Question about Sewing Machines
I have the Viking Emerald 118 model, less than a month old. I cannot get the button for setting whether the needle stops up or down to work. It worked fine the last time I used my machine. I also am having trouble getting the threader to work, it also worked just fine all times before. Can you please help.
The large wheel on the side of the machine that pulls out to thread a bobbin is probably pulled out. Push it in and the rest of the features should work.
Posted on Jan 20, 2010
How can I repair the top thread from tangling in the bobbin stopper for the Husqvarna Viking Emerald 118?
Thread nesting in bottom usually means that top thread is either not threaded correctly or top tension dials has lint caught in it. Use canned air to blow it out. Also change needle.
Dec 10, 2014 | Husqvarna Sewing Machines
My viking emerald 118 machine just started breaking needles and the bobbin thread will not hold. YOu can pull the bobbin stitch out by pulling the thread.
Check the upper tension by lowering the presser foot and pulling on the thread through the needle. You should feel resistance. If not, take a stiff brush and clean out the tension disks/dials removing any loose threads or lint. If upper tension is ok, check bobbin tension by pulling thread through needle plate opening. You should feel resistance. If not, remove bobbin case and brush any loose threads or lint from the case, especially in the tension spring where the thread is snapped into place. You may need to use a sharp needle to dig in between the spring but be careful that you don't damage it.
Jun 17, 2014 | Husqvarna Viking Emerald 116 Sewing...
I have a new (less than a year old) Husqvarna Emerald 118 sewing machine and the needle up/down feature has suddenly stopped working. Is there anything I can do or do I need to take it in to a dealer?
I suggest to take it to a dealer, something may have come loose or broken or it could be the computer part of the machine has went out, but they can tell you which one
Aug 31, 2011 | Sewing Machines
I have an Emerald 116 Husqvarna/Viking sewing machine and the feeder teeth have simply stopped feeding. It worked fine the last time I used it a couple of months ago and it hasn't been moved or disturbed...
HOW TO FIX YOUR FEEDER TEETH (DOG TEETH) ON EMERALD 116/118/120 IF THEY STOP WORKING....
So this is just a temporary solution to this problem... after reading through the user's guide (which really needs to be updated to have more troubleshooting suggestions), and basically taking apart various parts of the machine, I found a temporary solution.
1. Unscrew the Face Place (where the needle is attached to. #9 in User Guide Overview) There is only one screw on the side right underneath the Pressure Foot Pressure Dial (#8 in User Guide Overview). Taking off the Face Place gives you room to use a screwdriver for step 2...
2. Unscrew the Needle Plate (#12 in User Guide Overview), and take out the Bobbin holder (black). Slide the lever for the Feed Teeth to the raised position, and with your forefinger pop up the Feed Teeth (underneath the needle) to the raised position. You will here a click... and you are set to go. Reassembly your machine and get back to sewing!
Nov 21, 2010 | Sewing Machines
Needle stop up/down no longer works on Viking 118
sometimes the bobbin winder gets left closed, and that will make the machine run slowly and with no up/down button.
Jan 25, 2010 | Sewing Machines
Manual
i need a manual for my Husqvarna 215 sewing machine.
can you help me?
Apr 11, 2009 | Husqvarna Viking 1
Bobbins for viking emerald 118
The Emerald 118 takes a bobbin that is very close in size to a Singer Class 15 bobbin, but it is slightly different.
Don't buy green bobbins for a standard Husqvarna machine. They will not work.
Any Husqvarna dealer can get the Emerald bobbins for you.
Oct 03, 2008 | Husqvarna Viking 1
Sewing Machines Logo
216 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Are you a Sewing Machine Expert? Answer questions, earn points and help others
