Sharp Q Series LC-60UQ17U 60" LED TV 1920x1080, 240 Hz, HDTV, 3D Logo
Scott Sendek Posted on Feb 15, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Sharp 60uq17u no picture - Sharp Q Series LC-60UQ17U 60" LED TV 1920x1080, 240 Hz, HDTV, 3D
Electro Med Services
Level 3:
  • Sharp Master 6,694 Answers
  • Posted on Feb 15, 2016
Sharp Master
Level 3:
Answers
6694
Questions
Helped
1872443
Points
21433
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
http://electro-medical.blogspot.com/
To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
1helpful
Sharp lc-32sh12u...no picture
It can be either the LCD panel driver board, or the worst case is bad LCD panel.
1helpful
32 inch Sharp Aquos is less than a year old... I changed that channel and the picture was green or gray... i changed it again and got a normal picture once but now all channels are looking blank with a...
Contact Sharp to locate the nearest authorized Sharp servicer. Sharp Aquos servicers have to give Aquos TV top priority. Sharp provides very good and fast serice on these sets.
2answers
My camera not focusing
Dear juanvillar46 I found this important information to explaing better about the hand color and meannings
Understanding blur warning icons If the feature is turned on (see ), a picture blur warning icon autourg00531002id1716777.jpg is displayed during quickview and review.
spacer.gif Green - Picture is sharp enough for an acceptable 4 x 6-inch (10 x 15 cm) print.
Yellow - Picture may be sharp enough for an acceptable 4 x 6-inch print or sharpness is not determined.
Red - Picture is not sharp enough for an acceptable 4 x 6-inch print.
White - Printability is still being determined.
Your Rating is very important for me
"Was this helpful?"
Pics are not so sharp
in the 40d, the sharpeness of the picture can be tune. find in the menu the picture mode (like portrait, landscape,neutral) choose one of the mode and hit jump to acceed to the tune, contrast, colors, controls
4answers
Sharpness
as for the sharpness if the picture has no adjustment and is maximum sharpness you cannot improve it.
5helpful
Picture adjustment questions
*The brightness control setting determines how bright your picture will be. *The contrast control sets the gain of the video circuit. This determines the difference between dark and light scenes. Low contrast settings make the picture "hazy". High contrast settings make the picture more distinction between dark and light scenes. *The sharpness control determine the frequency response of the video circiut. High sharpness settings give better resolution but also shows more noise in your picture. Lower sharpness settings smoothe out the picture removing noise but also fine detail. It needs to be set for the best all around picture. *Picture Enhancement is pre-set adjustments which give you different picture qualities. You just select the one you like. Stargazer
Top Sharp Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
