Question about Aqua Vac Tiger Shark
Tiger shark has bubbles coming out of top but will not move
Bubbles come out of the top but will not move
  • Albhms69 Aug 25, 2013
    I had the same problem. I noticed when I was cleaning once there was a screw at the bottom below the basket when i took the cleaning basket out. I noticed on the side opposite where the electric connection comes into the unit a missing screw. I found the matching nut and was able to screw it back in with a flat tip screwdriver and this screw turns the connections which turns the rudders. It works fine now. I wasted money on buying a power unit.
Something is caught in the tracks that make it move. Look under the blue track that move it. I had the same problem and found a rubber swim mask headband all caught in the tracks. I had to take the side panel off...6 screws on the inside you can see when you take the filter out and removed it and now it works fine.
Posted on Aug 10, 2009
The shark moves in the water but does not pick up anything
contact the manufacturer we have no info on that one
Aug 30, 2015 | Aqua Vac Tiger Shark
Tiger shark move slowly
something jammed in the tracks
Jul 18, 2012 | Aqua Vac Tiger Shark
Tiger Shark moves slow
no tension need to replace tracks
Jun 25, 2012 | Aqua Vac Tiger Shark
My tiger shark does not work!! I have power to the transformer and shark, but it won't move. I just spent $400.00 at my pool store to get it fixed, they put new wheels, filters, and a new cord and...
The motor pack...
Was the store able to scan the motor to pull out operational info? Was it water tested prior to being returned to you? Perhaps the store will make accomodations to get it returned and repaired correctly?
John
Jul 23, 2011 | Aqua Vac Tiger Shark
I have a tiger shark one and half years old. it turns on, can hear the motor going and it will move and clean regularily anywhere from 20 sec to 5 minutes. but then will get stuck in one spot. the motor...
The motor pack is having trouble and will need to be replaced (most likely). For help finding a service center that can perform the inspection and repairs check Hayward's site at http://www.haywardnet.com/locator/ and fill in the information requested. Be sure to select product repair or service and robotic cleaners to limit the response to those able to fix these cleaners. We are in S.E. Michigan and are one of the centers for Tiger Shark cleaners.
John
Oct 10, 2010 | Aqua Vac Tiger Shark
My tiger shark pool cleaner spends a lot of time at the top of the water line. How can I adjust it so it does not climb so far?
the tiger shark is designed to climb but you can adjust the weights to keep it down. check out http://www.aquavacsystems.com/Weights-and-Floats_ep_31-1.html
for more info and specs of your unit. good luck
The Pool Tech
Jul 02, 2010 | Aqua Vac Tiger Shark
Tiger shark just doesnt clean very well
I the filter is not very clean the pump will not push hard enough to hold the tracks onto the walls. Try running without filter in a very clean pool for a few minutes to see if it solves the climb walls replace the filter and clean the unit
May 26, 2009 | Aqua Vac Tiger Shark
Tiger shark will not move
The motor that drives it forward and back is seperate from the fan and is defective unless your stuck on the main drain the motor unit needs replacing.
Mar 14, 2009 | AquaVac Tigershark 2 Commercial Vac with...
Aqua Vac Tiger Shark Logo
569 people viewed this question
Top Aqua Pool & Spa Experts
Larry Maranto
Shehu Pro
Shehu Pro
Ben Clacy
Ben Clacy
Level 1 Expert
Are you an Aqua Pool and Spa Expert? Answer questions, earn points and help others
