Question about Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
The picture on my KDL 32XBR4 gets vertical solid lines
The TV is almost 2 years old and beyond warranty. The lines have sharp edhes and some are thick and some are thin. The show up as soldi colors matching the colors of what ever was on that channel at that time. The only workaround is to switch off the TV and turn it back ON.
This happens in less than 15 mins from startup if watching HD channel or playing a game on PS3. Sometimes, when watching non-HD channels, it doesn't happen for over 1 hour.
But,once it starts happening, it gets more and more frequent. At times, the frequency being less than a minute.
Is this repairable?
  • 2 more comments
  • juvesaurabh Jul 15, 2009
    I need a more detailed explanation. What is the nature of this problem? What would mostly likely be needed to replace?
    I want to know if this a known or documented problem for this particular model? It will be worthwhile to get an input in this direction.
  • juvesaurabh Jul 16, 2009
    Any other opinion on my problem. I am wondering if it could be fixed at a reasonable cost or would it be expensive (in the range of > $500) ?
    Thanks! On another note, if the estimate goes beyond my budget, is it feasible to sell the unit and if so, how can I fetch higher price. I believe the repair shop could repair it themselves and sell it refurbished.
    The reason I think this is because if it breaks down another time, it would be worthless and frankly I've lost faith in my TV . Your genuine input on this would be greatly appreciated!
    Thanks localwonder.. I think that your response was the most detailed.
  • 6,784 Answers
Hi, this is the result of a failing PC-Board(Main Circuit Board-Mother). The actual distortions or, lines are the result of separation that is occurring within the soldered circuitry of the board layout. this is isolated in the A/V(Digital/analog) sector. In most cases, this will be a heat related issue and, the replacement of the PC-Board is recommended. the price of this replacement will be around 300 to 400 dollars tops. the labor will vary from 50 to 80 dollars an hour, depending on the actual repair shop or, in-house repair selected in this case.
***(It is recommended to contact the manufacture of the unit for this Board replacement procedure and part as well. this PC board is not a defective part at all and, there are no known recalls or defective notices issued at this time. this is just a cold solder break(seperation of the metal solder joints)
Posted on Jul 16, 2009
  • 3,037 Answers
Usually its a bad video board with these tvs. Yes it is repairable, usually swapping out the board is the fix. I would have someone with electronics expertise do it to make sure it is done right and so no one gets hurt. You should be able to order the board from Sony or a local tv repair shop if you plan on replacing it yourself, otherwise there are online part sites that you can search for, that should sell it. Let me know how this turns out.
Benjamin
Posted on Jul 15, 2009
  • Benjamin Patri
    Benjamin Patri Jul 16, 2009
    It would definitely be within $500, probably $300ish from a decent shop
    Top Expert:
  • Sony Master
  • 76,649 Answers
It is repairable but the cost to repair this problem will likely be more than the cost to replace it.
2 Suggested Answers
SOURCE: My Sony KDL-32XBR4 has vertical lines for 5-15 minutes on startup
I have a 46 inch , Sony XBR 4 tv . The past week there has colored vertical lines that appear on the screen for about 10 minutes . Then they go away . What is the problem and solution?
Posted on Oct 04, 2010
Sony TV Vertical Lines
sounds like a bad main or digital board--you under warranty with this unit?
Apr 01, 2012 | Sony Bravia KDL-40W4100 40 in. LCD HDTV
I have wavy lines all over my tv...it is not even 3 years old
Hello
IF YOU HAVE A SOLID BLACK LINE RUNNING VERTICALLY THEN YOU HAVE A FAULTY MATRIX INVERTER. IF CENTRAL THE MAIN VERTICAL INVERTER NEEDS CHANGED. LEFT = LEFT VERTICAL INVERTER RIGHT=RIGHT.........
ANOTHER WAY TO GET THIS FAULT IS WORN OR DAMAGED RIBBON/PLASTIC GOING FROM THE SCREEN MATRIX TO THE INVERTER
Hoping this will help in solving the problem, take care...
Jul 03, 2011 | Sony Bravia KDL-26S3000 Television
I have coloured vertical lines covering my Sony Bravia LCD tv screen. The TV is only 2 years old. I have sound but a very distorted picture. The cable company has checked and says it's a tv problem. I will...
I also have a 2 yr old Sony KDL32xbr4 that now has multi-colored vertical lines on the screen. I contacted Sony and they say they have "no known issue" of this sort for this model. I find this rather puzzling since I have found numerous postings on the web. They told me to try the factory reset. Whatever. Might as well have said "don't buy a Sony". 2 years! $1300 for a tv and it lasts 2 years! Makes me sick to my stomach.
Jan 02, 2010 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
Hi I have a Sony KDL-32XBR4 TV purchased in mid 2007. I has been well taken care of with no missuse and now the screen only shows a hundred or so small vertical lines with one or two larger vertical lines....
It sounds like you have a video circuit problem and unless you have very good knowledge of electronic and tv circuitry there is not much we can do about that problem.You`ll need the help from a local tv repairman.
Hope they`ll be able to help you.
Dec 02, 2009 | Televison & Video
Slow picture and dark reddish tint
These sounds like you have an issue with main board or tcon. Picture slow makes me think this is a communication issue between the tcon and the main board.... This needs a professional diagnostic. The good news is i don't think it is the panel which would make the cost of repair beyond the cost of the tv. If it is in warranty or just out of warranty call sony, sometimes if it is just out of sony's 1 year warranty they will make exceptions. But you need to call them for this exception.
Some solutions are not cut and dried and an on-site diagnostic is best. In your case this is true. I have worked on sony for many years and that symptom (at least the way it is described) is not one I have seen.
Oct 10, 2009 | Sony BRAVIA KDL-32S2000 32 in. LCD HDTV
Jul 10, 2009 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
Sony Bravia KDL-40V2500
The panel or TCON board has failed, the solution is the same replace the panel. Not worth the cost, get a new TV
Sep 28, 2008 | Sony BRAVIA KDL-46S2000 46 in. LCD HDTV
Rainbow vertical lines on screen
THAT HAPPENS WHEN IT GETS TOO HOT, MAYBE YOU HAVE TOO MANY THINGS PLUGGED INTO THE SAME OUTLET
Apr 28, 2008 | Sony BRAVIA KDL-V40XBR1 40 in. LCD HDTV
Vertical colored lines no picture.
if the tv is less than a year old , call 1-800-SAMSUNG for warranty repair, the lcd panel is bad
Dec 17, 2007 | Samsung LNT3242H Television
Sony BRAVIA KDL-40V2500 40 in. LCD HDTV Logo
234 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
