Question about Hunter Fan Company 5/1/1 Programmable Thermostat
Blinking re co on thermostat
My thermostat has been showing RE CON blinking on the indicator panel. What does this mean?
    Guru:
  • 1,738 Answers
It means that you are going into from one program to another program.
Posted on Aug 09, 2009
  • rjhahn Aug 10, 2009
    I have the same one here at my home
I GOT 14 BLINKING RED LIGHTS SONY BRAVIA KDL46VL160 I DISCONNECTED T-CON BOARD AND THE GREEN LIGHT STAY ON I ORDER USED T-CON BOARD TWICE INSTALLING AND AGAIN I GOT 14 BLINKING LIGHTS
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
If blinks continue without any pause, the main board is faulty.
Search the site by type in the "brand name" to your device, in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
May 23, 2016 | Televison & Video
What is the error code for 5 blinks for a Sony KDL70R520A LED TV?
The most common defect that causes a 5 blink error on this model is the T-Con board. This board is now discontinued. You might be able to find one on Ebay or Amazon. If the T-con board does not fix the issue, then your panel is defective and your TV will need to be replaced.
Apr 09, 2016 | Sony KDL Televison & Video
The unit does not run and the display indicates "EH"....What does this mean?
EH is emergency heat. It could be the thermostat is not set of configured properly. Find the instructions and wiring diagrams for both the thermostat and the air-con to double check wiring of the thermostat to the air-con
Oct 10, 2015 | Heating & Cooling
Why does th3 Standby light blink 5 times on front of my Sony Braivo KDL-55ex620 TV.
HI
5 time red light blinking indicate that the T Con board is defective please replace T con but after replacing the t con board you must up date the SW because in some cases you replace the t con & 5 time is gone but there is no picture so in that case you must perform sw
thanks
Feb 14, 2015 | Sony Televison & Video
Sanyo tv troubleshooting
this is a bad t-con board or a loose lvds cable from the t-con to the panel.try reseating the cable to the t-con and the tv panel,this means removing the back cover.
Dec 09, 2013 | Televison & Video
My sony bravia lcd tv model# KDL-46VL130 has a red blinking light blinking 5 times. What does this mean??
Could indicate the T-con board is either faulty, not grounded properly, or not connected properly. I would concentrate on the last two possibilities first before replacing the board itself as that could get rather expensive just to find out a ground wire was loose or a connector bad/loose.
Do you get any menu when you turn it on and press the menu button on the side of the tv? if so, the likelihood of a bad board is slimmer than not.
Mar 09, 2013 | Televison & Video
Television does not show picture, does not turn off, does not respond to controls. on-light turns on, but not much else. NEED HELP!!!
Does the power indicator light flash or blink? If it does, count the number of blinks and then Google your make and model with the words blink codes at the end. This will take you to sites that will tell you what the blink code means.
Sep 04, 2011 | Televison & Video
42" LCD tv shows picture on only half of the screen,other half dark!
The T-Con board (otherwise known as LVDS) connects to two seperste parts of the LCD panel. If you do have half a picture (left or right) replacing the T-Con board should resolve this issue. Open your TV, find the part number and search on eBay or at sites like www.flattvparts.co.uk where you can search by TV model number.
Oct 27, 2008 | RCA L26WD26D 26 in. LCD TV
Flashing re co
Re Co stands for Recovery Mode. That means if you have programed your thermostat to be at say 72° at 5:00 then it should kick on in Recovery Mode several minutes before 5 in order to reach that temperature. This is normal and doesn't indicate that something is wrong, just that your thermostat is trying to reach or recover the programed temperature.
Feb 08, 2008 | Heating & Cooling
Hunter Fan Company 5/1/1 Programmable Thermostat Logo
848 people viewed this question
Top Hunter Dryers Experts
Paul Bade
Brandon Berry
Brandon Berry
Are you a Hunter Dryer Expert? Answer questions, earn points and help others
