Question about AT&T Blackberry Curve 8300 Smartphone
The roller ball will roll but doesn't move on the screen
  • 846 Answers
There is a blackberry repair guidethat shows you how to replace the part yourself. link to self repair guides guides is in thelower left corner of blackberry repair website.
Posted on Jul 16, 2009
callmelolly
  • 6 Answers
SOURCE: roller ball on blackberry won't work
Was it Like it when you bought it?? If not, then its probably broken.. it happens a lot with rollerballs.. if you take it back to the shop you bought it from they will probably send it away to be fixed.
Posted on Sep 05, 2009
  • 23 Answers
SOURCE: my roller ball on my blackberry 8900 will not
You could take i out n clean , u could use the enter button or buy a new 1
Posted on Oct 13, 2009
FixinFax
  • 3085 Answers
SOURCE: my roller ball will not roll down
Pry the ball chrome cover off and clean with alcohol.
Posted on Dec 19, 2009
  • 15 Answers
SOURCE: my roller ball does not roll down it goes all
there is something stuck under the ball. take the phone and roll the ball on clean white paper facing dowing in all directions. I
Posted on Feb 10, 2010
SOURCE: my blackberry roller wont move down... is there
There is a little workaround... When you're in e-mail, you can touch "t" to go to the top of the list, the spacebar to go down a page at a time, and "b" to go to the bottom of the list. It seems to work on other pages as well, at least sometimes. That has helped me while I figure out what's really wrong with it.
Shortly before my rollerball stopped rolling up, it turned a dark red color when it's not illuminated; it has kind of a pale pink glow when it's lit up. I'm still digging around on for info on this, but maybe this will help in the meantime with yours.
Posted on Feb 18, 2010
I have a Dyson 24 ball. How do I get the brush to turn on?
Hello, this is Ava with Think Crucial.
There are a number of reasons why your brush roller has stopped moving. General maintenance to your vacuum is crucial and will help it work at peak performance.
First things first lets focus on the brush roller. Unplug the vacuum and turn it on its side. Look for any noticeable clumps of debris or hair strands that may be caught in the brush roller. Remove these obstructions, probably best to do so with a scissor if it's hair or long pieces of carpet fibers. After removing the debris try manually rotating the brush roller to uncover other hidden clogs. Another thing to take note of is the condition of the bristles on the roll itself. Are they loose or worn down? These are signs that your brush roller is in need of replacing.
While checking out your brush roll you might as well take a look at your vacuums belt. Your belt should be replaced about every three months. After regular usage, the belt will stretch out, lessening the tension on the brush roller. Lesser tension diminishes the brush roller's turn rate and speed. If the belt feels loose then it certainly is affecting your vacuums suction as well as your brush roll not moving at all.
You can purchase a wide variety of high quality Dyson replacement parts for your Dyson vacuum direct from Think Crucial with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
https://www.thinkcrucial.com/search?type=product&q=dc24
I hope this was helpful.
Ava B.
Think Crucial Customer Care
http://www.thinkcrucial.com/
Jan 23, 2017 | Dyson DC24 Ball All-Floors Upright Vacuum...
Tip
Mouse Balls ! How to clean a cranky mouse
This applies to ball type mice not the optical type.
If your mouse has stopped moving the cursor but the buttons still work or it isn;t as smooth as it used to be then this tip should help fix that. A lot of people will go out and buy a new mouse when all they needed to do was clean it.
To clean your mouse all you need is some rubbing alcohol, paper towels, cotton swabs and sometimes a pair of tweezers.
First thing to do is open the cover on the bottom and take the ball out. Use your thumbs to twist the cover and it will unlock. Set these aside we will clean them last.
Now look in the cavity and you will see a couple of wide rollers. These are what the ball rubs against and these in turn are used to generate the position signals to your computer. When they get dirty they won't roll and the result is that the mouse doesn't think it has moved. When you look at the rollers a dirty one looks like the photo.
The grey can be a a few things usually a mix of oils and dust. And sometimes it is lint. Soak one of the swabs in alcohol and wipe the roller. You will have to clean a spot then rotate the roller to clean a new area. When the stripe or buildup is gone then go to the next one. This takes a minute or so per roller so it is quick. If the buildup is stubborn you may need to scrape it off then clean.
The next thing to clean is the ball using a paper towel with alcohol. Just give it a good wipe and let it dry. Next clean the cover and the bottom of the mouse body. You may want to clean the surface you use the mouse on as well.
Replace the ball, replace and lock the cover in place and you are done.
The mouse should work normally now. If it still doesn;t it can be due to wear or lint on the internal sensors. However cleaning the mouse like this fixes it about 99.99% of the time.
on Apr 13, 2010 | Computers & Internet
Dyson cinetic big ball beater brush not working
https://www.thinkcrucial.com/search?type=product&q=dyson
Ava B.
Sep 05, 2016 | Dyson Cinetic Big Ball Animal Bagless...
Can I fix the roller in my wireless mouse?
Open the mouse. (Slide the panel on the bottom that surrounds the ball, and pull the ball out. Clean the ball and the rollers inside the mouse with rubbing alcohol. Remove all debris, hair, lint, etc.
Voila!
Sep 26, 2014 | Computers & Internet
Filter in roller ball keeps popping out. I cleaned the filters and placed them back in there positions. When i turn on the vacuum the suction is good, as soon as i move the roller ball the filter pops out...
Hi April,
I'm sorry to hear you're having difficulties with the filter. So we can determine which model of Dyson Ball you have, please get in touch with us directly by calling us free on 0800 298 0298 (UK), or 1866MYDYSON (US). I'm confident we'll be able to resolve this issue for you.
Kind regards,
Jack
Dyson Online Customer Support
Oct 30, 2011 | Dyson DC17 Animal Bagless Upright Cyclonic...
I have a dyson roller ball vacuum cleaner DC25. The brush will not turn when I am running the machine. It turns manually' Wally from San Antonio
You can purchase a wide variety of high quality Dyson replacement parts for your Dyson Vacuum direct from Think Crucial with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
Ava B.
Jan 29, 2011 | Dyson Ball DC24 Bagless Upright Vacuum
My Scroll bar won't move up. How do i fix this?
You need a new trackball, there is a guide that shows you how to replace it at Blackberry repair guide
Jun 30, 2010 | RIM BlackBerry Pearl 8100
Bernina 1530
You may just need to clean it. Many times when people use hand lotion or other things oil etc. it gets on the ball and interferes with the board. Try cleaning the ball with cottonball and alcohol. It really makes a difference.
Hope this helps.
Rick
Mar 17, 2009 | Bernina 1008
Pearl roller ball
It might be a case where the track ball has some dirt or debris underneath it. First, turn the device off. Next, press down firmly on the track ball while at the same time rolling it in every direction. Hopefully that will knock loose any debris. Another tip to try is to wet your thumb with a little water and do the same thing.
If those two options don't work, you may try taking out the track ball and blowing out the slot with some compressed air. Below is a link that shows how to remove and clean the track ball:
http://www.blackberryforums.com/general-8100-series-discussion-pearl/113889-how-clean-trackball-your-pearl-8100-a.html
Oct 03, 2008 | RIM BlackBerry Pearl 8100
AT&T Blackberry Curve 8300 Smartphone Logo
386 people viewed this question
Top AT&T Computers & Internet Experts
Computer Repairing
Computer Repairing
Prashant M
Prashant M
Are you an AT&T Computer and Internet Expert? Answer questions, earn points and help others
