I have a first generation ipodnano witch i brought in america a couple of days after they were released. i used my ipod for quite a while and all was fine, i then brought a new phone a Sony Erickson walkman witch i then used instead of my ipodnano so my ipodnano sat on my bed room self for numerous months. Just reasenly my phone has stoped working as well as it did before so i went to use my ipod but when i did it wouldn't turn on. I have tried to restore my ipod several times but it will not work and i don't know what is wrong with my ipod. It will not turn on, it will not play songs there is no glimmer of life coming from it until i plug it into the pc, itunes and my computer will reckognises there is an ipodplugged in and itunes will stat up, a couple of seconds later the little icon in the corner pops up telling me what songs i have on it. Still my ipodnano does nothing it is very stressful as i haven'tdroped it or anything like that i just left it on my shelf turned off for a considerable amount of months.
Please help me i need my ipod back again and have realized how much i have missed it
Thank you
The problem may be battery charge. Leave it plugged into the computer for 6 hours, and then try it. If this does not work, the best thing to do may be to call apple for further help.
HEres what u have to do if ur Ipod nano froze on main screen try turning it off then shorten off the bateryes or if that does not work dont touch it for some hours if u do this then it will work if it doesnt work tell me
The ipod nanos the smallest product in the Apple iPod line. The fourth generation
Nano comes in two different capacities, each capable of holding
thousands of songs.
Capacities
The fourth generation iPod Nano comes in 8 GB and 16 GB models. The 8
GB version can hold 2,000 songs, and the 16 GB version can hold 4,000
songs.
Tips
Song capacity estimates are based on music encoded in Apple's
proprietary format at a standard, average bitrate. The higher the
bitrate, the better the quality. Songs deviating from Apple's standard
(for example, CD-quality music or high bitrate MP3s) will use more disk
space.
History
Nano's predecessor, the iPod Mini, was released on January 6, 2004, and
was available with a 4 GB hard drive. The Nano was first released on
September 7, 2005, and was the first iPod to use flash memory. It was
first available in 2 GB and 4 GB versions. The fourth generation Nano
was released on September 9, 2008.
Size
The fourth generation iPod Nano is 3.6" tall and 1.5" wide.
Video
The third generation Nano, released on September 5, 2007, was the first
Nano to feature video playback. Storing videos on Nano can dramatically
reduce the amount of songs it can hold.
once the battery dies completely...plug it to pc (itunes should pop up also) , when itunes comes up check for update of ipod it might need it....this shall stop the ipod from freezing up...have fun and enjoy
You have to reset your iPod. (Note: This is for the 3rd generation iPod Nano)
To reset iPod nano:
1 Toggle the Hold switch on and off (slide it to HOLD and then back again).
2 Press and hold the Menu and Center buttons for at least 6 seconds, until the Apple logo appears.
If iPod nano won’t turn on or respond
- Make sure the Hold switch isn’t set to HOLD.
- The iPod nano battery might need to be recharged. Connect iPod nano to your computer or to an Apple USB Power Adapter and let the battery recharge. Look for the lightning bolt icon on the iPod nano screen to verify that iPod nano is receiving a charge.
Turn repeat off in the menu.
Setting iPod nano to Repeat Songs
You can set iPod nano to repeat a song over and over, or to repeat a sequence of
songs. iPod nano repeats songs within the list you choose to play.
To set iPod nano to repeat songs:
m Choose Settings from the iPod nano main menu.
â To repeat all songs in the list, set Repeat to All.
â To repeat one song over and over, set Repeat to One.
To turn repat off, go to Repeat off.
If your iPod nano won’t turn on or respond
1) Make sure the Hold switch is off.
2) If that doesn’t work, connect iPod nano to your computer’s USB or FireWire port. Your
3) If that doesn’t work, your iPod nano might need to be reset.
a) Toggle the Hold switch on and off (set it to Hold, and then turn it off again).
b)Press and hold the Center and Menu buttons for at least 6 seconds, until the Apple logo appears.
4) If that doesn’t work, you might need to restore iPod nano software.
WILL NOT TURN ON.
WHEN PLUGED INTO COMPUTER A HOURGLASS APPEARS
