Question about Maytag Washing Machines
First i have a maytag atlantis washing machine, it is about 6 to 7 years old. the first problem is the load size water setting switch, it only works on large. that's not a problem as we don't change it. now when you try to turn on it starts washing with no water.
  • kerry deshazo
    kerry deshazo Jul 15, 2009
    i will give it a shot, thanks for the info
    President:
  • 744 Answers
Hello these 2 problems may be related, In most washers they have a pressure switch, this regulates the amount of water that enters the machine. the pressure switch is located inside the control panel...Normally removing a few screws at the back of this panel will give you access. The pressure switch is going to be the one with the small rubber tube attached. Remove the tube blow down it reattach it and then try again. If this does not solve your problem it may be related to the inlet valve. Locate the inlet valve on the back of the machine, pull the terminals off the valve and check to see if the terminals have 110v across them when you start the machine. if you do have 110v across the terminals then replace the valve after checking we do have water. If you don't have 110v (no reading) then check the pressure switch for voltage going in and out...if voltage in but not out replace the pressure switch. Good Luck!!! if you have any further questions or concerns please feel free to comment again. Mike
Posted on Jul 15, 2009
  • 3,230 Answers
Dry agitating is often a sign of a bad water level controls /pressure switch. The water level controls, also knows as a pressure switch, might have burnt wires, may be stuck in the full position, or the hose is clogged up.
The water level controls the water fill valve and, when it detects there is enough water in the tub for the wash size selected, it shuts off power to the fill valve and then sends power to the timer. It detects the correct water level via an air tight hose that runs from the outer washer tanks to the water level controls. The hose contains a certain amount of pressure for each load size (small, medium, large). As water fill the washer tub, pressure rises in the hose also. Since the air is trapped in the hose, it is compressed and pushes up a piston in the hose. When the piston is popped up, it closes an electrical contact which shuts off the water fill valve.
A small pin hole or leak will cause the tube to lose pressure and it will not be strong enough to switch off the water fill valve leading to overfill. The reverse problem, like yours, means that the water fill valve might be stuck on the full load position, saying there is enough water in the machine when there is not.
Good Luck!!
Thanks
Maytag Atlantis Washer - no cold water
Check the solenoid valves. If it's connected to hard water, the minerals build up inside and won't let the internal plunger move.
Mar 16, 2017 | Maytag Atlantis MAV9501E Top Load Washer
I have a maytag Atlantis washer - 7 years old, it
I have a Maytag Atlantis top load washer which leaks in the rear right hand corner under the discharge hose, how do I take the machine apart to get to the problem.
Feb 04, 2010 | Maytag Atlantis MAV6000 Top Load Washer
Washing Machine will not fill with water
It sounds like the water solenoid has gone bad or stuck closed OR timer/control knob has bad set of contacts which control the solenoid.
Jan 17, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Maytag top loader washing machine
i believe i can help you,,but washers dont agitate in the spin cycle,,i believe you ment it wont wring or spin in the spin cycle..your lid switch is defective,,replace,,if need be i can talk you though,,onthejob
Dec 28, 2008 | Maytag Atlantis MAV6000 Top Load Washer
Maytag Atlantis top-load washer won't fill with water, no power.
Not the lid switch>>>The water level switch ...unless you have forgot to turn the water on,Please Rate This !!!!
Dec 01, 2008 | Maytag Atlantis MAV6000 Top Load Washer
Maytag washing machine will not drain
your water pump may be jammed with a sock or something..its in the bottom of the machine
Nov 15, 2008 | Maytag Atlantis MAV6000 Top Load Washer
Maytag Atlantis washing machine
Yes there is a small motor just like in most wall clocks the gears strip or the gear bushing slips and refuses to advance the dial.
you have to replace the whole timer unless you know MacGyver microsurgery
Feb 13, 2008 | Maytag Atlantis MAV9750A Top Load Washer
Maytag Atlantis MAV6257AWW
I have a Maytag Atlantis MAV6257AWW. I need to replace the transmission. So I removed all four screws from the inner tub but I couldnt get the inner tub pull out, it's stuck.
From what I read on here, the seal nut doesn't have to be remove in order to remove the inner tub.
I tried every, I even hammer the shaft down from the inside of the tub but still no luck. Can someone help, thanks.
Jun 23, 2007 | Maytag Atlantis MAV6451 Top Load Washer
Washing Machines Logo
32 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
