Question about HP Computers & Internet
HP Pavilion zv6100 laptop CMOS will not recognize the HD
I have an HP Pavilion zv6100 laptop. I reformatted the drive with XP install disks and now CMOS will not recognize the HD. Checks of the drive with a different computer indicate the hard drive has no bad sectors and is functioning properly. Could this be a bad boot sector? I am at my wits end with this. Please help!
  • HP Master
  • 32,281 Answers
You could have a faulty disk controller. Try inserting a different working hard disk into the HP and see if it can detect it in the BIOS. If not then the disk controller is faulty and this is a motherboard problem. A replacement motherboard may not be worth it, put your money towards a new laptop and put the hard disk into an USB hard drive adapter case and use it as an USB external hard drive.
Posted on Jul 16, 2009
HP Pavilion dv5020us reformat
Manufacturers usually have a recovery partition on the hard drive, you should see this option when you boot up, The same time when you see the To Enter Setup Press Del
Nov 25, 2009 | HP Pavilion dv5020us Notebook
Installallation of xp
the xp does not recognize the SATA hard disk of your computer, you must install SATA drivers during the installtion of XP.
Sep 16, 2009 | Microsoft Windows XP Professional With...
Reformatting an HP Pavilion DV2000
when you put in the windows installation disc and restart your computer you will get a screen where you have the option to delete and reformat any existing disc partitions, choose delete current partition and reformat in NTFS and then you can install windows on newly formatted drive
May 10, 2009 | HP 417035-001 - HP Pavilion dv2000 Series...
Do i need to change my harddisk?
It sounds like UBUNTU formated your hard drive where xp does not reconized the drive. When you go into BIOS setting, do you see your hard listed? If so, you should be able to put a clean install of XP to the drive. When you start the install, you must select REFORMAT drive and install XP. If this still fails, you may need to fdisk your drive first using DOS command and reinstall XP. Let us know if you incounter any more problems after doing this. Good Luck.
Feb 08, 2009 | HP Pavilion dv6000z Notebook
HP Pavilion ze5500 - Laptop won't recognize hard drive.
Hi. Once I had this similar problem with a HP Pavilion dv9000. "No Operating System"; "Windows Recovery Console cannot continue because there's no HD present..press F3 to Exit". No progress with Safe Mode nor Command Prompt, etc.
Then I went to the Bios, change tab to "System Configuration" and change the "Sata Native Support" to disable, whitch says that by changing to disable the HD would work better if the Operating System are Win2000 and Win9x.
Hit "Safe and Exit" and the computer started normaly!
I relly don't know how or why. It just work.
I don't know if would work for Linux (mine had Windows XP) and don't know the Bios view of your laptop. But you can explore and give it a try.
Hope this helps.
God Bless You!
Jan 06, 2009 | Computers & Internet
XP on HP Pavilion dv2000
i think you have a sata hard disk drive.so go to cmos setup and in the cmos setup and please disable the sata drive there
Jan 04, 2009 | HP Pavilion dv2000t 14.1" Notebook Laptop...
For the laptop with no hard drive detected, this is most likely because Windows XP does not recognize SATA drives by default, which the laptop most likely has. To solve this, you will need to enter the BIOS setup utility (most likely Delete or F1 on startup). From there, you will need to change the drive mode to Compatibility mode. I'm not sure where this would be, but if you check in your laptop manual, you can probably find this somewhere.
For the 2519TU, download and install this for the LAN driver: ftp://ftp.hp.com/pub/softpaq/sp30001-30500/sp30264.exe it should work just fine.
Dec 23, 2008 | HP Pavilion dv9000z Notebook
Installing cd
you can use any xp disk to format hd and reinstall .
do u not know anyone who could lend u their copy for a few hours.make sure u have the cd key.
you can use the same disk many times on many machines with the same disk n same cd key.
Apr 06, 2008 | HP Pavilion dv1000 Notebook
Does not going ahead of logo hp
startup with xp disk in drive and let me know what information comes next.
it could be bios problem ,it could be hd problem.at this point it sounds like hd prob;faulty sectors,corrupted or missing sys32.
if it turns out that you have the option to install xp do it.this eliminates bios prob though curious why cannot enter bios at this point.
Apr 01, 2008 | HP Pavilion dv9000z Notebook
HD reformat
Get Hiren's Boot CD. It has many utilities which includes data recovery, low level format and hard disk partitioning.
Feb 29, 2008 | Computers & Internet
Computers & Internet Logo
282 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
