Jenn-Air 24 in. JDB1080AWS Built-in Dishwasher
Problem for Jenn-Air 24 in. JDB1080AWS Built-in Dishwasher
It is not cleaning dishes
By se3223 on Jul 15, 2009
it is not cleaning dishes, it leaves food residue on dishes and deposits small bits to other dishes especially on glasses.
Solution #1
posted on Aug 09, 2009
Not Rated)
mambro
Rank: Wiz
Rating: 79%, 163 votes
hard water is your problem. go to www.dishwasherfilter.com and get a difi filter. you will love the way your dishes look guaranteed or your money back.
Was this helpful?
Yes
No
Solution #2
posted on Jul 15, 2009
Not Rated)
localwonder
Rank: Guru
Rating: 92%, 2949 votes
If there is not enough water, the dishes would not get cleaned. This could be caused by a partially closed water shut-off valve (located under the sink), or a faulty dishwasher water valve (located at the bottom of the dishwasher, behind the kick panel, on either side).
Also, There is usually two, sometimes three spray arms in a dishwasher. Make sure there is no debris blocking the holes inside each spray arm.
**Water temperature Note***
To get the best results, the water has to be at 120 degrees Fahrenheit when entering the dishwasher.
Was this helpful?
Yes
No
Popular Solutions for Jenn-Air 24 in. JDB1080AWS
Questions and Unsolved Problems for Jenn-Air 24 in. JDB1080AWS
Do you recommend Jenn-Air 24 in. JDB1080AWS Built-in Dishwasher?
Answer
Answer
I have a JennAir model JDB5900AWN that just started to not drain out the final rinse water prior to... (More)
Answer
Water comes in water goes out but while in does not get dispersed Arm does not move. I'm guessing... (More)
Answer
The only button that is responding is the "Quick Wash" button. This has happened before... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Dishwashers Experts
Top Dishwasher Repairmen
(423) 303-3783
Dishwasher parts delivered overnight nationwide....
 Appliance Parts Pros.com
(800) 803-6775
Manage my home, all the technicians you need at...
Manage my Home
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
