Question about Hoover F6212-900 / F6215-900 SteamVac Agility Upright Vacuum
Brushes don't spin
Everything on the mackine works perfectly except for the fact that the brushes will not spin i have tried the on off switch but they still wont rotate they just stay locked in place
    Brigadier General:
  • 4,088 Answers
Remove the bottom cover and replace the broken drive belt. Check that the brush will rotate freely--likely everything is jammed with hair and dust. The brush assembly should just lift out of the case and the end bearings will pull off. The brush needs to be removed to install a new belt anyway. There should be a diagram that shows how to install the belt (it has a half-turn twist).
Posted on Jul 15, 2009
Dyson DC28 head/spinner does not spin in Bare Floor setting only
The brush roll is not supposed to spin when it's on bare floor setting
Mar 11, 2018 | Dyson Vacuums
EL8505 brush will spin at only certain handle positions. The brush is unhindered and the belt is in position and in good order. The vacuum feels like it is sufficient. When the brush is not spinning the...
Many vacuums have a switch positioned somewhere by the pivot point that is pressed when the catch is released and the handle taken out of the 90 degree storage position. I haven't worked on an EL8505 but I have fixed a couple other brand / model vacuums that were behaving the same way you describe in your problem. In most cases it is either a perfectly good switch that had moved out of position because the framing it is supposed to sit in is broke or worn down or a bad switch that only works when the plunger was in just the right spot.
The link is a parts blowup of your vacuum and I think A-26 is the part you need. It appears to have both the bracket and the switch in one part. Make sure where it mounts doesn't have any damage preventing it from staying in the right place and alignment.
Electrolux EL8505A Parts List and Diagram eReplacementParts com
Mar 23, 2014 | Electrolux EL8505A Bagless Upright Vacuum
The spin brushes on my hoover steam And vac don't
Either the pin on the brushes that attaches to the motor shaft is broken, or the motor is dead. Did you check the switch on the front of the unit to make sure it wasn't turned off?
May 16, 2012 | Hoover Vacuums
The spinscrub brushes won't spin when any pressure is applied to the machine. What is the reason for this?
There is an air inlet screen behind the brush indicator....if this is plugged with hair and debris, this will cause the brushes to stop spinning....also, if the mackine is upright or if the recovery tank is not in place, then the brushes will not spin.
Oct 16, 2009 | Hoover F5906-900 Upright Steam Vacuum
Beaters stop when vaccuming rug...didn't when new
I believe you need to change the belt that drives the brushes. When it gets stretched out, it will just spin on the axle of the motor or spin on the brush and smoke.
Jim
Jun 01, 2009 | Dyson DC07 Animal Bagless Upright Cyclonic...
Brushes are not moving at all
There should be a switch to adjust the speed of the brushes. if it is off the brushes will not spin. The only time the brushes are supposed to spin is when the handle is tilted back, and the switch is on.
I’m happy to assist further over the phone at https://www.6ya.com/expert/robert_b96ba3f038cf317c
Mar 08, 2009 | Hoover F5866-900 SteamVac Deluxe Wet/Dry...
Roomba keeps saying clean brushes yet are clean!
Make sure you take off the little cap at the end (the one that spins -- just grab it and pull it straight off) and clean under it too. The rest of the brush may look perfectly clean but what happens is that hair gets stuck under spinning cap and, like a slowly growing washer, it pushes the whole brush toward the gear box. When it gets pushed over enough, the large yellow ring starts to rub against the side of the brush deck making it harder for the motor to turn the brush and you get that "remove and clean brushes" message.
Jan 30, 2009 | iRobot Roomba 530 Robotic Vacuum
Brushes not spinning....
My status light came on, the vac beeped twice and stopped. I noticed my brushes weren't spinning. I took an eyeglass screwdriver and took off the center screw that holds on the brushes. I cleaned the shaft that the brushes spin on. replaced brushes and it works great! I just did this now and it is still running. my status light problem is fixed my roomba is 4 years old and I am on my 2nd battery. Seems to have fixed the problem. FYI it was wrapped with hair, dirt and it was greasy.
May 29, 2008 | iRobot Roomba 4210 Bagless Robotic Vacuum
Hoover F6212-900 / F6215-900 SteamVac Agility Upright Vacuum Logo
384 people viewed this question
Top Hoover Vacuums Experts
Jim Parker
Jim Parker
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
