Question about GE 36 in. JGP628 Gas Cooktop
It is not a GE but it is a Jenn-air
4 Gas burners, 2 on each side left and right sharing one igniter on each side... on the right side the igniter lights (tick) when the front burner is turned on but does not tick when the back is turned on..... everything is clean and clear... I have to turn on the front burner first then turn the back on for the gas to catch up from the front (bad, I know).... what could be the problem, the switch or the igniter?
Thank you.
  • eliekheder Nov 18, 2007
    but the back burner does not light from the igniter?... it does light from the fire of the front, it is like putting a match to it... beside I don’t hear it ticks when I switch the back burner, so how could the igniter light only the front and not the back although the back discharge gas as soon as it is turned on.
    what I am saying is, if the igniter sparks and light the front why it does not ticks and light the back when the gas exists?... so now could that be the switch that does not make the igniter clicks?
  • 290 Answers
If it will light when you activate the front burner the ignitor is ok.
It sounds like the switch on that valve has failed and is not putting power to spark module.
Post back if you have any questions.
Posted on Nov 17, 2007
  • Michael  Lindley
    Michael Lindley Nov 18, 2007
    When you turn the knob two things happen. The gas valve opens to allow gas to the burner and the ignitor switch is activated to power the spark module. These are two seperate parts. Each burner valve has it's own switch. You most likely have a bad switch for the rear burner.
    If you will light the front burner and leave it in the light position so that the ignitor is clicking, then turn on the rear burner, it should light normaly and be much safer then letting the gas cross all the way to the front. After the rear is lit you can turn the front off or to whatever position you want it.
  • Michael  Lindley
    Michael Lindley Nov 25, 2007
    Just wanted to follow up on your problem and see if you got it fixed.
    Thanks/Mike
  • 473 Answers
It's either a bad spark module or switch.
On a 4 burner Gas cooktop - all 4 burners get gas but why does the igniter only work with the front 2?
Usually that's caused by clogged holes in the burners. I clean it out using a toothpick.
May 02, 2015 | Jenn-Air Cooktops
I am not sure of the model number but the gas cooktop was purchased in 1998. The 2 burners on the left side all of a sudden are not ingiting. There is no gas and the igniters are not sparking. the other...
Hello Sharon,
are the two left hand burners "simmer burners" that low come on and go off to simmer a pot?
and the right side just set on and turn off without the simmer option?
if yes this pretty much describes your cooktop the part called the potentiometer is going the be the problem.
Aug 26, 2011 | Thermador SGS36GS Gas Cooktop
Igniter ticks but burner will not light. Gas is flowing
The gas burner holes near the igniter made be clogged if you've spilled food on them. Use a sewing needle to clean the holes.
May 12, 2010 | GE 36 in. JGP628 Gas Cooktop
All 4 Igniters keep firing after the burner is lit.
Here is a tip that I wrote that will help figure out why the burner spark keepson clicking...
Gas Range RepairBurners Keep on Clicking
heatman101
ghhdf
May 02, 2010 | Jenn-Air 34 in. Expressions CVGX2423 Gas...
Trouble with front burners: Right burner sparks but does not light Left burner does not apper to spark, but lights If you turn on both bruners they some times light???
The igniters for the burners are all on one circuit so when you turn the burner to light the switch inside the burner valve will cause all burner igniters to come on. As far as the left burner not sparking it could be due to a bad igniter switch in the valve and when you turn on the right burner you are causing all(including the left one) to spark. You will need to make sure that the burner eyes are clear and not plugged. You can use a sewing needle to clear out the eyes. The small eyes at the igniter electrodes are very important because if they are clogged the burner will not light.
Jan 15, 2010 | GE 30 in. JGP328 Gas Cooktop
Jenn Air Gas cooktop burner ignition
Hi JHMcdona
Most likely the electrode for the right burner is defective. As well as the switch may also be defective (is shorted because of pressing hard on it trying to make it work!!). Change the electrode and igniter switch of the right front burner.
Regards
Aug 26, 2009 | Miele 35 in. KM326G Gas Cooktop
Igniter issue - some do not turn on other do not turn off
I would try cleaning the burners. You can purchase cleaning brushes made specifically for this purpose and they work like a charm.
Sep 25, 2007 | Thermador PC366BS Stainless Steel Gas...
Ticking Sound of spark igniter persists
Our GE cook-top burner igniter has started ticking even when the oven is shut off. Even after cleaning the bottom of controls the ticking persists. Any suggestions? Thanks
Aug 27, 2007 | GE 36 in. JGP628 Gas Cooktop
GE 36 in. JGP628 Gas Cooktop Logo
210 people viewed this question
Top GE Cooktops Experts
Dan Webster
Dan Webster
Dave Harrison
Are you a GE Cooktop Expert? Answer questions, earn points and help others
