During spin cycle it slings water from bottom of drum theres a lot of mildew or something around the shaft under the tub
  • 55 Answers
It sounds like you have a Maytag or an Amana washing machine to me. I could be wrong but just guessing. The tub seal/tub bearing replacement on these units is an expensive and requires special tools. You may want to look into getting another unit.
Posted on Jul 16, 2009
Water pores out on spin
Take off the cover and check for any holes in the top of the plastic tub surrounding the drum . This can occur when the washer is or was previously severely out of balance and the drum rubs a hole in the side of the tub. Since the water is usually below this level until the spin cycle pushes the water up the sides of the tub, it only becomes apparent then. Another possibility is there may be a blockage in the pump or drain hose. If you still have a good amount of water in the tub due to the washer not draining completely before the spin cycle, the water will sling everywhere when it attempts to spin. I hope this helps! Good luck!
Feb 21, 2012 | Washing Machines
Loud noise during spin cycle (Bravos washer) was told the bearing is pressed into the tub. Looking at parts list they show the "basket" and the "tub outer". Is the bearing in the "tub outer"?
Similar issue, lot of racket on final spin and was told only option was a $280 whole tub assembly. Dissasembled tub and removed bearings from shaft. Took to local bearing warehouse and got replacements for <$25. The small one was a Nachi Quest 6005-2NSE9 and the large one was 6006-2NSE9. It took me @ 4-6 hrs in total and had to work to get top bearing onto shaft but much more attractive option than replacement or whole tub. Extremely irritated with Maytag and will NOT give them another dime. A appliance less than 1.5 yr old should not have these issues - cheaply made. Is a shame as Maytag used to mean something, it meant quality but not anymore.
Feb 17, 2010 | Maytag Bravos MTW6600T Top Load Washer
Two problems, mildew smell and loud noise in spin cycle
drum bearing failure due to the water seal in front of the bearings failing the smell is probably the grease mixed with water in the outer tub
Jul 15, 2008 | Frigidaire GLTF1240A Front Load Washer
Maytag washer bangs during spin cycle
chances are you had a blockage in the pump and it tried to spin with the water still in the drum. check the bottom hose and filter for blockages so it does not occur again.
Jan 19, 2008 | Washing Machines
Kenmore Washer Spin Issue - Need help troubleshooting
Check the coils on the wig-gag. Its a couple of bars that engage the spin drive or the wash drive. If you look at the machine when its running you will see it moving back and forth, hence the name. If the coil engages the spin cam, but it still will not spin then the tranny is your next culprit.
Jan 04, 2008 | Washing Machines
Whirlpool LHW0050PQ Front Loading Washer VERY NOISY during spin cycle
remove the top access panel 3 screws in top rear.
now look around and push on the drum from top
it has suspension shocks and springs like your car they should resist any movements.
look/wiggle the concrete balance blocks , no cracks or loose.
inside the tub are the arm solid /not loose.
run it with the top open what do you see/hear and where
look under the rubber flap in front did anything get under the tub
Dec 29, 2007 | Whirlpool LHW0050PQ Front Load Washer
Washer leaking water from bottom
Probably a main tub seal, big job!
Nov 16, 2007 | Maytag MAV7600 Top Load Washer
Washer spin when in wash cycle
the problem is specifically the motor tacho which consists of a rotating magnet screwed to the motor shaft and a fixed coil around the magnet. the problem can be the magnet unscrewed or the coil fallen out.either way, they can usually be repaired by glue or packing.
Nov 07, 2006 | Zanussi FJ1454W Front Load Washer
Washing Machines Logo
Top Washing Machines Experts
