Question about Mitsubishi WS-65807 65" Rear Projection Television
When turning on the TV the color on the picture is Green and Red distorted picture.
After one hour or so it clears up but goes back to off color on and off.
SOURCE:
dalestv80
  • 3 Answers
SOURCE: Mitsubishi WS65905 Projection TV
convergance ics and sometimes resistors go bad. call a repairman...
Posted on Aug 01, 2007
  • 1153 Answers
SOURCE: WD-52525 too much green and picture is not clear...what can i do to fix it
. Suspect the FMT PCB part # 930B924002. Supect the DM PCB part # 934C116002 if green tint
Posted on Aug 25, 2007
SOURCE: Distorted picture and multi-color words
You need to resolder the convergence chips. This is a very common issue with this line of TVs.
Hometheaterspot.com's Mitsubishi forum has detailed posts on how to fix this. Just serach for "55809 convergence" and you should find the info you need.
Posted on Dec 20, 2007
ctf1800
  • 4402 Answers
SOURCE: Mitsubishi WD52525 DLP Projection TV
Mitsubishi TV troubleshooting
Here's something that might also be useful. After you turn on the set, and get the regular red blinky lights, hold down the Device and Menu buttons together for about 5 seconds.
The Power light will start to flash in a two digit sequence.
For example, 3 flashes, then 7 flashes = 37.
Here are the error codes, and the corresponding problem:
12 = No error detected, check power supply.
32 = Lamp Cover is open.
33 = Air filter cover is open.
34 = Lamp abnormality
36 = Light Engine (DMD or Lamp Fan stopped)
37 = Exhaust or Lamp Ballast Fan stopped
38 = Lamp Temperature High
39 = DMD Temperature High
41 = Short is detected
44 = DVI cable between FMT and Engine disconnected
Posted on Jan 29, 2008
  • 927 Answers
SOURCE: big screen showing double and red ghost color
Go into your service menu and try to adjust the convergence, if it does not adjust, the IC's ( chips) are bad in that circuit. Call a local factory authorized dealer to service your tv. The cost should run around $450.00. Good luck.
Posted on Apr 03, 2008
The color on our Sony tv is now distorted. The
if this is an older tv and your state might have changed to digital programming then i would suggest trying to look at the back of the set and see if you have anything to fix this problem or you might want to CHECK AND SEE IF YOU HAVE VIDEO ON or CABLE on or TV on. Sometimes if you have Antenna switch to cable then your channels would be red and picture distorted. change the antenna to air for tv. or from tv to cable.
Feb 24, 2010 | Televison & Video
Picture is distorted for about 15 minutes after turning TV on. Was eventually clearing up but lately picture never gets completely clear.
Projection sets have two very common problems.
The first common problem is convergence
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
Here are some of the most common problems with these sets...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Dec 23, 2009 | Toshiba 42H83 42" Rear Projection...
F25216bc RCA 25 inch TV. Color is distorted with a heavy red tint
You either have a bad CRT or a Shorted Red Output IC/Transistor. One other possibility is if
someone turned the Screen Control down if it is accessible from the back of the set.
Hope this helps,
Skyassc
Jun 22, 2009 | RCA F25216BC 25" TV
Green/Blue distorted Colors
Color issues are harder to solve without seeing the problem. It sound like the red amplifier on the crt board is bad. Is there any red in the picture at all? If not, that will be you problem
Nov 26, 2008 | Televison & Video
Double picture
*Screen Looks 3-D
*Colors wont align
Nov 07, 2008 | Apex Digital GB51HD09 51" Rear Projection...
Sudden color/picture distortion
you have a shorted green CRT that is affecting the other crts the short is internat to the crt that leaves what is called retrace lines. if the set is more than three years old then replace all three guns.
Feb 25, 2008 | Samsung TX-R3080WH 30" TV
Color distortion
Problem on CRT board, this is the board on the back of the tube. It has a open transistor for the green.
Oct 08, 2007 | Toshiba 32AF43 32" TV
Picture goes out periodically
Sound like color problems, could be convergence going out. Not quite sure of yellow color, but you could be loosing one of the 3 colors red blue green, this could be why you see yellow.
Sep 24, 2007 | Sony KP-61S75 TV
No Picture
Did you have color problems in past? Most of these sets have convergence problems. Amps goes out. But you should have seen some type of distortion from color, red,blue, green. If no color problems then maybe vertical ouput out or horizontal output bad.
Sep 09, 2007 | Hitachi Director's Series 65XWX20B 65"...
Green wave-like color distortion over reds
do you happen to have any speakers of any size within about 3 feet in any direction of the tv?? move them if so, I have large speakers about 5 feet from my tv at home and i still get some distortion once in a while with red and dark green streaks.
Aug 15, 2007 | Sony WEGA KD-34XBR970 34" TV
Open Questions:
See all Mitsubishi WS-65807 65" Rear Projection Television Questions
Mitsubishi WS-65807 65" Rear Projection Television Logo
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
