Question about Car Audio & Video
Amp won't power up,anymore! Even with new parts installed,removed
Rockford Fosgate 100a2 car amp Replaced BUZ power supply transistors then powered it up,Power LED went Dim,powered back down immediately.Removed left channel outputs (IRF540 & IRF9540 I believe)then powered it up and play the right channel all day!
Re installed left channel output transisters,powered up and now it has a shorted power supply.Measures 5 volts at power terminals of amp.I think I possibly swapped the Output transitors(IRF540 & IRF9540) positions in the board and smoked one of the BUZ transister.Also removed the U1620 & U1620R rectifiers,tested them OK and in my hast ,Don't remember their positions on the board either.
Picture of board would help.That would tell me if I reversed positions on those output transistors
Did I reverse positions on output transistors or should I check some transistors farther back in that right channel?
Any advice would be greatly appreciated!
    Scholar:
  • 113 Answers
Hiya, dont have a diag either what you will have to try and is compare the left channel with the right. There will be 2 driver transistors (also likely on heatsink) close to the outputs. Check which driver drives which output on the left, then match it on the right. Those same drivers could very well also be a problem on the right as they often go with the outputs. There is a possibilty they have smoked again. See here to test FETS
http://www.4qdtec.com/mostest.html
Basically the left will match the right but not similar locations but definitely by track joins.
Also check the power resistors at the output. Often also go.
Hope that helps
Posted on Jul 16, 2009
Rockford fosgate db1500 amp turns on but no output what to check or repair
dwdwaawdioauwdawhsduawdnaioudghasuigdajwdiasnd akdhnsanlxdkasiudasdasbdkjasdaosiudasgbdusabd as
Oct 05, 2013 | Rockford Fosgate 100a2 Car Audio Amplifier
No power after i unhooked the wire from amp, left wire uncovered at ends for couple days tried hooking them back up and no power now. is amp blown
if you unhooked the wire from the amp while the amp was on, you may have possibly blown a fuse, or mayb a transistor or compacitor inside the amp! easy fix, just find new transistors and compacitors and soilder them on after removing old ones!
May 03, 2010 | Rockford Fosgate Punch P8002 Car Audio...
Rockford Fosgate T15004 The Amp still powers up with the
Check you inputs to verify you have a signal coming in, if signal then check outputs try a speaker that you know is working and plug it in if that speaker plays then the subs/ or speaker wiring is bad, if it doens't play then you probably have a blown output transistor on the amp or possibly a terminal ground/positive has come loose on the inside..
Oct 27, 2009 | Rockford Fosgate T15004 Car Audio...
Amp was hooked up without fuse from battery to amp
Another failure must have occured, as the fuse would have blown, possibly limiting the damage, however something did fail to start the problem.
Nobody can give you an honest estimate without analyzing the damage.
A wild guess would be one-half the cost of the unit.
Sep 10, 2009 | Rockford Fosgate 100a2 Car Audio Amplifier
401s Rockford Fosgate Amp. Not turning on. No power light. Pos+ and GR- are solid. Thought it may be remote, so tried running a wire from the POS+ to REM to test it, no luck
Amp Failure:
There are many different ways that an amp can fail but the two most common failures are shorted output transistors and blown power supply transistors (< those are not blown). There are several types of protection circuits in amplifiers. The most common are over-current and thermal. The over-current protection is supposed to protect the output transistors. Sometimes it doesn't work well enough to prevent the failure of the output transistors but it will work well enough to shut the supply down before the power supply FETs are destroyed. If the amp remains in protect mode, goes into protect mode or blows the fuse as soon as the remote voltage is applied, shorted output transistors are almost certainly the cause. If the fuse protecting the amp is too large, if the protection circuit doesn't respond quickly enough or if the power supply is poorly designed, the power supply transistors may fail. If you see a lot of black soot on the power supply transistors (near the power transformer), the power supply transistors have failed. Soot on the board doesn't necessarily mean the transistors have failed. Sometimes, technicians don't clean up the mess from a previous failure. Transistor Failure/Checking Transistors:
In general, when a transistor fails, it will either short (common for output AND power supply transistors) or open (common for power supply transistors). Transistors act like valves. They control the current flowing through a circuit. A shorted transistor acts like a valve that's stuck open (passing too much current). In the case of an output transistor, the shorted transistors tries to deliver the full rail voltage to the speaker output terminal. If you've ever seen a damaged amp that pushed or pulled the speaker cone to its limits when the amp powered up (common on some Rockford amplifiers), that was almost certainly due to a shorted output transistor. When checking transistors, you most commonly look for shorted connections inside the transistor. You do this by using a multimeter to look for low resistance connections between the transistor's terminals. Note:
I used the terms short and open on the previous paragraph. A short (short circuit) is a path through which current flows that should not be there. An open (open circuit) is a break in the circuit.
These repairs are best left to a repair tech familiar with car audio amplifiers. Check with your local shop to get a reccomendation. If the light isnt even coming on, chances are your input or power supply has been taken out.
Jan 01, 2009 | Rockford Fosgate Punch 401S Car Audio...
Rockford Fosgate 120a2 amp
You can get it from Rockford.
Let me know if you need any help repairing it.
Aug 19, 2008 | Rockford Fosgate 100a2 Car Audio Amplifier
Amplifier not working
If the speakers are being driven in or out and remain there when the amp is on, the amplifier likely has shorted output transistors. These are not easily replaced in the Rockford amplifiers that use the MEHSA insulators. Unless you're interested in learning to do this type of work, it should be sent to Rockford for repair.
Sep 09, 2007 | Rockford Fosgate P3001 Car Audio Amplifier
Rockford Fosgate Amp Repair Guild
I would love to get a copy of that repair guide you made. Could you please
May 18, 2007 | Rockford Fosgate 100a2 Car Audio Amplifier
100a2 amp not getting power
get a strand of wire and jump it from the power to the remote if the amp does not turn on then take the amp and smash it over and over again because it is fried
Nov 05, 2006 | Rockford Fosgate 100a2 Car Audio Amplifier
Car Audio & Video Logo
176 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
