Question about Refrigerators
Water is leaking from under refrigerator after I pulled it out to clean behind it. the water line is not leaking.
    Brigadier General:
  • 3,513 Answers
Thank You for contactng Fixya.com
Analyzing the likely source
Move the refrigerator out from the wall and look for the location of the leak.
Check the side panels and the seals around the door for beads of "sweat." This could indicate a condensation problem.
Check the floor. A puddle there could indicate a missing or cracked drip pan, or a leak in the water line that feeds your ice maker.
Check for water seeping from the front of the freezer or the refrigerator. This could indicate your defrost drain is plugged or your ice maker is leaking.
Fixing a condensation problem
Check that the doors shut correctly. Hold each door about halfway open, then let go. If the doors don't shut completely, adjust the screw legs on the front of the refrigerator so the unit tilts back a bit. With adjustable pliers, turn each leg one revolution clockwise. Recheck the doors and, if necessary, repeat the process until they shut securely.
Inspect the door gaskets. Look for debris that may keep the doors from shutting. Also check for cracks or gaps in the gaskets that could allow the cold air to seep out. If you find debris, clean the gaskets with warm, soapy water. If you find cracks or gaps, you'll need to replace the gaskets (see How to Fix a Refrigerator That Cools Poorly).
If your refrigerator is equipped with a door-frame heater that evaporates condensation, make sure the heater is turned on. The switch should be located with your other refrigerator controls.
Fixing a drip-pan problem
Pull off the grill that runs along the bottom of your refrigerator.
Locate the drip pan, using a flashlight if necessary. The pan should be sitting on top of a set of black condenser coils and directly below a drain tube that carries water from your freezer when it is in defrost mode.
Place the drip pan in your sink and fill it with water to test for leaks. If it leaks, order a replacement from your appliance dealer.
If the drip pan doesn't leak, clean it with warm, soapy water, then reinstall the pan and the refrigerator grill.
Fixing a clogged defrost drain
Locate the defrost drain. It should be a round hole or a channel running under the vegetable and fruit bins in the refrigerator or along the floor of the freezer compartment.
Inspect the drain for clogs and remove any debris. If necessary, use a small screwdriver to break up debris that's trapped in the drain hole.
Fill a meat baster with hot water and force it through the drain to make sure the clog is gone. If the drain is operating properly, the hot water will fill the drip pan.
Fixing a leaky ice maker
Pull the refrigerator away from the wall and locate the copper water-supply line. It runs from the house water line to the refrigerator water-supply valve. (To get to the supply valve, you may have to use a screwdriver or a nut driver and socket to remove your refrigerator's back access panel.)
Inspect the copper supply line, the supply valve, and the plastic supply tube that runs from the other side of the supply valve to the back of the ice maker.
If a connection is leaking, tighten it with an adjustable wrench. If either the copper supply line or the plastic supply tube is leaking, you need to replace it.
Turn off the water supply. The valve may be under the kitchen sink or connected to a cold-water pipe in your basement.
Remove the faulty line and take it to a hardware store to get an exact replacement.
Install the new line, tighten the connections with the adjustable wrench and turn the water back on.
I am sure you would be able to resolve the issue.
God Bless.
Posted on Jul 15, 2009
There is a thick sticky black substance leaking from my refrigerator for the past two weeks on the left front side. Frigidaire model p/n 241543966
Hello Melanie;
My name is Peter. I am a retired field service technician.
You do not have a refrigerant leak. Refrigerant is clear in color.
You have a water leak. The black sticky substance is either coming from your bottom condenser cooling coil or just general dirt under your refrigerator that accumulates over time. The coil under your refrigerator collects dirt as well.
You need to pull the refrigerator out so you can get behind it.
Unscrew the bottom back cover. Inspect for the water leak source. Your condensate drain pan may be leaking or dislodged.
The water line to your ice maker may be leaking.
Your water supply shut off valve to your refrigerator may be leaking.
Nov 01, 2014 | Refrigerators
How do I move it
use a dolley to lift and pull dont pull out to far you may have a water line in the back for ice maker and the electrical cord is ony so long the water line is leaking to the ice maker or the evaporator pan under the fridge is full you fan may not be working if it is not blowing replace it unplug before woking on it any appliance dealer will have a fan you use the blade on old one just pull it off with an allen wrench if ice maker lines are leaking use two wrenchs and retighten if cracke get a new icemaker line kit menards home depot etc.
Feb 13, 2013 | Refrigerators
Minimal flow of water and ice from dispensers and water leaking onto floor under the frig.
