I got a 50'' Toshiba projection TV and when i
I got a 50'' Toshiba projection TV (used) and when i turned it on i could hardly make out the image. After realigning the convergence ( with the crosses ) it has made it better but there is still jagged lines in the top half of the screen, and the entire screen flashes the odd time. The next day i turned the TV back on and the image was worse again, so i ended up realinging the crosses in the convergence menu, and it is back to better, but still has the jagged lines and the odd screen flash. Any help?
  • adamgd86 Jul 16, 2009
    The brightness is good. The picture is not dim. Movement seems good when doing the convergence. Only problems are
    zig zagging lines,
    When i did adjust the convergence to improve the image, after the TV was off over night, it seemed to reset all my alignment settings, so i had to do it again when turned on.
    Everything else seems to work perfect.
  • 147 Answers
Replace both stk392-110 convergence ics.the crts could be weak if you have no brightness.if the picture is dim the crts are bad.but the movement of the convergence are bad stk392-110 ics.some models they are very difficult to
change.you may contact me at 972-579-0527 if you are in the dallas/ft.worth metroplex.
Posted on Jul 15, 2009
Will my toshiba tv bought in uk work in usa
There are two things you need to know regarding your TV.
Power requirements and broadcasting standards.
1:POWER
Look on the back of the TV and find the sticker or label that mentions the INPUT VOLTAGE.
If it reads 220-240V 50Hz then it will not work in the USA.
If it reads 110-240V 50-60Hz then it MAY work in the USA. At least you know it will work if you change the plug on the mains cable.
2: BROADCASTING
In the UK, broadcasts use the PAL system to display images on the screen. In the USA, broadcasts use the NTSC system to display images on the screen.
You need to check the manual that came with your TV to see if it is capable of receiving an NTSC signal. This signal is used in everything in the USA from PVRs, to DVD/HDD recorders, satellite systems, public access and cable systems.
If your TV meets the power and broadcast requirements then it should work.
May 24, 2015 | Toshiba 50H82 50" Rear Projection...
Toshiba TP50G60 Convergence Problem ??
it was on the video output module, check bad resistor near the video output module..
let me know
Aug 07, 2008 | Toshiba TP50G60 50" Rear Projection...
Picture often flickers and image distorts every few minutes
The trouble is most likely in the Video processor. If the trouble looks like its tearing the video only from side to side it may be the line doubler circuit. Some of these boards are no longer available but a good TV tech may be able to componnent level repair it for you.
Apr 15, 2009 | Toshiba TP50H95 50" Rear Projection...
DOUBLE IMAGES
there is a problem with tthe convergence section this is something a tech can do
Sep 23, 2008 | Toshiba TZ50V51 50" Rear Projection...
Toshiba power light
i would look at the front panel switch assym. for loose connection (ground)
Jan 14, 2008 | Toshiba 50H72 50" Rear Projection...
Tv has a ghost image in red
http://www.digitalhome.ca/forum/showpost.php?p=564268&postcount=220
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Nov 21, 2007 | Toshiba 50H72 50" Rear Projection...
Toshiba TN50x81 50 Inch TV most of the images seem to have a ghost image behind them
Remove the right speaker grill, there you will see some adjustemt knobs, I never tried it but might be helpfull.
Nov 10, 2007 | Toshiba TN50X81 50" Rear Projection...
1997 Toshiba TP48G10
not sound, not imagen, with you conect to power the relay is down
Sep 30, 2007 | Toshiba TP50G60 50" Rear Projection...
Generic Problem
You will need to replace or have the convergence ICs changed out. Not really a hard job and should cost you about 225 to 375 to have this set repaired. Good Luck
Apr 29, 2007 | Toshiba TP50H50 50" Rear Projection...
Color problem with Toshiba
Sounds like a problem with convergence, poss just requires new STK 392-110 ICs , may need a couple of resistors that go due to faulty ICs
Nov 02, 2006 | Toshiba 50A61 50" Rear Projection...
Televison & Video Logo
127 people viewed this question
Top Televison & Video Experts
Electro Med Services...
