Question about RTO PasLode 900420 Impulse Framing Nailer
Brand New Paslode 900420, I bought the red gas, charged battery for 2 hours and it work shoot any nails. What am i doing wrong?
  • 55 Answers
Also try and check whether or not the slide where you insert the nails that you push the button down that way it is pushing the nails forward
Posted on Dec 02, 2009
Make sure your gas is sitting in the right position.
Posted on Jul 25, 2009
Why want my paslode shoot nails all the way
Did you adjust the depth piece on the front? You can move this piece all the way up to try to nail deeper.
Also, I have tried nailing two pieces of oak together with no luck. It leaves the 2-1/2" nail about 1/8 to 1/16" above the surface.
Nov 07, 2014 | RTO PasLode 900420 Impulse Framing Nailer
Paslode 900420 fires only one nail and the battery has to be pulled and reinsert to fire again. After shooting one nail, the light alternate between green and Red. I have tried new fuel cell and fresh...
It needs to be cleaned and oiled. You can buy an electrical cleaner spray and oil specific for paslodes at Home Depot. You will have to take the back off (where the filter is) and clean it with the cleaning spray then oil it well. Put it back together and it will work like new again. You will be surprised how much difference it will make. Good luck
Sep 11, 2012 | RTO PasLode 900420 Impulse Framing Nailer
I have a 900420 gas paslode nail gun .When I push the gun down it is dead ,the battery is charged and it has gas
You need to remove the combustion chamber assembly and check for spark, remove 4 screws from filter cover and 2 screws from nose mount then carefully slide the assembly off, fit a good battery and press down on the roller arm below the fan, the fan should run, operate the trigger while the fan is running and you should get a spark, if not you will have an electrical fault, if you get spark bend the roller up slightly and see if that solves your problem
Sep 22, 2011 | RTO PasLode 900420 Impulse Framing Nailer
My 900420 didn't shoot a nail ,i installed new battery and fuel cell,and is 33 degree nail r right for this model .
Here is a tip that I wrote about the Paslode nailers and the problems that can come up with them.
I also have a link to the Paslode manuals which contain Paslode cleaning and troubleshooting guides.
If you need parts for your Paslode, there also is a link for a site that sells the Paslode nailer parts.
Paslode Cordless Nailer Problems
heatman101
Oct 16, 2010 | RTO PasLode 900420 Impulse Framing Nailer
I changed the gas cylinder in my paslode framing nailer and now it won't fire the nails at all. The battery is fully charged and the whirring sound and smell of gas is evidenced but no nails are fired.
Make sure you have the correct gas cylinder. There are more than one type of cylinders for these nailers. If it is not correct it won't seat and gas will leak. Whiring sound is normal, fan mixing oxygen. Make sure "O" ring is in place under the gas cylinder.
Oct 01, 2010 | RTO PasLode 900420 Impulse Framing Nailer
I have charged my battery new gas the green light flashes. Then when I depress the red light flashes
Do you have the right Gas clinder? I believe there are different types depending on nails selected.
Jun 29, 2010 | RTO PasLode 900420 Impulse Framing Nailer
Paslode nail gun 325 black not firing
Any time these guns become intermittent or stop firing but the fan still runs, the first the to check is the expiration date on the gas cartridges. The do expire and this will make the gun work inconsistently or not at all.
Dec 08, 2009 | RTO PasLode 900420 Impulse Framing Nailer
Gun not firing batt charge, new gas, fan goes just not firing
could be a couple things, first are there nails in the magazine, this tool has a stop when low on nails it won't fire, second is the lower probe bent not allowing full push on the cylinder to load gas. Give me the model number and I will find a print or you can go to Paslode.com and type in the model number and get an owners manual that has a trouble shooting guide in it for help. Let me know and if I have helped you with your question would you please rate this response accordingly.
Sep 05, 2009 | RTO PasLode 900420 Impulse Framing Nailer
Paslode 350 wont fire
Probably needs cleaning. You`ll need two new o`rings.
Aug 19, 2009 | RTO PasLode 900420 Impulse Framing Nailer
Nail gun
have you activated the fuel cell by pressing the black nozzle down onto the cylinder?
Jul 27, 2009 | RTO PasLode 900420 Impulse Framing Nailer
RTO PasLode 900420 Impulse Framing Nailer  Logo
355 people viewed this question
Top RTO Air Tools & Compressors Experts
yoopertech
John Trevino
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a RTO Air Tool and Compressor Expert? Answer questions, earn points and help others
