The TV is almost 2 years old and beyond warranty. The lines have sharp edhes and some are thick and some are thin. The show up as soldi colors matching the colors of what ever was on that channel at that time. The only workaround is to switch off the TV and turn it back ON. This happens in less than 15 mins from startup if watching HD channel or playing a game on PS3. Sometimes, when watching non-HD channels, it doesn't happen for over 1 hour. But,once it starts happening, it gets more and more frequent. At times, the frequency being less than a minute. Is this repairable at a reasonable cost? I had purchased it for $1200 (msot expensive 32" in the market at that time)...
  • juvesaurabh Jul 16, 2009
    Just to add my HDTV is Sony KDL 32XBR4. I would like to get another expert's opinion on my problem.
    FYI, my model is Sony KDL 32XBR4. If that helps? Does it sound like a common problem to fix at reasonable cost or does it seem like an expensive fix?
    President:
  • 2,559 Answers
Sounds like the horizonal hold is bad.
Posted on Jul 16, 2009
  • 580 Answers
You have a video ground loop. This may be caused by a ground problem in your cable system. Since you get this line on other sources ie DVD disconnect the RF cable wire from your TV or cablebox when on that other source and see if it goes away. If it does call your CABLE PROIVDER and they should be able to fix it. If they don't you need to get a ground loop isolator or in line surge protector. This goes in between the RF cable and the cable input of your cable box or TV. Try www.centronics.com model 634 if the cable co. won't take care of it.
Posted on Jul 15, 2009
I have a Bravia KDL 40BX421 that suddenly has green vertical lines on the bottom 1/4 of the screen. These lines are in a background bar that is mostly a reddish shade.
Thin vertical lines cover screen on Samsung LCD - AVS Forum ' Home ...
www.avsforum.com/.../1127410-thin-vertical-lines-cover-screen-samsun...
Mar 7, 2009 - 30 posts - ‎25 authors
Hi guys, Ive had this TV for about a year now - all of a sudden thin vertical lines havecovered my screen (show in link below) No matter what ...Missing: 40bx421
TV Repair Help for Vertical & Horizontal Lines on Your TV ...
? 2:47
https://www.youtube.com/watch?v=b0sI7LB4cZE
Apr 25, 2014 - Uploaded by ShopJimmy.com
TV Repair help with troubleshooting lines on your TV Screen. ... hi i have a sony bravia mdel # KDL46EX523. i have horizontal multi colored lines ... My TV has the following symptoms: - Horizontal lines from top to bottom of .... thick(like 1-1/12 inch) and a couple of green vertical lines next to the black one.Missing: kdl ‎40bx421
Flat Screen TV Has Lines Going Through Screen - Possible ...
Dec 16, 2015 | Televison & Video
Colored line in sony klv-32Bx300
It would probably cost more to fix than it would to buy a new one.
Mar 14, 2014 | Sony KLV-32BX300 SERIES BRAVIA LCD...
Sanyo flat screen tv about 2 yrs old has thin colored horizontal lines down the right side
Nothing you can do about that...get used to it or change the TV.
It's a defect in the panel that can't be reliably fixed.
Feb 15, 2013 | Sanyo DP46848 LCD TV
My Sony Bravia KDL 40WL 135 TV has been flashing strange colors for awhile; today screen is black with a thin blue line across the bottom. No sound. Any help appreciated.
The vertical output section circuit has the fault. Contact any experienced service technician. This is not a user repairable fault.
Aug 10, 2012 | Sony Televison & Video
My Sony KDL-32XBR4 has vertical lines for 5-15 minutes on startup
I have a 46 inch , Sony XBR 4 tv . The past week there has colored vertical lines that appear on the screen for about 10 minutes . Then they go away . What is the problem and solution?
Jul 10, 2009 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
Sony 40 inch lcd television
Call Sony!! It Will get worse!!! The panel has ribbons that have fine wires that are used to show each line of information on the screen. Either the panel is going or the wires are loose. Either way, the panel needs replacing. Just hope to God it's under warranty or if not, sony will help you out with a buy-out.
Aug 07, 2008 | Sony KDF-E60A20 60 in. LCD HDTV
Sharp Aquos LC-32D41U
The unit has bad drive ic's,which is part of the lcd panel.It is not cheap to fix.
Feb 28, 2008 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Line accross top of the screen with flashing black and white boxes
Thin white dashes on top of screen is PERFECTLY NORMAL. It is nothing wrong with the TV, it is the broadcast. What you are seeing is the very bottom of the timecode running. It doesn't happen all of the time or all channels. It usually happens with old 4:3 commercials predating "Digital TV." This is mentioned in your Users Manual. You should be able to adjust the horizontal/vertical position in the menu settings.
Jan 02, 2008 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Televison & Video Logo
91 people viewed this question
Top Televison & Video Experts
