Question about LG LDF6810ST Stainless Steel Built-in Dishwasher
I'm getting an error I cannot find in the book.
The error looks like the bottom of an E followed by an E. The dishwashe wont start. It worked fine two days ago.
The "half E" is supposed to be a T. The code is TE, and means "
Thermistor trouble or very high inlet water
temperature. (over 194℉)" Some people have posted possible solutions on this site.
Posted on Aug 11, 2009
Heavy light flashing
Heavy Light flashing indicates leakage error.
The leakage sensor on the bottom cover of the unit is detecting water in the bottom of the dishwasher. Possible parts that could be the issue are as follows: Hose Connections, sump and tub assembly, drain pump or just simply the main PCB.
tip the unit in its back and remove the bottom cover. disconnect the leakage sensor and inspect the inside of the unit carefully for ANY water leaks. Most of the time its a mouse chewing holes in the tubing for water. Otherwise check carefully and you will see the leak.
Mar 23, 2014 | Samsung DW80F600 24" Black Built-In...
When I start my dishwasher the check water light keeps comming on. Also the salt light so the machine does not go through its cycle. Can you please advise me the best course of...
Hi, if your unit is getting good water pressure then the problem is going to be your flow meter which is the device that measures how much water is coming into the unit. If it doesn't detect enough water coming into the unit, the dishwasher will hault and give you check water light error. When the error comes up look at the water in the bottom and see if you have enough water in the bottom for a cycle. If not then your flow meter is fine and your unit truely isn't getting enough water which means that either your house isn't giving good water pressure to the dishwasher, or the electronic water valve that connects to the water line from your house is bad and needs to be replaced....
Jun 21, 2011 | Bosch 18 in. SRS56L08 Logixx Slim-Line...
Problem is the top drawer of dishwasher will not come on. The lower drawer seems to be working fine. Any suggestions?
if its no lights or fault codes its the main filter circut board can buy this for $50-140 depend on your supplier this happens when crewles gets into it if you remove bottome drae have look see if you se any dead crawles that what happend & secondly could be your controll board blown up from crawles this havent been buitl well for australian hot climents but built well over seas got cold wether and wont get this problem and when buying this draw dishwashers they dont tell you to put baits under the bottom draw and bug spray every where before installing it and keep it up for every 6 mths cheers
Sep 17, 2010 | Fisher and Paykel 23 in. DD-603SS Built-in...
Heller dishwasher error 004
Hi all, this error (004) means that there is an overflow....To solve it do this:
1) Disconnect the power to the dishwasher
2) Remove the left cover (to do it remove all the screws..2 are located under the top and 3 behind the front lower cover)
3) Dry very well the bottom plates where is the motor and the electrics wires.
4) The overflow switch is a floating contact, so check that there is no water under it. (You can check it pushing gently the contact).
Before reinstall the cover check that the dishwasher is working fine!
IF YES.....WELL DONE MATE YOU SAVED YOUR MONEY!
Cheers....Aldo
Sep 20, 2009 | Dishwashers
My dishwasher wont start
Sounds like you need to check for power to the unit. Access is at bottom of dishwasher under panel. Next you will see the wiring coming into an enclosed electrical box. you will need to get to wires and check voltage on black hot wire to neutral with a voltage meter. If you have power but still doesn't work then at least you know the problem is with the unit and not the incoming power.
Jul 24, 2009 | Dishwashers
Fisher & paykel double dish drawer top draw just beeps...
The controllers get very brittle & can break away from their housing, the reason it's rapidly beaping is because it thinks the door is open. PLEASE TURN IT OFF FIRST AT THE POWER POINT. Take the front draw panel off by pulling the plugs situated on the front behind the draws, the controller is at the top right hand side if it is loose then thats the problem, double sided tape will work but lots of it or try a wedge type arrangement. I know this is an old post but people refer to these for solutions much later.
Mar 09, 2009 | Fisher and Paykel 23 in. DD-603SS Built-in...
Frigidaire dishwasher wont run
I solved my problem by disconnecting from the power source and then reconnecting, apparently it needed to be reset, it now works fine!
Feb 15, 2009 | Frigidaire 24 in. FDB1050RE Built-in...
Dishwasher error
The error was a flood fault, water was not draining from either of the drawere, I removed the bottom drawer, dried drip pan and used hairdryer to dry fault sensor, the dishwasher then reset itself and works fine.
Dec 31, 2008 | Fisher DS603W / DS603B / DS603I Dishwasher
UpsidedownFE not working thermal error
Thermistor problems are really very rare.  One thing to look for is a possible broken wire in the door assembly.  Remove the front door panel.  Locate the wire harness.  About 1/3 of the way up from the bottom of the door, look for a broken wire.  If no broken wire, look for a kinked wire that may be on the way to being broken.  Once all the broken wires are repaired, the unit should work fine.  If there is no broken wire, then have the thermistor replaced.
Apr 09, 2008 | LG 24 in. LDF 7811 Stainless Steel...
LG LDF6810ST Stainless Steel Built-in Dishwasher Logo
131 people viewed this question
Top LG Dishwashers Experts
Mike
Mike
Mike
Are you a LG Dishwasher Expert? Answer questions, earn points and help others
