Question about Maytag MTW5900TW Top Load Washer
How do I drain a maytag washing machine? - Maytag MTW5900TW Top Load Washer
  • yadayada
    yadayada May 11, 2010
    set it to spin with water off to washer.
  • 585 Answers
If the machine will not operate to drain the water, gravity will do the job for you. Simply remove the drain hose from the standpipe, and lower it to a floor drain if one is near enough to the machine. If no floor drain, you can catch the water from the hose into a large bucket for disposal. You will need to empty the bucket numerous times before the washer is empty.
Posted on Jul 15, 2009
  • Bruce Volkers
    Bruce Volkers Jul 20, 2009
    Did you get your issue resolved?
Maytag washer throwing fault code 21
An "F21" or "F02" error code is indicative of a slow draining cycle, normally caused by a clogged or kinked drain hose. If an "F21" or "F02" error code appears, check the drain hose on the back of your washer to ensure that it is not clogged or bent. Once the drain hose has been unblocked, the error code should disappear and the machine drain properly. However, if you have a high efficiency washing machine and the error code continues to appear, make sure you are using the correct detergent; because high efficiency machines use much less water than traditional washing machines, they require the use of a low sudsing detergent. Traditional detergents may produce too many suds, which can block the machine's drain hose and lead to slower draining cycles.
May 20, 2012 | Maytag Washing Machines
Maytag Epic Z won't Drain after rinse cycle.
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Aug 13, 2011 | Maytag EPIC MFW9700S Front Load Washer
My model FAV6800AWW will not spin or wash its a piece of ****, will not drain water out. whats the problem with this piece of junk maytag sells
heatman101
Jun 29, 2011 | Maytag Neptune FAV6800AW Top Load Washer
HAV2360 Maytag does not drain before spinning. Drain cycle seems not to engage.
Unlike Whirlpol and Kenmore washers Maytag Washers drain and spin at the same time.
Apr 10, 2011 | Maytag HAV3460AWW Top Load Washer
Wont spin
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
If you are having problems with your front load washing machine then checkout this tip...
heatman101
Apr 05, 2011 | Maytag Washing Machines
My washer was filled with water but wont spin.. makes little noise but no spin
heatman101
Jan 18, 2011 | Maytag PAV5157A Top Load Washer
I have a maytag alantis top load washer and it drains out put it seems it dosn 't spinn
heatman101
Sep 20, 2010 | Maytag Washing Machines
My tub won't drain correctly, we followed the maual and still not draining fully from tub. I have a maytag front loader.
heatman101
Sep 15, 2010 | Maytag Washing Machines
Maytag Neptune washing machine - wont drain & spin
Washing Machine2_bing.gif does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine2_bing.gif then checkout this tip...
Front Load Washing Machine2_bing.gif not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
May 21, 2010 | Maytag Neptune MAH5500B Front Load Washer
Maytag MTW5900TW Top Load Washer Logo
74 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
