TLA -01911C HD LCD 19" TV with ATSC tuner will not turn on. Polaroid will not help. Is there any thing I can try?
  • kew1956 Jul 16, 2009
    Tried to follow advice by unpluging and holding power button. No luck. Any other suggestions other than service man? Have been told that the repair will be more than the initial cost. Polaroid wants to charge me shipping to return tv and then also $175.00 for a used replacement.
  • 3,230 Answers
1. There'll be a fuse in the plug, so check that's not blown by replacing it with one of the SAME type
2. Don't assume your mains socket is working. Test it with another appliance, and plug your TV into another socket that you know is working.
Sometimes a power surge or fluctuation will cause a digital TV to lose its programming (memory). Try these steps to see if will will help (works sometimes on some brands of TVs).
1. Unplug the TV and leave it unplugged for about 10 minutes.
2. After that time, and while the TV is still unplugged, press and hold the main Power On/Off button for about 10 seconds. Release the button.
3. Plug the TV back in and attempt to turn it on normally.
If it powers up normally, the problem is fixed. The TV should then start automatically seeking active signals (channels) from your connected input signal source. If it doesn't, go to the Setup (or Settings) menu and select the Channel Search (or auto program) mode.
If it doesn't power up, press and hold the main Power On/Off switch for up to about 10 seconds (or until it turns on, whichever comes first).
If it still fails to power up, then your TV most likely has an internal fault (such as a blown fuse or power protection circuit, or a blown power supply capacitor) that is preventing it from powering up. This would have to be diagnosed and repaired by a reputable service technician.
Good Luck!!
Thanks
Posted on Jul 15, 2009
  • Mukesh Kumar Jul 16, 2009
    Well, it seems power failure, it needs repair.
Polaroid monitor doesn't see signal from DISH
try to reboot dish gateway(modem)
if this helps please take time to rate
Feb 01, 2013 | Polaroid 19 inch Widescreen 1080i LCD HDTV...
Need a manual for Polaroid TLA-01911C
http://www.hdtvreview.com/Polaroid-TLA-01911C-hdtv.html
May 07, 2011 | Polaroid TLA-01911C TV
PROB LEM WITH POLAROID TLA-01911C
The white screen and nothing else usually indicates a failure of the filter capacitors in the power supply board. When these capacitors go out the voltages are not correct so the TV can not power up right. You can rebuild the power board by replacing the bad capacitors and this should bring the TV back to life. Here is a link to a repair guide for this power supply board.
http://www.ccl-la.com/blog/index.php/repairing-a-polaroid-tla-01911c-with-a-bad-power-supply/
I hope this helps,
BuddyMc
Dec 28, 2009 | Polaroid TLA-01911C TV
Polaroid TLA-01911C TV - I seem to have the same
You probably have a bad inverter PCB. It is a skinny board by itself over on the left side of the back of the panel.
Oct 12, 2009 | Polaroid TLA-01911C TV
I have a Polaroid TLA-01911C. I switched from cable to air and did a scan, but no channels are found. I even hooked up an antenna with no channels found. Any suggestions?
Ether the antenna is not good enough for the digital signals that are now brodacasted or you got a bad digtal tuner in this unit. i would buy a antenna from radioshack special for this TV.
Jul 18, 2009 | Polaroid TLA-01911C TV
Will Not Find A Signal Polaroid HD 15" TV - Model TLA-01511C
same (tla-01911c) issue when trying to watch over the air brodcast try rescanning the channels that normally works for me
i got direct tv basic set on my S-video input so i only need over the air when the sat is down (i.e: storms, wind, snow, ...)
May 15, 2008 | Polaroid TLA-01911C TV
Need code
I called one-for-all and got a repair number and then sent the remote to them to have the codes added.
Dec 13, 2007 | One For All URC4220 Remote Control
Televison & Video Logo
29 people viewed this question
Top Televison & Video Experts
Electro Med Services...
