Question about Vapor 2300 LadyBug XL Steam Vacuum
My Ladybug 2300 XL says it needs water and will not operate even though it is full. i suspect the pump isn't working. What do I do?
  • jsumner232 Jul 15, 2009
    i can't seem to find my instruction manual. Do you know where I can get one on line?
  • 691 Answers
Call this number, they sell all parts for your machine 18002379199, your unit have three year warranty on the them, if its still has warranty left contact the manufacture and they will fix it. not not attempt to fix it your self under factory warranty or you will void it. sound like your unit became defective.
Posted on Jul 16, 2009
  • 19,396 Answers
It is not the pump. The ladybug has a water level sensor that is faulty.
Ledybug are manufactured in china, there should be a customer support number on the user manual. Parts are usually available from manufacurer.
Regards.
Posted on Jul 15, 2009
What would cause my shop vac series90pn to quit working while picking up water
The best thing for a basement that is vulnerable to flooding is a small sump with a permanently wired automatic submersible pump in it. Such pumps are relatively cheap and available in many qualities.
While such an installation will not keep a basement dry it will ensure the water level rises only enough for the majority to flow into the sump and be pumped away without you needing to do anything.
Wet vacs of my experience either have a float valve to prevent water ingress into the motor or a switch to cut off the power if the level rises too high.
Many such vacs have a powerful motor generating much heat and are only suitable for fairly short duty cycles. When used continuously the internal heat build up can distort plastic and melt thermal safety fuses.
It is impossible to guess what the trouble might be and that will only be revealed by checking. With vacs the first suspect is the power cord and the second is the switch...
Jun 26, 2014 | Shop Vac Vacuums
Repair hoover steam vac F7210
Fixya does not make servicing recommendations.
Jul 23, 2017 | Vacuums
The automatic drain hose is hooked up to the back of the unit, but when the bucket is full, the automatic pump does not work. The automatic pump should come on and empty the bucket, but it does not come...
Any automatic pumps operate off a swith that is turned on when the water rises. They normally have some type of ball lift, that will raise the switch when water is high and then drops with the water and shuts the pumps off. It sounds like yours is stuck and not activating the pump.
Jul 06, 2011 | Vacuums
I have a Bissell ProHeat Turbo 2x, it isn't mixing the water & cleaning solution and isn't spraying. What do I do?
Isn't Spraying:
Possible Problems->Solutions
-Water Tank may be empty-> Fill Heavy duty bladder with hot tap water.
-Formula Tank might be empty-> Fill with Bissell fiber cleansing formula for cleaning.
-Tanks may not be seated completely-> Turn power off and reset the tanks.
-Pump may have lost prime-> Turn power off, then on again, wait one minute then depress the trigger
You can also contact Bissell at: 1-800-237-7691 begin_of_the_skype_highlighting 1-800-237-7691 end_of_the_skype_highlightingto help you out on why the cleaning solution and water aren't mixing, but first try fixing the first problem, you never know, it might cure the first one. :)
Hope this helps!
Remember to give me 4 Thumbs Up
for all the hard work to the Community! :D
~~Dayminner
Jun 04, 2011 | Bissell Vacuums
I have an oreck xl shield scrubber and cannot remove the water tank. help
Make certain the yellow retaining latch is DOWN. Sometimes it LOOKS like it is all the way down when it isn't. Chances are, the tanks outlets were not properly greased, causing an o-ring to stick or roll off the seat.
Simply push down on the tank HARD at the top of the handle. You may have to strike it a few times but it will come off. It is best to do so in the upright position, rather than with the wheels extended. Once it is off, check the o-rings, re-seat if needed and apply some white grease to enhance the seal and prevent future sticking.
-Jeff
Oreck owner
Sep 06, 2010 | Oreck XL M900A Upright WetDry Vacuum
Machine will not dispense water even though reservoir is full. Soap is not dispensing either.
check the spray nozzles on top of the brushroll. these often clog. If those are clear could most likely be the pump as they fail frequently.
Jan 29, 2010 | Bissell 9500 ProHeat 2X CleanShot Upright...
Bissell Pump Weak?
Often times I see the pumps clogged with soap when acting like you described. This can cause a pump to be weak. Pressure builds up whe you stop squirting water but tapers off quickly. A few times I've been able to get water flowing good but most times have to replace the pump.
Mar 02, 2017 | Bissell 1699 ProHeat Clear View Upright...
T2100 S Ladybug Canister Steam Cleaner
Visit the Ladybug Ladybug 2200S Vapor Steam Cleaner page and scroll to the bottom. There's a link that says, "Download owners manual."
Oct 20, 2008 | Vapor T 2200S LadyBug Canister Steam...
Steam cleaner
Most upright steam cleaners like Hoover and Bissell, you put in the hot water, bissell does have a heater, but it only helps get the hot water a alittle hotter. But a model number would help.
Dec 12, 2007 | Vapor PC2200 Ladybug Steam Vacuum
Vapor 2300 LadyBug XL Steam Vacuum Logo
75 people viewed this question
Top Vapor Vacuums Experts
richie46
ray gallant
Tom Chichester
Are you a Vapor Vacuum Expert? Answer questions, earn points and help others
