kingston.com/flash/securedigital.asp
Jan 24, 2012 | Kingston 1 GB microSD Card with USB 20...
My PNY 4GB micro sd HC memory card for my cell phone says its write protected and won't let me transfer anything on to it. How do I remove the write protection. I already tried to switch it into an...
The problem might be that the card is password protected, i recommend you switch it to the unlocked position and then use a computer to format the memory card and do a full format not the quick format.
hope this helped.
Mar 06, 2011 | PNY 4GB microSD High Capacity Mobile Media...
I have not been able to get the write protection removed even after unlocking the memory card
Toggle the lock switch.
If the lock switch is not on lock:
1. Slide the switch up and down. Repeat this 3 times.
2. Let it stay on the Lock position for 30 seconds.
3. Slide the switch up to unlock the card.
4. Try to transfer files into the device.
Jan 12, 2011 | SanDisk 2GB microSD Memory Card
My sandix 2gb microSD mameory card is write protected how will i remove it?
1.Look for a switch or button on the side of the micro SD card or adapter. It might have a lock/unlock symbol on it. 2.Move the switch to the "Unlocked" position to remove write protection. This position may also be labeled "R/W" for read/write. If you have no switch, continue to Step 3. 3.Download and install Sony EzRecover (see Resources for link) and attempt to use it to format the card (this will erase all content). If this doesn't work, try Step 4. 4.Delete and repartition the micro SD card using Windows XP. Select "Control Panel" > "Administrative Tools" > "Disk Management." Select the micro SD drive and click "Delete." Right-click on empty drive and select "New Partition."
Dec 29, 2010 | SanDisk 2GB microSD Memory Card
Sd card write protected format card
SD cards (and microSD adapters) have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Dec 18, 2010 | PNY 2GB microSD Memory Card
How to remove the write protected micro sd card?
SD cards allow you to store digital information; you can use SD cards with most electronic devices like digital cameras and computers.
An SD card will become write protected if the switch on the card is placed on the "Lock" position. This prevents any information on the card from being altered or deleted.
If you wish to add, delete or change any of the information, you must remove the write protection.
Remove the SD card from the computer or digital device.
Locate a switch on the bottom or side of the SD card.
Move the switch to the "Unlocked" position to remove the write protection.
If you do not have a switch, you will need to remove the write protection with your computer.
Insert the SD card into your computer's card reader or back into the digital device.
You can now save and change information on the card.
Dec 06, 2010 | Kingston 1 GB microSD Card with USB 20...
Formatting time it shows write protected error
SD cards nad microSD adaptors have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card. If the switch is already in the proper position, slide it fully the other way and then back again.
Mar 01, 2010 | PNY 2GB microSD Memory Card
SanDisk 4GB microSDHC Memory Card Logo
283 people viewed this question
Top SanDisk Computers & Internet Experts
Arora Singh
Arora Singh
Sandy Moore
Sandy Moore
Are you a SanDisk Computer and Internet Expert? Answer questions, earn points and help others