Hi merlaine273,
If you're experiencing water leaks outside the refrigerator, it is often caused by the drain pan. There are some ways on how to correct this issue, either you clean the pan and reposition the tray. In addition, here are some tips that you can apply to solve this problem. Please follow the steps below.
Before conducting any repair, please remember your safety. Unplug the machine or shut off the power at the breaker panel to avoid any electric shock.
1. Remove the drain pan and clean it with a warm soapy water or water and baking soda.
--> the drain pan is located at the bottom of the refrigerator behind the front grill.
--> Please remove the grill which snaps into place. Hold the drain pan while pulling slightly upward and forward.
2. If you noticed that the pan is too closed to the compressor please reposition the tray.
3. You may also try to check water invelt valve. It is located behind the refrigerator. Look for a water supply line coming into the valve and turn it off at the source. Now disconnect the supply line. It has screws so you need to remove them.
4. The water inlet valve is connected by two wires. Before disconnecting the wires please label the wire placement on the water inlet valve.
5. The wires are connected to the terminal with slip on connectors. Firmly pull the connectors off of the terminals ( don't pull on the wire ). You can use a pair of needle-nose pliers to remove the connectors. Please check if the connectors and terminals has corrosion. If corroded they should be replaced.
Hope it helps.
Thank you for using FixYa.
Mar 24, 2011 | GE Profile 26.6 cu. ft. Side-by-Side...
GE Profile leaking onto floor
Clean the drain pan and drain line in the back of the freezer section behind the cover underneath the evaporator coil. (hint: use turkey baster with hot water) Make sure water drains when you pour it in. If it doesn't - also clean drain tube on the back of the unit behind the cover. When done - put the tube exactly where it was.
Good luck! :)
Vlad
First Choice Appliance
Apr 19, 2010 | GE Profile TPX24PBDCC Side by Side...
There is a little water leakage or drainage slowly seeping from the under of the fridge, it has happened before. It streams out for a while and appears to stops when we turn off the ice maker. wj=hat could...
The drain pan should be removed and cleaned at least once a year. The drain pan is located at the bottom of the refrigerator behind the front grill. Remove the grill, which snaps into place. Grasp the drain pan while pulling slightly upward and forward.
Clean the pan with warm soapy water or warm water and baking soda.
If the pan rattles when it is replaced, it is too close to the compressor. Simply reposition the tray.
Another cause of outside leaks will be the inlet lines. If you have an ice-maker, check the water supply lines, going into and coming out of the water inlet valve. The hoses may be loose here, thus,causing the leak.
Dec 10, 2009 | Kenmore Refrigerators
Leak from refrigerator bottom when dispensing water
Good day,
The water supply starts at the dispenser, runs thru the door to the door's bottom where it connects to a swivel connector.
From there it travels under the machine and back into the fresh food compartment to a reservoir located behind the crispers where it is chilled.
It comes back out and travels to the filter system if you have one, and from there to the water valve located on the back rear of the machine.
One of the plastic lines or a fittings is leaking.
It's a look-see repair. Should be one person drawing water, while a second should be looking with a flashlight.
Nov 20, 2009 | Whirlpool Refrigerators
Water is leaking under the refrigerator. This is
If everything else on the refrigerator seems fine (freezing and refrigerating are fine), then you probably have a problem with the drain hose under the evaporator coil. On frost free freezers, there is a heater that comes on periodically to melt off all the frost on the evaporator coil, and that defrosted frost (water) goes out a drain hose and collects in a pan at the back of the unit where it can evaporate.
Either the drain is clogged with ice inside the freezer, (in which case you might notice ice building up on the bottom of the freezer, or perhaps water collecting on the bottom of the refrigerator if your freezer is on top) OR there is something wrong with the pan at the back of the refrigerator, like a crack, or it somehow got tilted so that the water pours out. It is located behind the panel on the back.
Or perhaps, and this would really ****, the water line that supplies your ice maker is leaking, if you have one. If you do have one, I would recommend turning the water line to the fridge off before pulling the fridge out.
Sep 14, 2009 | Kenmore Refrigerators
Kitchen aid refrigerator superba
hi there,
the drain pan is under the fridge behind the kickplate. the kickplate is the vent-line panel located under the door. it's held on by 2 screws. unscrew the screw and remove the kickplate. the drain pan will slide out. careful, as it's probably pretty full.
Oct 01, 2008 | KitchenAid Superba Architect KSCS25INSS...
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
