Question about Garden
The pull start mechanism does not work. When I pull the rope, the parts that are supposed to turn the motor do not engage. What do I do?
#1 Taper
  • 1040 Answers
SOURCE: cannot get my trimmer started.
Tom, it sounds like part of the rope has jumped off of the spool. There should be a small piece of plastic with a screw holding the spool in place. It may have worked itself loose.
Jim
Posted on Jun 07, 2009
suzukiracing
  • 200 Answers
SOURCE: Craftsman Model 21032: Pull start does not engage.
The plastic gear is probably stripped and will need to be replaced.
Posted on Jul 19, 2010
  • 97 Answers
SOURCE: My Poulan Pro 150E pull cord will not engage to
Sounds like the starter dogs are broken. They are little plastic teeth that engage to turn the engine when you pull the cord. You'll need to replace the whole starter assembly to fix this.
Posted on Sep 02, 2011
  • 28 Answers
SOURCE: Weedeater Troybuilt TB65SS : the pull rope is
Did you replace the rope? how much rope was used? and was the flywheel and rope clutch alligned properly on installation?
Posted on Jun 26, 2012
  • 2239 Answers
SOURCE: My husqvarna 125L has an issue, when I pull the rope to turn the engine the connecting mechanism slips somewhere and the power I alpply to the pull rope does not get through to the engine. I have take
This was a pretty common issue with the E start, the problem is with the spring and the siver disc it fits into ( the spring sits into a hole in the disc, what happens is the spring has come out of the disc ) the disc and spring have been improved to give a better fitment, you need to insert an allen key into the hexagon fixing nut and unscrew it, you will need to lock the engine to undo it ( normal r/h thread ) you the need then to order and fit spring part no. 545160301 and disc 530016475
Posted on Jul 16, 2012
Sometimes when I try to pull start my Stihl FS 36 weedeater it just free wheels and other times it will start. What could be causing this?
The mechanism is beginning to wear out. When you pull on the rope, the turning action pushes pins out from the center of the rope pulley that engage to turn the engine. These pins wear out and will eventually fail, not engaging at all. These pins may or may not be available for purchase at the small engine parts store near you, but the entire pulley assembly with new pins usually is.
Jul 04, 2017 | Cars & Trucks
Stihl 170 does not start with brake engaged, but will start easily with brake off. Unable to pull rope with brake engaged.
not suppose to start with brake on --the brake is a safety shut off it stops the clutch drum
Apr 24, 2017 | Stihl Garden
Lawn mower rope pully repair
if rope to long then pull out recoil one turn hold rope tight pull knot out of handle down rope rope to were you are holding it tie a knot in rope slowly let rope go back in recoil then pull it all the way out should fit now cut off excess rope but also if you have a long rope it is suppose to mount on handle should be a mount hook for on the handle
Sep 05, 2014 | Garden
Why is the rope starter not engaging the motor how do i fix it or do i need to return it
Try pulling the rope slowly until the starter engages the flywheel (you should feel when it engages) then give a good pull to start the engine. Don't give the rope a quick hard pull in one motion. You will probably need to do this three or four times before the engine starts. Of course push the primer button the number of times called for in your engine instructions before trying to start the engine. If you still don't think the starter is engaging the flywheel if would take it back where you bought it if it's new.
Jun 20, 2014 | Troy-Bilt TB146 EC 4-Cycle Garden...
What causes the ignition switch to keep the starter engaged?
Hi Melissa,
When you twist the ignition key from the "on" or "run" position to the start position, three things happen to start the engine. They are: a) the starter solenoid is energized [the starter solenoid is needed because the ignition switch has small wires capable of carrying 20 or 30 amps at the most and the starter motor will require hundreds of amps to spin - the solenoid can safely switch this huge amount of current], b) the starter drive gear solenoid (electro-magnet) is energized and physically causes the starter drive gear to move and engage the teeth on the engine's flywheel, and c) the starter motor spins the drive gear. The spinning drive gear turns the flywheel - simulating a very slow running engine. This sets up the timings for spark plug firing, fuel intake, compression, combustion, exhaust, etc. Without spinning the engine the timings wouldn't exist. The same happens when the starter rope is pulled on a typical lawn mower engine - except the starter is the person pulling the rope and the electro-magnet solenoid drive gear is the mechanical, spring loaded spool of rope (that magically is coiled up after pulling to start the engine.
Once the key is released, it defaults by spring action to the "run" position. The run position provides power to the ignition system to provide spark, etc. but electrically disconnects the power from the starter solenoid (and starter motor and drive gear solenoid as a result).
If the starter remains engaged after the key has been released from the start position (and the key moves back to the run position as designed), it could very well be a faulty ignition switch that is failing to open the electrical connection to the start solenoid. You *may* have some success by spraying a liberal amount of "electrical contact cleaner" directly into the key opening on the ignition switch. It will clear dirt, grime and other stuff that doesn't belong in it - so it may drip out very dirty - that means it's doing its job. Work the key in and out of the ignition and twist back and forth while spraying into the lock. With any luck, you'll clean the contacts enough so that it works properly. Never spray graphite or lubricants into the ignition switch - those products can be used on door locks only.
I hope this helps & good luck!
Feb 14, 2013 | Ignition System for Hyundai Sonata
My Poulan Pro 150E pull cord will not engage to start the weed eater. The rope comes out adn retracts back with no problem, but there is no pressure on the clutch to cause the motor to start. There is...
Aug 26, 2011 | Poulan/Weed Eater No. Te475 952711797 17"...
I have a Yard Machine Lawn mower by MTD it has a briggs and stratton engine. The pull cord pulls, to easily I might add, but will not start the lawn mower. It doesn't seem to engage the motor. What might...
If you think the rope pulls too easily the engine may not have enough compression. Consider doing a compression test or a leak-down test on the cylinder.
Oct 23, 2010 | Mtd 22" Yard Machine Push Mower
Cannot get my trimmer started.
Jim
Jun 07, 2009 | Echo Garden
I have 8hp troybilt horse rototiller. when i pull the starter rope, it doesn't engage. so i took it apart and i see that the place, where there are some ball bearings that are supposed to engage and turn a...
the pully teeth that you are tallking about can easily be sprayed with WD-40 or equivellant. Than keep working it and it WILL eventually come loose. I have worked with small engines for 10 years. This should solve the problem
May 09, 2009 | Troy-Bilt Garden
Door opener will not engage as mechanism moves along the chain track
Make sure the rope hanging down has not been pulled. If it has the door has been disengaged from the opener. You can correct this by flipping the metal part up (that the rope is connectd to) toward the drive track. Then open or close the door using the remote. The track should grab the door again.
Jul 08, 2008 | Sears Craftsman LiftMaster Chamberlain...
Garden Logo
707 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
