Question about HP Pavilion F1503 15" LCD Flat Panel Monitor
Usb 2.0 I am trying to charge my ipod and my daughter mp3 player threw the hard drive usb 2.0 cable! it isn't working!
  • 40 Answers
Please clarify the term "hard drive usb cable"  Ipods have a special connection on the bottom for sync and charge, and it may not fit another mp3 player.
srich
Posted on May 27, 2008
Vivitar mp3 player isn't recognized by computer
If the MP3 player is not charging through the USB cable when connected to the computer and the computer cannot detect the MPe player then you could have a faulty USB cable. Try a different USB cable.
May 02, 2012 | Vivitar Digital Mp3 Player - Black
Tip
How to convert a USB Battery Charge Cable to AC
<p>Many of the new battery-operated devices such as phones and MP3 players come with USB cables to charge the battery while the computer. However, wall chargers for these items are missing, damaged or undelivered. If so, you can use a USB wall charger, USB cables, adapters and because all have the same size at the end with these boots are endless. <br /> <p><br /> <p>Generic Battery <br /> <p>1. Buy a USB wall charger. These are available online through www.amazon.com and www.bixnet.com or a limited number of electronics stores like Radio Shack or Best Buy. <br /> <p><br /> <p>2. Connect the USB end of cable to the USB wall charger. <br /> <p><br /> <p>3. Connect the charger to the USB cable. Then connect it to the wall. The machine starts working the green light. <br /> <p><br /> <p>iPod Battery <br /> <p>1. Connect the USB cable to the iPod. Be sure to press the two ends before inserting it into the iPod. If you do not, you can damage the pins, once that happens, you will not be able to charge your iPod. <br /> <p><br /> <p>2. Mount the USB wall charger sliding the top in half, for the manual. <br /> <p><br /> <p>3. Connect the USB cable for both USB wall charger. Plug the wall charger. The costs start when the lights come back on the iPod screen and you will see the battery icon fill. You can find this anywhere iPod charger are supplied. <br />
on Aug 09, 2011 | Apple iPod touch
My ipod wont charge
There are only three possible causes of the problem for the iPod that's not charging.
1. Dead battery
2. Loose connection
3. Bad charging cable
* First, you may want to try to use another cable then try to charge your iPod. Or you may try to connect it to different USB ports of the computer and see if the same problem will occur.
If that did not help, then you need to send the iPod to the manufacturer and have them check the battery and possible loose wire connection inside.
Thank you and good luck!
Jul 31, 2010 | Apple iPod shuffle Second Gen. Silver (1...
Wont connect to computer
First try installing the support software that can be found on the support cd that came along with your product. It automatically installs needed drivers for the computer to recognize your player, and lastly if that doesnt work, try connecting the player to other PC, just to be sure and for you to diagnose waht seems to be the real culprit, becuase it is also possible that the players' USb port is damaged. try also using another usb cable
Jun 27, 2010 | Emerson MP530 MP3 Player
My 2 G Nano will not charge when plugged into my computer's usb nor can i reset it
have you tried a hard reset? I had this issue once with my daughters ipod and a hard reset did the trick
http://support.apple.com/kb/HT1320
that explains how to reset it
Hope this helps
Mar 15, 2010 | Apple iPod nano
When I plug my iPhone into the USB it doesn't
ANSWER: The headphone jack will not charge your iPod. Only the USB will charge your iPod. However, the headphone jack will play music, but the USB will not play music from your iPod.
REASON: The headphone jack does not provide any power to charge your iPod. It isnly has enough power to recieve a music signal.
REASON WHY YOU CANNOT PLAY IPOD THROUGH THE USB: The USB is only intended to be used with a flash drive or external hard drive with a folder structure containing either .mp3 or .wma files. The way the USB works on the system is that it reads all the files and folders on the entire device and will say "reading" until it reads all the files and folders. This should only take a few seconds but if there is tons of files it may take longer. Main problem: An iPod contains much more than just music files and folders - it contains an entire operating system. Worse, the operating system which the iPod uses is protected, keeping other devices except for iTunes from reading the music files.
TO PLAY MUSIC FROM USB (NOT IPOD): You will need to use a flash drive or external hard drive with your USB. This device can only contain music, and the music must be organized into folders. Your iPod will not work. However, you can use Auxiliary input using a cable which both ends are 1/4" headphone jacks, one end going to the iPod and other plugged into your stereo.
SOLUTION: To charge your iPod, you need to plug it into USB. However, to play music, you need to plug your iPod into the headphone jack.
Good Luck! - Chris Proia
p.s. Here is the User Manual for your XDM6350 : http://www.dualav.com/support/manuals/xdm6350.pdf
Aug 13, 2009 | Dual Electronics XDM6350 Car CD/ MP3...
I have an ipod video 80g and it does not charging anymore.. what does the problem?
1. Check the charging/communication port that is clean and free of dust and dirty.
2. Check your Ipod/cable in other computer
3. Borrow a USB cable from a frind and check it with your ipod to discard the USB cable is defective.
4. If still your ipod is not charging and powering on, then you will need to have professionally serviced your ipod player.
If it is under warranty, then make it valid.
Best regards,
Jun 10, 2009 | Apple iPod MA446LL/A MP3 Player
Usb connection for ipod
Do other devices work in the same USB ports? Does the iPod show up on a different computer? Have you tried different cables? Does it still charge?
Try that first. If not, you can do a reset by holding the top of the click wheel and the centre button. You can also try resetting it in menu.
Beyond that it sounds like warranty time.
Dec 26, 2008 | Apple iPod nano
CHARGED IPOD CLASSIC WITH WRONG VOLTAGE CHARGER
sorry mate i dont think so it can work replacin its hard drive and ic which eva got problems. but i prefer buyin new one instead of replacin hard disk etc
Nov 23, 2008 | Apple iPod MA446LL/A MP3 Player
HP Pavilion F1503 15" LCD Flat Panel Monitor Logo
56 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
