Question about IBM ThinkPad T400 PC Notebook
I can't turn my IBM Thinkpad on. It seems to have turned itself off and now I hold down the on switch and it will not come on.
  • Bryan May 11, 2010
    Are you running it on a battery or pluged in?
My ibm laptop keyboard has frozen. All else seems
Please press ctrl+Alt+Del simultaneously and the task manager will be opened up.There you will get the option to shut down.
If the task manager itself is not openeing up then please press and hold the power button for 10 sec and it willlose then you may restart the machine in safe mode and restore it to a previous config.
Thanks.
Jan 06, 2010 | IBM ThinkPad T42p Notebook
Is there an of on switch for wireless on a t40 thinkpad. I can't seem to get a connection. Thank you
Hold down the BLUE-coloured 'fn' key (at bottom-left of keyboard),
and press the 'F5' key once, and release the 'fn' key.
Dec 29, 2009 | IBM ThinkPad T40 2373 Notebook
How do I turn on the wireless on an IBM ThinkPad 2628 A20m Thanks in advance
To turn on the wireless on IBM Think Pad 2628 A20m you can try the below options
IBM
IBM General - Some models have the wireless slide button on the side of the laptop.
IBM DV series - use the antenna-like button found on the upper section of your keyboard.
IBM R40 - Use the Fn+F5 key-combo.
IBM Thinkpad (General) - Most have software switch or button on Left hand side.
IBM Thinkpad (model not further identified) wireless switch on Front edge of case.
IBM T43/X32 - Fn+F5 -Click "Turn On"
IBM ZD series use the antenna-like button just below the “Lock” key.
Let me know fi this will help
Dec 04, 2009 | IBM ThinkPad A21m 2628 Notebook
For thinkpad R52 where is the wirless switch ON/OFF?
On thinkpad R52 Wireless turns on and turns off by holding key Fn and pressing key F5.
Fn+F5
Aug 05, 2009 | IBM ThinkPad R52 Notebook
Computer turns on and off all by itself.
check out wall power
change the smps
may be software problen unintall and reinstall operating system
Aug 05, 2009 | IBM Thinkpad T40 Thinkpad T41 Thinkpad T42...
How to enter into BIOS when trackpoint was broken.
Hi there.
Its something to do with the trackpoint, possibly the cable has become loose.
* If an emergency power down is made by switching the system off during or while an application is open, then immediately switching the system on creates a 8611 error.
* Repeatedly turning power off and back on without properly shutting down or allowing the system to shut itself down.
Solution
Wait at least 6 seconds or longer after shutting down the system or before restarting to correct the 8611 error.
See if that gets rid of the error, if not it could be a loose cable to the trackpoint.
Good luck
Jun 01, 2009 | IBM ThinkPad 600X Notebook
Ibm thinkpad keyboard. i type letters, numbers show up. fix?
With my IBM Thinkpad, I had to hold Shift+ScrLk to turn off Number Lock.
Mar 27, 2009 | IBM Thinkpad 560 Series Laptop 20h4241...
Where is the wireless button on t42 thinkpad
There's no hardware switch to activate and deactivate the wireless networking, but pressing Fn and F5 brings up a menu that allows you to turn Bluetooth on/off, WiFi on/off or both. It seems like IBM isn't satisfied with standard toggle buttons like other notebook manufacturers - even pressing the Fn and F7 buttons to switch between internal and external screens, brings up a menu with multiple display settings and resolutions.
Hope this helps,
David
Mar 10, 2009 | IBM ThinkPad T42 Notebook
How can i turn off the Fn from my notebook ibm 2656 thinkpad
Usually, just holding down the powe button for several seconds will turn off computer, without damaging it. Also, you can remove power cord and battery.
Dec 15, 2008 | IBM ThinkPad R31 2656 Notebook
Wireless
Usually IBM laptop wireless cannot work
Aug 09, 2008 | IBM ThinkPad (22P9163OB) (22P9163-OB)...
IBM ThinkPad T400  PC Notebook Logo
174 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
